Question about Watches
Reset suunto core
I am stuck in the diagnostic menu with the following list: version, contrast, pressure, display, buzzer, backlight, eeprom, magfield, compass. All I did was change the battery and it brought me to this menu. How do I get out of it to the normal functions/time mode?
  • Watches Master
  • 18,402 Answers
watchmacher
  • 302 Answers
SOURCE: I replaced the battery as
Tough one but here goes. 1 New battery does not necessarily mean good battery 2 Determine the battery is inserted with the correct side up. 3 Is there a reset. Possibly a small hole that you poke a paper clip into. 4 Try holding all the buttons in at the same time for a couple seconds 5 Go see a watchmaker,
good luck
Posted on Mar 11, 2011
SOURCE: I received my suunto t3d
To reset contrast on the sunnuto t3d hold down all 4 corner buttons at once, this will place the watch in sleep mode. Wait a few seconds and press any button to wake the watch back up. This will allow you to run through the inital set up just like when you got your watch, alot of your info will be saved so you can just quickly confirm them with the mode button. I also set my contrast too high, I have reset it to 3 and found it much easier to read in all lighting.
Posted on Jan 06, 2012
  • 183 Answers
SOURCE: Suunto watch keeps resetting itself. Changed
You wouldnt think a whole lot could go wrong with a Suunto battery change. If they had trouble getting the coin access back off and unscrewed the case then the button contacts might be out of line causing your problem. You might also check to be sure that they put the right battery in and that there are no pry marks as sometimes there are problems getting the battery out. If any excessive pressure was placed on the circuit board and it cracked it will need to be replaced.
Posted on Sep 22, 2009
mcdevito75
  • 1970 Answers
SOURCE: how to change the battery to suunto d9
mcdevito75 here, With the tools and time needed, best bet is to look for a small watch repair shop in your area to change the battery.
Posted on Jul 07, 2010
  • 1739 Answers
SOURCE: I have a Suunto Core
Not sure if this is your exact model; if not try searching for other Core models in the top right search field:
http://www.suuntowatches.com/suunto-core.html
Your User Manual is here:
http://www.suuntowatches.com/media/content/suunto/manuals/Suunto_Core_manual.pdf
If the button lock is activated there will be a lock displayed at the 12 o'clock position.
You can activate and deactivate the button lock by keeping the backlight button pressed down. When the button lock is activated, it is indicated with a lock symbol .
Posted on Mar 20, 2011
Alarm does not sound
Thank you for the member's advise that...Replace the back cover with the arrow on the back point directly at the stem. The Indiglo backlight, Alarms and Chimes should all work when all the back cover is in the correct position.
If it's at the wrong position of cover it'll not work correctly because the speaker or buzzer of your watch must be attached on the correct case back. Just try to fix it right!
Mar 11, 2014 | Timex Expedition Digital Compass T40611...
Compass comes up with RECO, what does this mean?
If you use the backlight of the alarm a number of times during a short period, RECOV appears on the display. After some time, battery power will recover and RECOV will disappear, indicating that the above functions are enable again.
Mar 20, 2010 | Casio Triple Sensor Pathfinder PRG60-1AV...
How to set the compass on a casio SGW 100
http://world.casio.com/wat/download/en/manual/
Use the four numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
Feb 24, 2010 | Casio Digital Compass Twin Sensor Sport...
Locked screen , need button combo for suunto core
If you enter the following into your search engine, you will see a list of instruction manuals.
www.suunto.com/en/Support/Download-Center--User-Guides/
Download the one for your watch.
Feb 18, 2010 | Suunto Core Wrist Top Computer with...
I have a Timex e-tide with compass, temp and tide functions. The compass no longer points north and will randomly point in any direct when activated, is there a way to re-calibrate the compass?
http://www.timex.com/info/Product_Instruction_Guides_Downloads
Use the numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
Jan 13, 2010 | Timex Expedition Adventure Tech Compass...
My Casio Pathfinder PAG-50 when I go into compass mode shows ---* is there a way to set the compass?
Hope this tip helps.
R/
David
Jan 01, 2010 | Casio Pathfinder Triple Sensor PAG501V...
How to calibrate timex t45601 compass
Hope this tip helps
R/
David
Dec 25, 2009 | Timex E Tide Temperature Compass Watch...
Instructions for timex e-tide temp compass watch
Hope this tip helps
R/
David
Dec 15, 2009 | Timex Expedition E Tide Temp Compass...
Compass wont work correctly
if your hands aren't straight when you use the compass try this to sync the hands.
1. Press and hold the middle button to enter T-Touch mode.
2. Press the centre area on the face twice to display 24hr/12hr
3. Press and hold the middle button to enter T-Touch mode untill screen says sync.The hands will face 1200.
4. Press either the upper (East) or lower (West) button to adjust the compass hands. They should both face 1200.
5. Press the middle button to get back to 'regular' compass mode. Note that your offset setting will still show in the digital area.
Oct 10, 2007 | Tissot T-Touch T33759851
Watches Logo
1,352 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
