Question about Konica Minolta Bizhub C20/x Copier
Bizhub c20 error 004f - Konica Minolta Bizhub C20/x Copier
I do i solve a machine problem with erro code 1038 in bizhub c20?
check all connections between both circuit boards. if not that get a tech out might need firmware to be flashed. or bad board (s)
Jan 05, 2017 | Konica Minolta Bizhub C20/x Copier
How can i solve 1038 on bizhub c20?
replace the boards or have tech come out reflash the firmware
Dec 31, 2016 | Konica Minolta Bizhub C20/x Copier
How will i fix bizhub c20 when it show 13dd
you replace a circuit board and there is chip on the board missing.
Nov 01, 2016 | Konica Minolta Office Equipment & Supplies
How do i reset error c20 in bizhub konica minolta
OHP sensor malfunction had a tech check it out and or replace
Jun 04, 2016 | Konica Minolta Office Equipment & Supplies
Pls help on how to clear error 0310 on bizhub c20 i have checked all the connection and my print head is ok what next shuld i do to remove this error pls is very urgent thanksa
You didn't say what make of printer it is. Error codes vary from printer make to printer make. Your best bet is to do a Google search for ERROR CODE 0310 NAME (NAME=name of printer).
If It's a Konica Minolta read the link below:
Konica Minolta Bizhub C35 Error Codes
Feb 17, 2016 | Office Equipment & Supplies
Whats the error code 13ddon a bizhub c20 refering to?
The printer determines that EEPROM is yet to be
mounted when the main power switch is turned ON. was main board replaced recently it missing a chip!!!!!!!
Jul 10, 2015 | Konica Minolta Bizhub C20/x Copier
How do i fix error code 13DD IN KONICA MINOLTA BIZHUB C20
GET a tech out to see if the firmware can be rewritten or boards may need to be replaced.
Jun 30, 2015 | Konica Minolta Bizhub C20/x Copier
What's your question?download service codes for bizhub c20
The manual has error code listings locate the error and enter it here so that i can help you
Jun 22, 2015 | Office Equipment & Supplies
Code c004f
I get error code C-004F when i start my Bizhub C350. How can I solve this Problem?
Aug 17, 2013 | Office Equipment & Supplies
Konica Minolta Bizhub C20/x Copier Logo
54 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
