Question about Canon iR5000-6000-L1 PS Ver 1.0
What is the setting for paper tray legal
What is the number to be given for paper setting to set legal for tray 3 & tray 4
    Problem Solver:
  • 21 Answers
Click Start, Devices and Printers. Right click on the printer and select properties. Change the paper settings for each tray.
Posted on Nov 30, 2013
Tray 2 stuck in legal size
Replace the paper tray. It is broken.
Mar 07, 2014 | HP LaserJet 4600dn Color Printer
I cant get my printer HP2055 dn to print letter paper..it just goes to the legal tray (3). I also can't figure out how to get to the menu on the printer to see if the trays are set correctly.
Go to your menu and select paper handling. From there you can reset the paper settings. If paper will not pull from tray 2 you probably have worn out feed rollers.
Feb 12, 2013 | HP LaserJet P3005n Printer
Legal size no print of hp Laser Jet 2420n printer
Hii It could be wrong on this but there should be a setting on the printer for paper size and type for tray 1. Use it to set tray 1 as legal size and then use your program to send to the printer. Another way would be to have no paper on tray 1 and send the job. The display on the printer should say to load legal on tray 1 and hit the button to continue. When you do the printer will now know it has legal paper in tray 1. The last method is only good for that job and will have to be done the same way for another job. Specifying tray 1 as legal paper will allow you to have legal paper in the tray when the job is sent and not have to press the button.
All the Best.....
Dec 11, 2010 | HP LaserJet 2420 Printer
My Lexmark T640 does not seem to recognize paper "tray 2". I want to print legal, but it only prints from tray 1. How can I get the printer to recognize and use tray 2 so I can print legal AND letter?
2 things
1st make sure the paper guides are set correctly on the trays for legal make sure it's exactly on legal or it put the tray into universal mode. (To clarfiy the guides in the back which allow you to put legal in the tray.)
2nd Go into menu and then to paper menu and adjust/ confirm the settings for tray 1 and 2. Based on your question tray 1 is letter and tray 2 is legal, so make sure both of the tray size and type are set correct.
Oct 21, 2010 | Lexmark T640 Laser Printer
How to print with the legal paper?
follw the given step and check-
1-Before printing your document, be sure the page size is set to legal paper. Go to "File> Page Setup" and then click on the "Paper Size" tab. Select "Legal" from the drop-down menu.
2-Go to the printer and take out the paper tray. Remove the letter size paper.
3-Insert about one half of the package of legal size paper into the tray, depending on the depth of your tray. Larger printers can accept an entire package, while smaller ones cannot.
4-Make sure that the paper goes underneath the metal clips located at both the front and back of the tray.
5-For printers that don't have a tray, you'll have to manually feed the legal size paper. Locate the paper feed either on the front or rear of the printer.
6-Put a few sheets of legal size paper into the paper feed. The paper should be placed as close to the rubber spindles as possible. These spindles will draw the paper into the machine and feed it through the printer.
7-Print a test page.
Thanks,
Dec 03, 2009 | Brother HL-2040 Laser Printer
My photocopier has 3 drawers - First is universal and 2 & 3 are both set at letter. I would like to set drawer 3 to legal. how do I get the copier to recognize the change?
Please specify the models.Also the Minolta copiers paper tray change:Press utility key-User choice-paper set or
Utility-Meter count-Stop-0-Stop-0-0-1 Paper size input :set the paper size used in each paper source.Touch the key of paper sorce for wich the paper size setting is to be changed to show the paper size input screen.Touch the desired paper size keys.Touch END to validate the paper size setting.
Please look the mechanical setting in the trays.If so need,change.
Aug 13, 2009 | Konica Minolta Office Equipment & Supplies
Want to print on legal size paper from Tray 1 (top) as default
print menu - config and verify paper is being sensed correctly. If paper size in tray is not set correctly printer will ask where to print from
Feb 12, 2009 | Lexmark T640 Laser Printer
Unable to get faxes to print to legal size
here are the steps that i want you to follow inorder to use the tray for legal size.
1. On your printer itself, Press the SETUP BUTTON.
2. Scroll Down, and look for the option "Preferences", then press okay.
3. Scroll down again, then look for Tray Lock, and press okay.
4. Under Tray Lock, you will have an options there;
- Tray 1
- Tray 2.
5. If you are using the legal size paper for tray 2, then choose Tray 2 and press okay button to apply. And if you are using the Tray 1 for the legal size, you can go ahead and choose Tray 1 and press okay to apply. And this should work.
If in case you still have issues setting it up, please inform me.
thank you so much.
adonscott
Jul 28, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
Will not print on legal paper
Well I fixed mine to where it will do it. I had the multi- tray feeder where there was 2 paper trays (one legal & one letter) I removed one paper tray system and put the legal cassette in that one tray. Wala! it detected it as a legal tray now. I got the best of both worlds by removing that tray. Now all you have to do is specify if the paper is legal or not. Just change it on the printer tray and change it on the print properties of your document and away you go.
That's the best I have been able to do.
Sep 25, 2007 | Dell 3100cn Laser Printer
Computers & Internet Logo
Top Canon Computers & Internet Experts
Aashish Chaudhary
Aashish Chaudhary
Computer Links
Tony
Are you a Canon Computer and Internet Expert? Answer questions, earn points and help others
