Question about E-Machines eMachines Desktop PC
Mains cable icon stays lit after shutdown
The mains light stays lit after shutdown and eventually drains the Battery
    Champion:
    Scholar:
  • 209 Answers
When your laptop is functionning and plugged, does the battery indicates that is is recharging?
Posted on Nov 22, 2013
  • 1 more comment
  • petdon44 Nov 23, 2013
    The battery is 99% charged when plugged in then I shut down and unplug the laptop, and the connected to mains light stays on, eventually draining the battery. At present I remove the battery and the light will go out., but will come on again when the battery is replaced.
  • Elise Lacoursiere
    Elise Lacoursiere Nov 24, 2013
    As silly as it can sound, try to shutdown your pc another way. I don't know if you use Windows 8, but here's a link showing many ways to shut down. Please try and let me know if it changes anything.
  • Elise Lacoursiere
    Here's the link :http://emachines-us.custhelp.com/app/ans...
I have a makita hm 1810 hammer green light stays on hit switch light goes off
As stated in the manual:
The green power-ON indicator lamp lights up when the tool is plugged to the mains. If the indicator lamp is lit but the tool does not start even if the tool is switched ON, the carbon brushes may be worn out, or the motor or the switch may be defective. If the indicator lamp does not light up, the mains cord or the indicator lamp may be defective.
Aug 25, 2012 | Makita HM1810 Electric Demolition Hammers
The ups turns on, all the led light lit at the same time. what's the problem.
I believe you will find that your battery is either dead or shorted.
Aug 09, 2012 | Eaton Powerware® 5110 UPS System
My Dell says it doesn't recognise my new battery, and tells me that I should press F1 and that it won't be able to charge it, but it then does appear to charge it ok, although the light at the...
Hi
You don't say which Operating System you use.
A new battery needs a good, long charge for only the first charge. After that, charge until it is fully charged. The battery charge icon at the bottom right of the screen, near the clock, will tell you the state of the battery, by floating the mouse over it. If you have no icon, right click on the Task Bar, bottom of screen > properties > notification area > tick 'power' > apply > ok.
The likely cause of the original battery fault and the key to what to look out for in future with the new battery is a very common mistake in the way laptops are used. A laptop battery, working at optimum efficiency, whether of the older Nickel Cadmium and Nickel Metal Hydride or newer Lithium Ion types, is meant to charge under power and then discharge under use, if it is to have a long and useful life. This means that it should be used in a similar way to a cellphone's battery - connected to mains electricity and charged up when low or flat and then disconnected from the power and used on battery power alone until the power level means the cycle needs repeating. Many people, however, unwittingly use their laptops like desktop PCs and leave the mains electricity connected to it even after the battery is fully charged. The reason that people cite for doing this is 'convenience'. This, however, is a mistake.
Laptops have more flexibility than cellphones in that, if they are mainly used in one place rather than as mobile devices, then it is possible to charge the battery to full capacity, disconnect from the mains, then remove and keep the battery until the next time the laptop's mobility function is required (periodically recharge the stored battery if not in use for long periods of time because the charge slowly dissipates when not in use), reconnect the mains to the battery-less laptop and use it like that, ad infinitum.
When a laptop battery is fully charged, what it really wants to do is discharge. However, maintaining the mains connection prevents it from doing so. The
power management system on the motherboard is designed to cope with long periods of either battery powered or battery-less mains powered use, but not long periods of simultaneous battery + mains powered use. A fully charged battery still connected to mains electricity has no means of discharging and various power sensitive components such as the Power Inverter, Cold Cathode Backlight, LCD Panel and Graphics Chip can become damaged by the power bottleneck created.
Using the battery in this wrong way also gradually depletes the charging capacity of the cells, until eventually, the cells can carry no charge, meaning a dead battery. A dead battery, where the cells are depleted, left in the laptop with the mains connected, is even worse for the Power M
anagement System because the flow of power to the motherboard via the dead battery cells is inefficient and intermittent, creating battery overheating, low CPU Cooling Fan speed, inferior cooling and consequent internal overheating hazards in addition to potential electrical damage to several components.
Loose DC jacks, leading to intermittent power drops and surges, are typically caused by the jack being allowed to take the weight of the heavy transformer box on the laptop's power cable. The solution is to ensure that the laptop is never held, carried or used with the transformer hanging unsupported. If the laptop is in use, the transformer should be disconnected, carried, placed on a desk or table near the laptop (if the cord is short) or laid completely full-weight-flat on the floor (if the cord is long enough).
Also, always use a Surge Suppressor/Surge Protector between the mains power socket and all Co
mputer equipment, never directly to the mains.
When battery cells are dead, a replacement battery is required and should be bought and installed as soon as possible. In the meantime, the old, dead battery should be removed and the laptop used (battetyless) on mains power alone.
Manage the new battery and the AC/DC Adapter in the way described above and you should hopefully avoid similar problems in future.
I hope this helps. If this answer does help you, please take the time to rate it. This helps answerers better understand the needs and the point of view of the asker and guides us in exploring the best ways to provide useful, high quality answers. If you need further help, please feel free to post another question or add a comment to this question. Thanks for using FixYa.
Sep 02, 2011 | Dell Inspiron Mini 10 Notebook
Computer locked as though in sleep mode - screen dark grey colour. Power light lit and 'moon' illuminated. Any ideas hoe to unlock?
Remove the battery and mains and hold the power button down for 30-60 secs, then replace battery and mains. It should now hopefully turn on.
Feb 21, 2011 | MSI Microstar CR500438US Notebook PC
On my 94 jeep im having an electrical problem, something is killing my battery and i checked the alternator and my starter and i can not find the solution something is killing my battery rapidly please...
START THE VEHICLE, PUT A VOLTMETER ON THE BATTERY. THE VOLTAGE SHOULD READ 13.90 TO 14.80. IF THAT IS OK, THERE MAY BE A BATTERY DRAIN. TURN OFF EVERY SWITCH IN THE CAR.CLOSE ALL THE DOORS. MAKE SURE ALL THE COURTESY LIGHTS ARE GOING OUT. & THE GLOVE COMPARTMENT LIGHT. RAISE THE HOOD. DISABLE ANY UNDER HOOD LIGHTS. DISCONNECT THE NEG. CABLE FROM THE BATTERY. PUT A 12 VOLT TEST LIGHT, ONE END ON THE NEG BATTERY POST & THE OTHER END ON A GOOD GROUND { METAL }. IF THE LIGHT COMES ON THERE IS A BATTERY DRAIN. NO LIGHT , NO DRAIN. IF IT'S ON, ONE AT A TIME PULL THE FUSES OUT OF THE POWER DISTRIBUTION BOX. IF THE LIGHT STAYS LIT, PUT THE FUSE BACK. DO THIS WITH ALL THE FUSES BIG & SMALL. IF THE LIGHT STAYS LIT, DISCONNECT THE ALTERNATOR. THEY CAN CHARGE THE BATTERY WHILE RUNNING, & DRAIN WHEN STOPPED.
Jan 11, 2011 | 1994 Jeep Grand Cherokee
Toshiba satellite A100 dead. orange steady battery light with mains connected and power button lights shift key and 2 function lights - that's it.
It will turn GREEN when the battery is fully-charged.
Is there a problem with the battery not accepting a charge?
Remove the battery, to see if the computer will start without it.
Do these 2 lights just "blink" once, and then go out?
Does a "power" button stay lit?
Have you hired a professional computer technician to trouble-shoot?
Sep 17, 2010 | Toshiba Satellite A100-S8111TD Notebook
Laptop is turned off but the lights are still on
Can you describe the symbols that are next to the lights that are still lit?
If your laptop is still attached to mains power (ie your power pack that feeds DC voltage to your laptop) the battery pack may be still charging (indicated by a light) The battery pack is internal to your laptop and this powers your laptop when the power pack is not connected to mains.
Try disconnecting your mains power and see if a light goes off. If it does then that light is the light which indicates charging is in progress.
Other lights that are typical to laptops are:
a. hard drive activity (usually lights when the hard drive is being used) Usually has an adjacent symbol which looks like a metal can or cylinder.
b. bluetooth (wireless connection to other bluetooth devices such as cell phones, other bluetooth devices such as another computer) Adjacent symbol looks like two triangles side by side.
c. sleep (usually lit when your laptop goes to sleep and saving power) This may be covered by the power on lamp mentioned below, and the power light may flash to indicate the laptop is in sleep mode to save battery power.
d. power on (lights when your laptop is ON)
e. battery charging (as described above). There is often a symbol adjacent to this light that looks like a small battery.
Good luck,
Steve (Melb, Australia)
May 12, 2010 | Toshiba Computers & Internet
SAMSUNG NC10 CANNOT SWITCH ON
take it back and replace it it should still be under warrantie
Mar 26, 2009 | Samsung NC10-14GW Notebook
Not staying charged
something staying on or your battery has had its days
Nov 17, 2008 | 2001 Land Rover Discovery Series II
E-Machines eMachines Desktop PC Logo
26 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
