Question about Thermador MCES MCEB Convection Microwave Oven
Controls sana kusar md sharif exam seat no A004044
How can I find the specs for a microwave oven transformer?
Check with a local appliance parts distributor.
Dec 27, 2015 | Microwave Ovens
How can i change the light bulb in whirlpool microwave md. GT4185SKS-2?
Most standalone microwave ovens require removal of the outside cover to gain access to the lamp for replacement.
Oct 07, 2014 | Microwave Ovens
I purchased the Danco 80701 "Repair Kit for Delta, Aquasource, and Glacier Bay Faucets with #70 Ball" so that I can repair a leak in my Delta kitchen faucet. The instructions on the package are...
Sounds like the old style center-control delta type faucet, rubber washers describe older type but still good. The rubber seats have holes in middle, supply water to the cylinder which diverts water to the spout, and has a seal over top of ball allowing stem for handle.
Think they are talking about flex-hose type faucet accessory getting clogged, Maybe: lift the flex-hose faucet housing off the center-control faucet body? Water to it runs directly from center-control faucet and if broken seat gets in narrow line could inhibit spray.
Kitchen faucet spout too has an O-ring under where it connects to the faucet body. Unscrew large nut where meets the faucet body unit (slip-joint pliers), once free of threads, spout should pull straight up, easy or slight tug. I use bent paper clip to remove old one trying to save it in one piece so as to get exact size (that's important) to replace, push on one side then other.
Jan 13, 2011 | Microwave Ovens
My SHARP Convection/Microwave Oven only works one minute at time, no matter what the settings. M.D. Abbiatti
This is a problem in one of the damper-related components, either the switch or motor or the damper door may be binding.
The damper is a door inside that opens or closes depending on cooking mode. If the controller senses that the door is not in the right position, it will shut down the cook cycle.
Sharp models stop after 59 seconds.
See the attached sample drawing for a typical damper assembly.
We have the applicable service manuals for these models and have uploaded them to our site here and here to help you.
If a switch is all you need, we offer a universal type for only $5 postpaid which you can order here.
Dec 31, 2010 | Sharp Microwave Ovens
PLEASE PROVIDE US YOUR MD/CEO'S emailid
If you browse Samsung.jpn it will be there.
Hope this helps
Dec 17, 2010 | Samsung Microwave Ovens
Serial trr4315895 microwave md. mh3184xpq-o fan runs all time quit heating, smell smoke
your magnatron or magneto depending on model, has given up the ghost. The repair cost is almost as high as replacement.
Sorry
Dave
Jan 14, 2010 | Whirlpool MH3184XP Microwave Oven
Power setting, whirlpool microwave
My Whirlpool MD 377 is not headting. The light inside is blinking when open the door.
Oct 10, 2008 | Microwave Ovens
Night lights do not work
We see this a lot. The problem is on the control panel, which we regularly repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Feb 02, 2008 | GE JVM1660 Microwave Oven
Thermador MCES MCEB Convection Microwave Oven Logo
14 people viewed this question
Top Thermador Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Are you a Thermador Microwave Oven Expert? Answer questions, earn points and help others
