Contrast is too dark - Computers & Internet
  • 25 Answers
Try the Fn (Fuction Key), key & the key that has the SUN symbol and an up arrow on it for brightness & the key with the half sun & an up arrow for contrast usually. (Both the Fn & that key may be necessary on certain models).
Posted on Dec 04, 2013
How can I brighten the background in CASIO fx 115ES plus? This is not about contrast. It is about the dark green background.
I'm afraid you can't. The contrast controls will lighten/darken the foreground, but there is no way of doing the same to the background.
Aug 23, 2016 | HP Casio FX-115 Plus Scientific Calculator...
Too dark
well...the contrast comes to mind first, and then the color temperature..it's all accessible from the menu, of course.
I'd start with contrast, and then look at the color temperature ratings..
Apr 27, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Fine tuning the contrast & darkness
Right click the display go to properties and on the advance tab try reducing or advancing the refresh rate to see if there is a difference. If negative restore the rate to the original setting. Good Luck. Ed Pinero
May 29, 2014 | Envision Peripherals 19" envision g917w1...
WD 73835 has ghosting images during dark or red scenes
Make sure your contrast isn't set too high. Most ghosting is caused by either contrast, brightness or tint issues. Try adjusting these settings. Also check if there is a Dynamic contrast setting for your TV as well as this can cause ghosting also.
Apr 06, 2014 | Mitsubishi Diamond 835 Wd-73835 73" 1080p...
Screen dark when i turn it on
try adjusting the contrast of ur screen. There is an Fn button in blue and contrast key in blue also. Press the Fn key and the contrast key together till u get the the darkness u want.
If this does not work, u need to get a technical guy to check the connection of ur display or u might need to replace ur display.
Jul 27, 2011 | Computers & Internet
Picture is dark. I need to adjust the contrast
If its starts out bright enough then rapidly goes to dark it may not be a matter of contrast. If it is the contrast hit the menu button and go into the video menu then select user defined as the setting select the contrast and adjust it to whatever specific setting you would like.
Feb 01, 2010 | Element Electronics FLX-2210 22 in. LCD...
While using my gps 12, the screen suddenly went dark with just a narrow border of lit screen. batteries good. I can faintly see the pages behind the dark screen.
it turns out I inadvertently adjusted the screen contrast. This is adjusted by holding the left arrow key down after powering up, until the contrast is corrected. If the screen was completely white, holding the right arrow key down after powering up would bring contrast back into balance.
Nov 28, 2009 | Garmin GPS 12 GPS Receiver
Gestetner DSm618d accidentally adjusted display too dark, now can't read it, so I can't control the machine, nor can I readjust ''contrast'' Vince
No matter how dark the contrast, if the room is dark you will be able to read it well enough to get to the settings -that is unless the display is burned out altogether
Oct 23, 2009 | Gestetner DSm618d Copier
Dim screen man
Try going to your ipod's settings, then into "contrast". There, adjust the contrast and raise the contrast percentage.
Please leave feedback and rate please ^_^
Jun 19, 2009 | Apple iPod nano
I have a panasonic television that is very dark, the other colors are okay but when it goes to nights scenes, its very dark can this be repaired, the model number is ct-25G6E
It sounds like the master contrast has slipped. If you are confident with electronics, there is a little knob on the main board which allows you to set the master contrast. This is only applicable if the picture looks like it has too much brightness (like a white haze over the picture in dark scenes). Gently adjust the knob to set the correct contrast and you should be up and running. If that doesn't work, then your tube is on the way out.
Mar 05, 2009 | Televison & Video
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
