Question about Accurist Watches
Second hand going back and forth
Second hand looks as if sticking just goes back and forth
4 Suggested Answers
  • 14 Answers
SOURCE: pocketwatch quit working
Stephen,
Pocket watches are watches the collect dust (from the pockets they sit in) very easily, so you may have an issue here with that being the cause of why your hands are not moving as they once did. Then again, it could be VERY easily that you went to a place to have them replaced and the battery you purchased was "aged" and no longer has power enough to make the watch function properly. I would suggest that if you replaced it yourself in a place where you bought the battery and went home to put it in, go to a place where they put it in for you as they will overturn the stock much quicker. If the clerk is someone of real knowledge they will even be able to tell you "we sell a 20 of that one every week" or something of that nature. As I have suggested to others this is the time of year where quality of service for a small watch battery is much less then it will be when you go in in 5 weeks when the store is happy to see someone.
Posted on Dec 01, 2007
watchmacher
  • 302 Answers
SOURCE: second hand sticking to minute hand
ditto
Posted on Oct 08, 2012
small6363
  • 18402 Answers
SOURCE: Tag Heuer Professional 200M Lady - the second hand jumps back and forth around 1 second. Is the battery flat too?
yes this is a indecation the battery needs changing
Posted on Apr 04, 2013
Hi, got a seiko 7T92, the stopwatch second hand, can this be made to work as a second hand or is it only for the stopwatch function, it's annoying that it's still all the time!
If you can have both clocks running at same time, yes but they'll be on different screens. you just have to go back and forth between screens.
Apr 02, 2016 | Seiko Watches
Battery on m Invict Pro Diver watch replaced , now the second hand stays swinging back and forth in the same place
Do the minute and hour hands keep proper time? I've seen your problem before when the hand has come loose from the center post that turns it. You probably need someone who knows what they are doing to pull the crystal and reseat the second hand. Do this when the watch is off!
Sep 08, 2014 | Invicta Pro Diver 9309 Watch for Men
Value for 28116BK
about $100.
Lucien Piccard is a brand with distant Swiss heritage, which now has the same address as Invicta, SWI group, Stuhrling/Akribos and World of Watches. Asian manufacture and always a deep "discount" from list price. This isn't to say that they don't have some great looking watches, only intended as a bit of background to the company.
Mar 20, 2017 | Lucien Piccard Watches
My new nixon 42 20 when i reset the chrono the second hand doesnt go back to zero it goes to 16 seconds past how do i sort this problem its annoying !
  • Undo & pull the crown all the way out,then
  • undo the adjuster button (the one underneath the crown)
  • push the stop/start adjust button one push at a time and it will move in slight increments,keep going till you get the second hand on the 12 mark
  • then push the top adjuster and it will go back to the 12 mark.
  • Push the crown in and wind your adjusting buttons up and you have finished
Aug 20, 2010 | Nixon 4220 PU Chrono Watch Black
Swatch Irony Battery replacement will not work
mcdevito75 here, I am thinking your watch ran fine before the battery change. It sounds like the new battery is not makeing good enough contact, you can try, removeing the battery and cleaning the contacts in the watch carefully with a Q tip, dip the Q tip in anything containing alcohol cologne, rubbing alcohol, perfume wet the Q tip good, then sqeeze most out of the Q tip as not too saturate the battery contacts, also clean the battery itself, the oil on your fingers could give it a poor contact on the watch. The stop watch section doesn"t take as much battery power as the second hand. You may also be able to jump start your watch also, You"ll need a needle and a magnifier glass, With the back off your watch, right in the middle of the movement, just below where the stem (winder) goes, you"ll just see part of a little gear, this is the hour hand gear, see if you can gently move that gear just a fraction, place the needle between the teeth of the gear and try to move it as gentle as possible then se if the gear will move on it"s own., be very carefull with the movement. Swatch watches are collectables. If you don"t feel comfortable doing the above, look for a small watch repair shop in your area for help.
Jul 17, 2010 | Swatch Irony watch
Watch is new out of the box. Movement will not start. ???
mcdevito75 here, If your Wittnauer is a Quartz movement, look for a small piece of plastic, just under the crown (winder) remove this piece of plastic carefully and push the crown back down to start your watch, if it's an automatic movement, try to wind with the stem if you feel a resistance then winding will initially start yor watch by winding with 20--30 winds, if you feel no resistance when winding the simply rock your watch back and forth in your hand, you will detect something moveing inside the watch, this is the counter balance winding the watch, rock the watch back and forth for approx. 30 seconds to start an initial wind.
Jul 10, 2010 | Wittnauer Belasco 36 Diamond 27 Mm Watch...
Citizen AT03060-50E,i bobught online kind cheap than showroom so still am confused that it is original or not.. my chronograph second and minute hand stops after 1 hour,the small chronograph second hand...
The chronograph will only run for 59 minutes 59.95 seconds.
If you do not have a set on instructions for your watch, you can find one on their web site (citizen.com)
When there, click on "technical support" and the on "setting instructions" and fill in the number off the back of your watch.
Feb 01, 2010 | Citizen Eco-Drive BL5184-56L Wrist Watch
Changed bsattery and now second hand only moving back and forth ..not forward
Have the battery checked, sometimes they are duds. But most likely your watch needs to have the movement cleaned. Something is in the gears stopping it from running.Let me know what happens.
Aug 03, 2008 | Watches
Watches Logo
Top Accurist Watches Experts
Ansel Alberto
Ansel Alberto
Are you an Accurist Watch Expert? Answer questions, earn points and help others
