Ariston washing machine
My washing machine lets the water out straight away without the washing cycle
  • 118 Answers
You might have the drain hose down too low....if the drain hose exits the machine at the bottom and you have this hose low down into the floor outlet this action will occur. Raise the pot let hose int a trough as high as the top of the machine.
Posted on Jan 31, 2014
4 Suggested Answers
SOURCE: ariston AVXD 129 washing machine displayed F--05
my washing machine displayed F--05 and water is not going out, I clean the pump and start the machine but the water is not going out. wHAT TO DO?
Posted on Jul 11, 2008
ginko
  • 19396 Answers
SOURCE: Washing machine fills in the water but does not start the wash cycle
The fact that it does not fill completely can be related to a problem with the water-level switch, that regulates the water level.
See from Repairclinic:
"This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch."
However, when it is only the switch the mashine usually completes the cycle, but with less water than normal.
A possibilty is that either the timer is faulty or there is a problem with the water supply.
Check that water is coming from water supply with regular pressure, and that hoses back there are not obstructed.
More likely you will have to replace the timer.
See again from Repairclinic:
"When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water."
  • You can find parts at the following websites, you need to input your model number. If the part is not listed contact them.
    Repairclinic
    Partselect
    Don't forget to rate the solution.
    Many thanks.
    Posted on Sep 01, 2008
    SOURCE: Ariston A1635 Margherita Control knob spinning
    According to the instruction book - it appears the machine has been stopped mid cycle then re-started.
    Switch machine off, turn control knob to a solid circle symbol (they are after every set cycle). Switch machine back on and lights will flash and program is reset. You can then select wash cycle as normal.
    Posted on Jan 23, 2010
    Water runs in and straight out of my washing machine
    drain pipe has to be as high off floor as the washer is tall .
    Jan 30, 2016 | Washing Machines
    Ariston L63S dishwasher does not rinse
    Check the screen and the inlet to the pump in the bottom of the washer if it does not empty the water from the wash cycle completely it may not go to the rinse cycle.
    Sep 06, 2017 | Ariston Technologies Dishwashers
    Ariston 1636 f/l washing machine not draining properly
    you need to clean the water passage at the drain hose.
    Feb 27, 2012 | Ariston Technologies Washing Machines
    Hello I have an Ariston advantage AF300 dish washer. And it has stopped working properly. The problem seems to be that no water is being sprayed around inside. The machine works its way through the...
    Hi
    You either have a food or glass particle lodged in the wash motor impeller not letting it turn or more likely the wash motor capacitor needs replacement.
    I suggest getting a repairer as the Aristons are tricky to repair.
    Ash
    Sep 03, 2011 | Ariston Technologies Dishwashers
    Leaves white deposit on washing
    What you probably have is a build-up of scrud in the machine as a result of an interaction between the fabric softener and the detergent. This flakes off and marks the clothing.
    Buy a commercially available cleaner for your machine for this purpose of do one or two cycles using a bottle of white vinegar in the tub without detergent. Clean the machine out doing another cycle using baking soda directly in the drum. Repeat this process if there are still any indications of scrud.
    Take care that you use the correct amount of detergent in your machine according to load and water level and do a cleaning run about every 25 wash cycles to clear away any excess detergent that was not caught by the rinse.
    Apr 06, 2011 | Ariston Technologies Ariston AWD12 Front...
    Water not emptying from the machine,
    Here is a tip that I wrote a bout front load washer spinning and draining problems...
    Front Load Washing Machine2_bing.gif not draining and or not spinning
    http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
    heatman101
    May 16, 2010 | Ariston Technologies Ariston AWD12 Front...
    Ariston awd121 washer will not complete wash cycle
    I'm also having the same problem. I hate this machine!
    Jun 28, 2008 | Ariston Technologies AWD 121
    New Ariston wash cycle
    This is exactly the way the systen is designed to work. It uses very little water so the machine sort of flips the clothes over and lets them soak, then flips them again. Every thing is fine as as it should be.
    Feb 07, 2008 | Ariston Technologies AWD121WH
    MACHINE DOESN'T CYCLE OUT OF RINSE
    Does it spin if you move the timer manually? ist it being used on a delicate cycle@? if so it will stop in the last rinse water
    Jul 10, 2007 | Ariston Technologies AWD 121
    Washer not completing cycle
    I HAD THE SAME PROBLEM ON A 4 MONTH OLD MACHINE AND I CALLED A SERVICE PERSON. HE SAID THAT I CAN THROW IT AWAY. THIS IS A PROBLEM THAT NOBODY CAN FIX.
    Sep 21, 2006 | Ariston Technologies AWD121WH
    Washing Machines Logo
    22 people viewed this question
    Top Washing Machines Experts
