Question about Logitech ChillStream Game Controller for PC
Repair manual000015037 how to replace usb cable?
How do I repair/replace a damaged USB port?
Do you using original cable from Klipsch?
Make sure your charger is on normal working conditions.
It is difficult to fix the USB port, except the experts.
Aug 23, 2015 | Klipsch GiG Portable Wireless Music System...
My PS3 won't reconize any of my controllers, putting the cable in works, it find the controller, but when I unplug te cable the lights start blinking again and I can't use the controller, what to do?
Hmmm. It sounds like either your PS3's Bluetooth controller is on the fritz, or all of your controllers are on the fritz. Since I doubt ALL of your controllers are malfunctioning, I am betting it's your PS3. I suggest having a friend with a working controller stop by and test his controller against your PS3. IF your friend's controller works, then you know that the PS3's Bluetooth controller is working.
Second step is to check to see if the USB cable is transmitting a trickle charge to the controller. Again, using your friend's controller (make sure he brings his own USB cable with him), try charging his controller with HIS cable first. If after 10 minutes of playing with the controller plugged into the PS3 via USB, you unplug it and the controller still works, then the problem is most likely your own USB cable (it's apparently damaged in some way). Now run down the controller's battery and try recharging it with YOUR USB cable. If it fails to charge, then you know that all you need is a new cable. Just in case, make sure you test EACH of your USB ports. A simple replacement will cost you around $10.
Otherwise, your PS3's UBS port(s) are not properly working and you should send in your PS3 for repairs. As stated above, test each of the USB ports on your PS3. My 60GB one has 4 USB ports, so I would test all 4 of them before sending in the PS3. Then, if you want it repaired, make notes of which port(s) is(are) malfunctioning and send it to an authorized PS3 repair center.
Dec 24, 2010 | Sony BD Remote Control for Playstation 3
My Zen Vision M is not recognized anymore by my pc. Windows XP.
Hi the USB port had gone out or your USB cable is bad. The vision M players are bad about the USB port just all the sudden not working. I want look damaged or anything but no matter what you do the player want connect. If the USB cable is not the problem the USB port is and your main board will have to be replaced.
If you need any more help, parts or your player repaired you can go to my repair service web page and e-mial me, call me or contact me threw my Ebay user name at from my web page at firehouse7777.weebly.com Thanks
Dec 08, 2010 | Creative Labs ZEN Vision:M Digital Media...
Computer (Mac or PC) won't sync computer does not recognize the unit is plugged in
  • Check the cable make sure it is properly connected and use other usb cable just to make sure if the cable is the problem or the unit.
  • After you use other usb cable and still the same call customer service of Magellan advised them that you already used different usb cable and still the same it is not working. They will check in their and if they checked its really not working they will check if still under warranty so that they will repair it or you can request for replacement.
Jun 14, 2010 | GPS
Power failure after plugging in USB cable. No power
You likely shorted your motherboard/ southbridge. A competent repair shop (one that can diagnose to board level)may be able to repair the short if it is not too bad otherwise you will likely need to replace the motherboard.
May 10, 2009 | Computers & Internet
My mp3 player won't do anything!!
Hello there,
It is unlikely that the player is dead but the Usb cable or USB/charging port or the battery is dead. If the player is under warranty you can demand for a replacement. Otherwise check if a replacement usb cable would fix the issue. Otherwise its going to cost you around $30 for repairs.
Sai.
Feb 15, 2009 | Philips GOGEAR SA6045 MP3 Player
Bad USB Port in Camera
With that amount of non-accidental damage, a replacement is the best option financially
Mar 05, 2017 | HP E427 Digital Camera
I think you CAN--there's a lovely site with specific instructions,,,, Do It Yourself Camera Repair --- for fabulous step by step instructions WITH pictures & simple explanations that a novice can follow!!!
In short, all you need to do is find another USB port (even from a broken camera or other device) to replace yours. It seems that you'll need to solder it in -? - that's the step I'm trying to research right now--I'd like to just glue mine back in because I don't know how to solder--- but the tricky part is getting the camera apart, not touching the flash capacitator nor any of it's power-holding chips, and not damaging any of the other components.
(ACF0EB8F)
Aug 18, 2008 | Kodak EasyShare DX7440 Digital Camera
Logitech ChillStream Game Controller for PC Logo
44 people viewed this question
Top Logitech Video Game Consoles & Games Experts
Lyle Siemens
Lyle Siemens
Rob boss
Level 1 Expert
Are you a Logitech Video Game Console and Game Expert? Answer questions, earn points and help others
