Question about Kyocera Mita FS 1010 Laser Printer
Doesnt print there is a light on on the bottom
My gateway nv79c54u laptop ac plug doesnt charge just blinks orange
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Sep 12, 2012 | Acer Gateway NV79C54u 17.3-Inch Laptop...
Doesnt print all the way to bottom of label
I had the same issue with my Zebra printer. Make sure your margins are set correctly, and you have the correct size label selected. This fixed my problem.
Aug 07, 2012 | Zebra LP 2844 Thermal Printer
Casio SE-C2000 - the reciept wont print the commercial message or bottom message, I have tried to follow the instructions as per the manual but it doesnt make sense. Please help
You need to turn them on in machine features. Find the feature number which shows "print commercial message on receipt" and "print bottom message on receipt" and program them to on state using the code number next to it
Aug 10, 2011 | Casio Parts Cash Register PC Desktop
My printer only prints top half of page when i send it to print from yahoo mail its a dell aio 810 printer
Your printer is printing what your monitor is saying. Try scrolling down to the bottom of the page, to see if that helps.
Dec 01, 2009 | Yahoo Mail
I have had 3 engineers out to try and fix my stoves 720gra cooker and has changed all the printed circuit boards ,and all other parts but still the top oven and grill doesnt work and has now been classed...
check the voltage on the spark generator,should be 240dc or 110 ac.
or it could be the harness(wires fron spark generator to ignition) to check harness do a continuity test,an electricion will know,or get a electirc tester and do it with the instructions.
Oct 01, 2009 | Stoves Premier 720GRa Gas Double Oven
Low toner light
check the tonner placement is correct
Jul 28, 2009 | Office Equipment & Supplies
Print spooler doesnt work wont print, on windows vista, lexmark x4530 printer
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Hope this help. Please Rate My Response! Thanks!
PREM
May 26, 2009 | Lexmark X2500 All-In-One Printer
Wont Print
try to go under control Panel - Administrative Tools - Services, then scroll down to Print Spooler and stop the service, then restart it. Try to print now.
good luck
Mar 31, 2009 | HP Officejet J5780 All-In-One Printer
Printer won't print
Did you peel the piece of paper on the ink cartridge?Or if that doesnt help do this get the cartridge out and then dip some water on the ink leaking part with a piece of paper and well see what will happen.
Mar 25, 2008 | HP DeskJet 5550 InkJet Printer
Printing test page
well as it seams u have given the order to ur pc to prin a test page before....but it wasnt responting so u keeped pressing the bottom..! so to fix that u can go to contro panel>printers and faxes and there u can find ur printers name...after that duble-click on ur printer and it shows a printer dialog...then delete ALL the documents that is ready to print...after that u r ready to print again!! but always remember that if u "say" to ur printer to print a page and it doesnt respont as soon as posible, it doesnt mean it wont print!! just click ONCE the print bottom the other time :)
dont foget to vote!! :)
Stratos
Nov 26, 2007 | HP PSC 1510 All-In-One InkJet Printer
Kyocera Mita FS 1010 Laser Printer Logo
16 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Adorjani Laszlo
AAAA262430
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
