Question about GE WHRE5260E Top Load Washer
What is the load capacity for the daewoo DWF-772W
What is the exact belt size of Daewoo Fuzzy Logic washing machine 7.5 kg dwf-75ts? Where can I order this?
Hi,if you still have the old belt,take it to the shop and ask them to give you a replacement.
all the best.
Apr 28, 2015 | Daewoo Washing Machines
DAEWOO WASHER DWF-800WPS machine the outer water is countune going out what is the problem
pump is running and not stopping, low water sensor is not working properly, replace part. it is behind control panel .
Jan 11, 2015 | Daewoo Washing Machines
I have daewoo dwf 200 le and it not taking the water from the pipe outlet what to do to fix the problem
Assuming you have mains water running to the inlet tap and the tap i is open, the most likely cause is inlet hose connector filter is blocked or the inlet valve inside the washer is faulty.
Hopefully you are able to select the wash program and start the wash cycle. Otherwise the problem could not be in the water inlet or elsewhere.
Refer page 21 on this manual and also check the part number and location of the inlet valve.
http://www.daewoo.cl/sta/manuales-tecnicos/DWF-312W%20Manual%20Tecnico.pdf
Aug 17, 2014 | Daewoo Washing Machines
LE CODE WHAT MEANS. DAEWOO WASHING MACHINES MODEL: DWF-772W
LE error code refers to the door mechanism. Usually there is a locking switch that senses when the door is closed, allowing the wash cycle to start. If your door is closed and you are still getting the LE error, it is probably this switch that is faulty.
Apr 20, 2011 | Washing Machines
Daewoo nano silver dwf-170mp
This Daewoo top load washing
Machine is the worst washing machine ever. Tried to call their maintenance many times still the problems coming back. Water flowing non stop, i need to spin it first to work properly. They repair it but the problem coming back always and its not abyer yet. My advice dont ever buy this machine again.. Its a full waste of money
Oct 17, 2010 | Washing Machines
I have a DAEWOO DWF-1150P top loader washing machine and when I switch it on I get an error code E9. Can you please tell me the fault and how to repair it?
I have a daewoo top loader washing machine ,,
Mode W/M-DWF-200MP
The power main board does not take the programs to work how should be its olny one program
Apr 29, 2010 | Daewoo Washing Machines
What is LE error for Washing Machine Daewoo DWF 772W model? how to solve it?
In other Daewoo models LE error code means pressure sensor failure. This sensor is used to know water level in the tube. It is probable that your model reports the same codes.
It does not necessary means a broken sensor you must check the electrical connectors and cables as well as all the mechanic and pneumatic elements like the hose connected to the sensor.
It is often clogs with soap and other particles.
Good Luck!
Jun 16, 2009 | Washing Machines
Dwf-6010ap
I HAVE DAEWOO WASHING MACHINE MODEL DWF-6010AP
THE PROBLEM IS THAT COLD INLET IS LEAKING WHEN RUNNING I NEEDS SOLUTION OR WHERE CAN I GET PARTS
Jun 25, 2008 | Daewoo Washing Machines
GE WHRE5260E Top Load Washer Logo
164 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
