IO error when movie starts playing and stops
We play the mediaplayer connected to our external hard drive. When the movie starts it stops and gives an "IO error".
    Scholar:
  • 141 Answers
IO error means Input/Out error. It looks like your mediaplayer is not liking your external hard drive. Make sure the video is supported by the mediaplayer, otherwise you will need to convert it to a video file that the player supports.
Posted on Nov 23, 2013
headstrong
  • 233 Answers
SOURCE: Transfer from Laptop to 250gb WD
you need to format the dirve to NTFS or FAT32
current format has a file size limit
thanks for rating
Posted on Jan 09, 2008
  • 30 Answers
SOURCE: maxtor external hard drive 750 GB
install it drivers
Posted on Mar 15, 2008
  • 10 Answers
SOURCE: IO Magic 250gig external hard drive
Unfortunately the hard drive within the external case has died. The clicking noise you can hear is the read / write heads trying to find anything on the platter and failing, this means that any files that were on the drive are lost. There are many tricks on the net that give hope of recovering data off a dead hard drive but most just corrupt the data completely. If you have files that you must have and can afford the extremely high price for data recovery there are services available through most hard drive manufactures, most notably through Seagate.
Posted on Jul 02, 2008
SOURCE: DVD player is not able to detect WD 320 GB hard drive
Try reformating the drive with FAT32 file system (this is the default facotry mode).
Thanks,
Siva Kaza
Posted on Feb 26, 2009
  • 142 Answers
SOURCE: Computer will not locate external hard drive
Right click on your "my computer" icon in XP, or the word "Computer" on Vista/7, go to manage. On the window that opens up go to storage>disk management. Is it showing up in that list?
If you are using a Mac, go to your utilities folder and run system profiler. Does your drive show up under the usb devices tree?
If its linux, which distro are you using?
Does the drive work on any other computer? If not, I would suspect a bad drive, or a bad enclosure, or just an un-initialized drive, which can be fixed in windows by right clicking on the drive in that list and clicking intialize. In mac run the Disk Utility from the utilities folder and click the drive and select format.
In the future, pls specify your OS. thanks!
Posted on Sep 06, 2009
CANT PLAY MOVIES ON MY DVD PLAYER VIA USB
Could be faulty cable, or even incorrectly connected.
Jan 11, 2014 | Iview 103DV Compact Media Player
How do I play downloaded movies from Samsung M3 Portable hard drive to tv
Most TVs will play AVI movies from USB connected drives except Sony TVs. Sony has prevented downloaded movies playing on their TVs.
Jan 27, 2013 | Computers & Internet
IO error
The message "The Request Could Not Be Performed Because of an I/O Device Error" appears when Windows is unable to read the data on a storage device.
If this error message appears when attempting to access the files on an input/output
(I/O or IO) device, such as an external hard drive, the file system on the drive could be damaged, the drive could be infected with a virus or the data connector inside the device enclosure could have come loose.
If troubleshooting the drive fails to fix the IO device error, formatting the drive might repair the device.
Connect the external hard drive to the computer.
Run an antivirus program.
Click the "Scan" tab or button, then click "Custom."
Uncheck all items in the list except for the drive letter assigned to the external drive.
Click "OK." Click "Scan" or "Scan Now" to run a virus scan on the hard drive.
Quarantine or remove any infections the virus scanner detects.
Click "Start." Input "cmd.exe" into the search field.
Press "Enter" to open Command Prompt. Input "chkdsk <drive>: /f /r" into Command Prompt.
Replace "<drive>" with the letter assigned to your external hard drive.
Press "Enter" to run CheckDisk on the drive.
CheckDisk will search for and repair detected errors or bad sectors.
Burn the files on the external hard drive to a set of DVDs or move the files to another drive, if possible.
If the IO device error reappears when attempting to move the files, disconnect the external hard drive from the computer.
Remove the power adapter from the drive.
Check the documentation included with the drive for instructions to take the drive apart.
If no instructions are available, contact the manufacturer for instructions or find out if disassembling the drive will void the drive's warranty.
Remove the screws securing the faceplate to the drive or from the edge of the enclosure. Insert the edge of a small, flathead screwdriver in between either side of the enclosure to wedge both sides apart.
Check the connections to the drive.
Confirm that the IDE or SATA interface is plugged into the back of the drive.
Reassemble the external hard drive, reconnect the power adapter and reconnect the drive to the PC.
Attempt to access the files on the drive.
If the IO device error reappears, return to Command Prompt. Input "format /fs:fat32 <drive>:" into the command-line prompt.
Replace "<drive>" with the letter assigned to the external hard drive.
Press "y" when the message "Proceed with Format (Y/N)?" appears.
The process will format the drive, erasing all data on the disk.
If the drive still fails to function after format, you will need to replace the drive.
Hope this helps
Nov 25, 2012 | Western Digital WD5000AAVS 500 GB SATA II...
I/O error on Buffalo HD-PET500U2 Ext Hard Drive
If this error message appears when attempting to access the files on an input/output (I/O or IO) device, such as an external hard drive, the file system on the drive could be damaged, the drive could be infected with a virus or the data connector inside the device enclosure could have come loose.
Hope this helps
Nov 16, 2012 | Buffalo Technology Computers & Internet
Useing external hard drive to record films to play back through tv connect to usb and it showes unsupported devise what is the solution
check what type of file extensions your tv plays and only load those kind of movies onto your hard drive.
Apr 16, 2012 | Computers & Internet
Playing movies from external hard drive
Hi rox09
Well you can rip your DVD to any external drive using and third party DVD ripping software ,once you do that you will get a AVI,MPEG and any common fomats your DVD player supports
Inorder to play those files in your DVD player ,you need the check whether your DVD has a USB input port or else if you laptop or computer has a S-video out put and your TV has S-Video input ;you can play directly from your laptop/computer to the TV using a S-video Cable which is available in any Computer shop.
I hope this helps
VJ
Mar 15, 2009 | ASUS Eee PC 900 Notebook
Both methods will work, but you will tend to have more control on the quality of the saved video if you "rip" the DVD yourself.  There are several methods to rip a DVD.  One, you can use the program SUPER, which is free, to rip to a single file.  Otherwise you will have to use several programs.  The second method is to use DVD Decrypter to rip the dvd. Then use VOB2MPG to combine the separate VOB files.  Finally, use SUPER to compress the DVD video to your liking.  In order to use your external hard drive to display to your TV, you have 2 choices.  One, move your computer to your living room and buy an aftermarket video card to output to the TV.  Two, buy a cheap computer which can run video w/o lagging and install an aftermarket video card to output to the TV.  I hope this helps in your DVD video adventures.
Jan 03, 2009 | Dell Dimension 3000 PC Desktop
Using the External Hard Drive
The external hard drive has to be connected to the computer, then from the computer you have to connect a cable to the TV. New TV's have a vga cable, where you can connect the computer directly to the TV, but some might have older cables.
Here is a list: http://en.wikipedia.org/wiki/List_of_display_interfaces
I hope that helps..
Jan 01, 2009 | Dell Dimension 3000 PC Desktop
Mediaplayer
hi youve got a few ways: 1) press on the link of the movie right mouse key - "save target as" download it and then open it 2) when the mediaplayer starts push stop untill you see the faint strip fills all the line time and then the movie wont stop for buffring 3) choose a lower resolution before cliking the movie good luck
Apr 19, 2006 | Dell Inspiron 6000 Notebook
Computers & Internet Logo
47 people viewed this question
David Payne
David Payne
