Question about Kenmore 4.0 cu. ft. Steam Front-Load Washer, Metallic Gray
Front load washer makes load noise when time to drain and spin
Makes load noise when it is time to drain and spin...displayed an error mess...E21
    Prodigy:
    An expert who has answered 500 questions.
  • 512 Answers
Some times there is a panel on the bottom 1/3 of the washer with two or three screws at the very bottom if you remove that panel you will see the pump. the center part of the pump can be removed turn counter clockwise and pull check inside for an object
Posted on Nov 22, 2013
It pauses with error code E20 and doesn't seem to drain or spin, could it be the filter is cloged?
The E20 error code is a class code that indicates a drain problem in the washer. This is consistent with the drain and spin problem that you are observing. To determine the exact error code, follow these steps:
Wake the machine by pressing any button
Wait 5 seconds
Press and hold the START and PAUSE/CANCEL buttons simultaneously
The exact error code (E21, E23 or E24) will be displayed.
If E23 or E24 are displayed, you will normally need to replace the control board due to a failed drain pump relay.
If the E21 code is displayed, I recommend that you follow these troubleshooting tips:
Check the washer drain to see if it is clogged.
Check the washer drain hose for a clog or restriction.
Make sure that the washer drain system complies with the installation instructions for the washer.
Try to gravity drain the washer by placing the drain hose in a bucket on the floor. If the washer will gravity drain, you may be able to
unplug the washer
and remove the bottom front service panel using the procedure in the image below. Arrange towels to catch residual water that may be in the washer and check the pump filter and drain trap for a clog or debris. If you find no clog or debris, then you may need to replace the drain pump. NOTE: You should not attempt this procedure unless you are completely confident in your technical ability to safely access and check the pump. Do not disassemble the drain pump hose if the washer is full of water.
May 15, 2015 | Washing Machines
Front load washer e21
Good Morning Friend,
I see that you are receiving an E21 on your Frigidaire washer, model# ATF6000ES. The E21 error code states that water is not pumping out fast enough. Here are a couple of suggestions that you can try.
    1)Check the drain hose for any kinks or clogs. Also, make sure that the drain hose is only 6-8 inches down in the drain pipe. If the drain hose gets backed up with water this error can occur.
    2)Make sure that the actual drain pipe, where the drain hose goes into, is only a maximum height of 8 feet. If it is longer than 8 feet, you will need to cut some of the pipe off.
    3)Make sure that your homes drain pipes are not clogged. If they are, you will need to unclog them. Call a plumber if necessary.
    After checking the above suggestions, reset your washer by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes. When you restore power, start any cycle on your washer. If you are still receiving an E21 error code, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your washer and determine why you are receiving an E21 on your appliance. Hope this is helpful.
    -Best regards-
    WP
May 13, 2014 | Frigidaire ATF6000ES Front Load Washer
E2 error code aw-8990st toshiba wash
Toshiba top load washers have standard error codes. Depending on the display (2 or 3 digits depending on the model) it will either show E21 (or E23) or alternate E2 and -1 (or E2 and -3). Here's a list of most Toshiba washers error codes;
E1: Water doesn't drain in time or not at all
E21: Lid open
E23: Lid not locking
E31: Load imbalance
E32: Check E1 and/or E31
E5: No water coming in
You can try resetting to factory default by following the procedure: Power OFF, then pressing and holding the Super Spin Dry button, press power ON and it should beep 3 times.
Hope this helps
Jan 25, 2014 | Washing Machines
Frigidaire front load washer e21 error appears after running about 20 mins into the wash cycle,i check the clothes they are still wet,although no water is still left,i go to the spin only cycle to get the...
Hello debbiecantu1 - Typically error code E21 indicates an issue with the water not pumping out fast enough. Does the unit make a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned. Try setting the cycle to spin only and verify if water pumps out. If it does not, then the unit could possibly be experiencing an issue with a faulty pump, timer, door lock assembly or control board. Contact a professional to move forward accurately.
Dec 13, 2012 | Frigidaire ATF6000ES Front Load Washer
My frigidaire washer has e21 error code and wont start
Hello - The error code "E21" typically means the water is not draining properly or not pumping out fast enough. Does the washer making a humming noise? If so, either the drain hose may be kinked or the drain in the house is clogged. Once you have confirmed and cleaned the hose and if issue continues contact a professional to move forward accurately. The unit may possibly have a faulty pump or control board.
Nov 05, 2012 | Frigidaire Affinity ATF7000E Front Load...
Have a erro code E21 What is it
The E21 error code means the water in the washer is not pumping out fast enough. The solution is to check the washer installation. Make sure the drain hose is not kinked. Make sure the drain pump has 120 volts in the drain cycle. If it reads zero the control board will need to be replaced. If not, then it's the pump.
Nov 01, 2009 | Electrolux EW1000i Front Load Washer
Wont spin
check drain pump for obstruction, (access from rear panel) pull hose boot from tub and ck basket in hose. read tech sheet for code definition while your there. have plenty of towels and wet vac ready
Mar 15, 2009 | Frigidaire ATF6000ES Front Load Washer
My Duet washer doesn't run through the entire spin cycle on heavy duty setting. Clothes come out of washer, naturally,WET!!!!!!!!!!!!!! Seems to spin out better on the normal cycle. spin cycle dosent...
If the drain time exceeds eight minutes, the water valves are
turned off and “F/02” is flashed. Press PAUSE/CANCEL two
times to clear the display.
NOTE: After four minutes the “Sud” error will be displayed,
then four minutes later the “F/02” error code will be
displayed.
Possible Causes / Procedure
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make
sure the pump is running.
4. Check the drain pump filter for foreign objects.
Jan 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
E21 error code
There is a E21. Water not draining fast enough. Try holding the start/pause and cancel key together for 3 seconds. The door lock, wash, rinse and final spin leds should light. Any error codes should be displayed when holding those keys.
PLEASE RATE THIS !
Jun 07, 2008 | Frigidaire ATF6000ES Front Load Washer
E21 error while on final spin
E21 is telling you that it has not drained the water out. You may have something stuck in your drain pump.
Sgt 48
Jun 03, 2008 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
Kenmore 4.0 cu. ft. Steam Front-Load Washer, Metallic Gray Logo
81 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
