Question about Honeywell R7184B1024 Electronic Oil Primary is obsolete, click here to see options
How can you fix faulty parts ? the R7184B Primary Control relay's are not a good idea in my book, 3 days without heat does not make a person very excited about 2 out of the box faulty parts ! ended up
It started with the 11 year old burner motor going out, I replaced it and the primary control, the box style, putting a new R7184B on, checking the everything else to insure no other problems, the burner would ignite and run 4-6 seconds, checking everything again it came down to the primary control, I put the second one on, with very few company's carrying parts for an oil burner everything had to be ordered, day 3, I had an old furnace in the shop, I took the primary control off of it and it has ran smoothly since. This is not the first time that I've had problems with these primary controls, I have always had to put an old style control on to get the burner to work. I have 3 heating and cooling friends with over 20 years experience have the same trouble with your R7184B primary conrtols. Why are you still pasting this controls off on the public ?
SOURCE: No heat!
I took your advice and got someone in this afternoon. He replaced the pump there and then and all is working well again. He charged £135 for the pump plus labour. It was the best price I could get after ringing around a few other companies. I wish I was a plumber and could charge prices like that!
Thanks a lot for your help.
Posted on Dec 10, 2007
SOURCE: Amana Furnace runs shuts down then relights
flame rod sensor
Posted on Jan 13, 2009
tborn6
  • 700 Answers
SOURCE: auxilliary heat just started blowing cold air
SOund like you heating element has a open limit or the sequencer is bad. Another thing that it may be is the element wire has broken. Either way it sounds like you need a technician to come out and repair.
Posted on Jan 27, 2009
  • 5 Answers
SOURCE: Replacing Round Honewell Mercury Thermostat
try to get one that is made for oil heat, the installation is easy only two wires, and the instructions make it easy.
Posted on Apr 26, 2009
  • 19 Answers
SOURCE: My Honeywell chronotherm IV Plus thermostat intermittent problem
The Chrono Therm 3 and 4's were some of the worst products that honeywell has EVER put out. I would suggest switching to the Vision Pro 8000, please consult your local HVAC company for more information regarding the change over.
Posted on May 17, 2009
Furnace wont keep kicking back on. On its own, led light does blink 3 times stops and blinks 3x again
Without knowing fuel or model, it could be bad relay in primary control or loose wiring, on either power or t-stat side.
*I never recommend homeowner attempt to repair/replace any parts on heating appliance. Any information is strictly to educate homeowner on functionality. Always contact a heating professional for service and annual tune-up.
Feb 13, 2016 | Heating & Cooling
Radiator fan not working on a 03 cbr 954
Hi, Jonathan and the usual suspects are:
1. Fan fuse has blown.
2. Faulty thermostat.
3. Faulty temperature sensor.
4. Faulty wiring.
5. Faulty fan.
6. Faulty fan relay.
7. Faulty fan switch.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
over heating Fan not working CBR Forum Enthusiast forums for Honda CBR...
http://www.fireblades.org/forums/honda-fireblade/95231-radiator-fan-probs.html
Honda 954 Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda CBR954RR Owner Manual
May 19, 2012 | 2002 Honda CBR 954 RR Fireblade
I have a r7184b furnice will not reignite after 3 days since basement had 2ft of water in it. green light will not came on and does not respond with the red reset
well it could well still be damp in the furnace you may well need to dry this out , then call a heating company to check it out .
Sep 05, 2011 | Honeywell Heating & Cooling
Kenmore Electric Dryer , 700 series, MOD 64722400 , SER MR4136705 , Type DWJR-ELE-2406028-FM64 . Dryer is not heating, checked fuse it's fine, cleaned every nook and cranny with a swifter duster and...
Hi.
Be sure that you have checked the thermal fuse. The part is tested using a multimeter set on Ohms (impedance). Remove the fuse from dryer and read impedance touching the fuse contacts with the two multimeter probes. If impedance is Ohm infinity (open), then the fuse is bad.
If the fuse is OK because tested good or replaced, then the problem is either one of the three thermostats located in the heating group, or the heating element. All parts are tested similarly to what described for the thermal fuse. If any of the parts read open (infinity), then the part is faulty. After finding the defective part remove all the lint from heating assembly and air duct. The lint causes overheating and blows thermostats, fuse or element.
Regards.
Ginko
Jul 14, 2011 | Kenmore 64722 Electric Dryer
My benilli 150 want do anything when i pusg the start button
Hi, Hawksribs and the usual suspects are:
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Bank angle sensor tripped and ignition/light key switch not cycled to the "OFF" position and then back to the "ON" position.
5. Security alarm needs a reset.
6. Starter control circuit, relay, or solenoid faulty.
7. Faulty starter button.
8. Electric starter shaft pinion gear is not engaging or over-running starter clutch slipping.
For more information about your issue, please visit the websites below. Good luck and have nice a day.
Startup Troubleshooting Starting Your Scooter 1 7
How To Fix Scooter Starting Issues Part 1 Quick Guide
The Ultimate GY6 Starter Ignition Troubleshooting Tutorial
Benelli Velvet 150 2014 service manual DOWNLOAD FREE FULLMANUALS COM
BENELLI VELVET 125 150 cc OWNERS MANUAL HANDBOOK OWNER HAND BOOK MANUAL...
Apr 11, 2011 | Benelli Velvet 150 Motorcycles
Good day! A condo suite has a programable digital thermostat operating on 24v for heat (geothermal heat pump solenoid valve) ac, and a humidifier to control. When the humidifier kicks the fan coil...
Hi, start at the thermostat on this unit if nothing else has been done as far as trouble shooting and repairs. 3 months doesn't mean a thing when it comes to a/c and refrigeration & heating parts. Check the stat operation, or replace it, and I am 99.9% sure this will solve your control problems.
Sincerely, and a good day to you!
Shastalaker7
A/C, Heating & Refrigeration Contractor.
Feb 09, 2011 | Heating & Cooling
My microwave oven timer works, the turntable turns, but it barely heats, so can't be used. It worked well till yesterday.. Any ideas what the problem could be? Its a 2006 model.
Sorry to read about your problem, I hope this helps you out. you can have one of the issues.
  1. Low line voltage.
  2. Magnetron with low emission.
  3. Faulty controller or set for wrong mode.
  4. Intermittent connections to magnetron filament or elsewhere.
  5. Faulty primary relay or triac or HV relay (not commonly used).
  6. Damaged protective VDR from filament to chassis (not commonly used).
Microwaves must be serviced by technicians due to the inherent dangers involved in repairing these appliances. Internal capacitors can retain a lethal electrical charge even though the unit is completely unplugged. A microwave radiation leakage test must be performed on the unit following any internal component repair.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 04, 2011 | Goldstar MV-1501 Microwave Oven
Jenn-air dbl oven WW30430B. Lower oven doesn't work anymore. Try to pre-heat - get F2 message. This started a year ago. Shortly after onset we had a hurricane and were without power for 2 days. When power...
HI. the oven control will interrupt normal actions if it senses an abnormal oven temperature. this can be caused by a faulty RTD(temp sensor), and, also, a faulty relay board if present.
Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness to make sure it is in good condition.
Aug 04, 2009 | Ovens
Maytag MDBH970AWS Heating element won't turn off. Dishwasher heating element won't turn off. Have to shut off the breaker to make it cool down. Heating element gets hot as soon as you flip the breaker back...
The heater relay is located on the control board, a faulty relay or a faulty control board would cause the problem you have described. The fix is to replace the control board. Parts for your unit should be available from most appliance parts retailers, if there is not one local to you, the part is available at www.apliancepartspro.com. along with an exploded view of your unit
Hope this helps.
please take the time to rate this solution
Mar 05, 2009 | Maytag 24 in. MDBH970AWS Built-in...
No heat on either side
Sound like it is the control panel problem. Like a crack solider in the control panel. You will need to replace to control panel to fix the problem. If you are good????? You can get a magnifing glass and see the crack solider amd fix the panel yourself. Good luck, Spankie09
Feb 08, 2009 | 2001 Jeep Grand Cherokee
Honeywell R7184B1024 Electronic Oil Primary is obsolete, click here to see options Logo
686 people viewed this question
Top Honeywell Home Experts
Donni Steen
Tom Chichester
Are you a Honeywell Home Expert? Answer questions, earn points and help others
