Question about Hitachi Drills
Jack hammer not firing - Hitachi Drills
I have a 3600w arksen jackhammer. It does not have an oil site gauge on it that I can see. what do I do about adding oil to this unit?
all these types of jack hammers hammers use 40 w oil
its electric
cant find a user manual for it online
if no visible site glass or oil filler
whats the chances you have to undo part of the jack hammer
at the Allen key bolts
reviews say these arksen units leak oil often
Jul 20, 2016 | Cars & Trucks
I bought a new jack hammer. After using it for a few hours grease started to come out where the bit is. Is this normal
No thats not normal real JACK HAMMERS on AIR ??? but its not Milwaukee not Bosch not Dewalt but a China brand? if you are have a real jack hammer then its not the right collum because its placed under Hammer drills? and you have also not possible speaking about maybe a little weight rotary hammer ? because ONLY real demolition and jackhammers are very specially made for the long lasting jobs !!! but the weight and power is very important by use the right tool for the right job the most rotary hammers ( exept brands like Hilti and Duss) are not made for long lasting jobs and are made for only working for a short time. its also makes the great price difference between a hammerdrill a rotary hammer a real demolition or a real jackhammer is much higher price. The tools on air Atlas Copco or Ingersoll for the hard and heavy jobs
If you have bought your tool by a hardware store and it is a real jack hammer go immediately back its possible that you are wrong informed by the seller or the budget was the fact. about the price for the tool maybe you have a real jackhammer but have choose a to little model size machine to do the job or its a budget brand online bought China machine. Its a simple question but a hard answer, difficult questions do not exist but difficult answers sometimes.
Regard and luck by warranty and a very small change maybe it is just only a factory flaw.
Apr 09, 2016 | Drills
Fix low volume problem sullair 185 does not produce sufficent air to run large jack hammer
Increase the setting on the regulator (on the compressor) or maybe the compressor lacks the cfm output needed to operate the jack hammer
Dec 17, 2013 | Air Tools & Compressors
Hammer not Jacking
Mine stopped and I took it apart and found a badly worn piston gasket. I can't however find a new gasket. Anyone know where to get parts for the sky687 hammer drill then let me know. Copipeworks@gmail.com
Sep 18, 2012 | Heavy Duty 1240w Electric Demolition Jack...
Makita jack hammer 1500 service manual
Go to the Makita website at http://www.makitatools.com/en-us/Modules/Home/Default.aspx, put your model number in the search box at the top, click on the arrow and you will be presented with any models with similar numbers. Select your jack hammer and you will be able to download the manual and parts breakdown.
Feb 26, 2012 | Makita Hammering
So does the hr200 work as a miny jack hammer or just a driil, can i buy a diffrent bit for that type of model to jack hammer up a little concrete
This is an older, discontinued model Makita that only works as a hammer drill. It does not have the dial selector the newer models have to switch from 'drill' to 'hammer drill' to just 'hammer'. If you need, there's a parts breakdown and user manual available at:
http://www.makitatools.com/en-us/Modules/Tools/ToolSupport.aspx?ID=352
Dec 23, 2010 | Makita HR2010 13/16 Rotary Hammer, SDS,...
I can't find motor brushes for the jack hammer. Any idea where to look?
You should be able to go to an electric motor repair shop and they can order them for you.Also check tool repair shops in your area.
Oct 19, 2010 | Electric Neiko 02845 Breaker Demolition...
I just bought the wolf 209 magnum and trying to get familiar with it but the hammer when pulled back and fired does not hit the firing pin it's like there is something stopping it right before.. is there...
most all guns made now with a hammer use the transfer bar system for safety to make sure that it will not fire unless the trigger is pulled. **** the hammer and hold it back while you pull the trigger. You should see a flat bar move up and position itself between the hammer and the firing pin and this transfers the force from the hammer to the firing pin. If you do not see this happen then you need to take it to a gunsmith and get it repaired. hope this helps you.
Oct 13, 2009 | Sport & Outdoor - Others
No hammer
i have 900 kango jack hammer motor work but don't jack in sacramento any repair dose work on the jack hammer can you give info who work in sac thanks jim
Jul 01, 2009 | Dewalt D25330K 2KG Sds Plus Demolition...
Drills Logo
Top Hitachi Drills Experts
John Trevino
Are you a Hitachi Drill Expert? Answer questions, earn points and help others
