Question about Mastercool Heating & Cooling
Blowing 10a fuse in the control box of Bonaire integra evaporative cooler
Is it the motor or control box
  • 38 Answers
SOURCE: my cooler is blowing very slow can hardly feel the air
it could be any of three things.
1. its a variable speed motor and will not blow hard unless you have an extreme cooling need (5 degrees or more away from set point)
2. You have collapsed duct work.
3. Dirty evaporator coil, or filters preventing proper air flow
Posted on May 08, 2009
koolbreezes
  • 540 Answers
SOURCE: Is it possible to get a new manual for my Vulcan
Check out this website for manuals.
Posted on Dec 22, 2009
SOURCE: I've lost the manual for my Bonaire VSL75
I think you mean "SLV 75" which is the "Integra" model.
I will post one in the manuals section.
Posted on Dec 30, 2009
  • 37 Answers
SOURCE: Evaporative Cooler Bonaire Profile do you put
Yes, it does require you to pour water into it from the back opening (where the aspen pad is located). I have one myself it works well on days up to 35degrees, the other temperatures higher it just acts as a spot cooler.
Thank you for submitting, and Happy New Year
T.Scott
Posted on Jan 07, 2010
SOURCE: Our Bonaire Evap Cooler stopped after power failure
Turn the power of to both the heater and the cooler. Turn the power back on to the heater and the cooler at the same time then reset codes on controller.
Posted on Feb 09, 2010
My Bonaire evap cooler keeps tripping the fuse when I turn it on
there is an electrical short in the unit that is causing the fuse / breaker to trip
could be insulation, moisture in a junction connection or failing motor
Call in an accredited electrician to find / fix the fault
Mar 12, 2016 | Dryers
Bonaire vulcan evaporative air conditioner
check your filter for dirts, clean or change it, check your evaporator and condenser coil and clean....
Jan 29, 2014 | Heating & Cooling
I have a bonaire evap system cant get it to come on have changed batteries and reset it still nothing happens the remote is called bonaire comfort control have recently brought the house and cant find an...
Remotes are a pain. Can you get into the unit to see the control box? You need to see if the unit has power. If its new enough it will have some diognostic lights so you can see if it has power. Without that its hard to diognose. Unit Model number is also helpfull. if it looks like the one on this picture it will be etched into a badge on one of the corner pillars. if its a plastic unit it will be on a sticker inside the unit
Feb 24, 2011 | Mastercool 67471 Evaporative Cooler Air...
I have an evaporative cooler: vulcan bonaire. the only control buttons which appear to be useful are: on/off, cool in the 'appliance' window, and cool in the 'mode' window. i have a feeling that this is...
Hi and welcome to FixYa. The principle of operation of an evaporative cooler is to provide cooler air via evaporation. The evaporation process is achieved by water being pumped over very porous pads with air is drawn through the pads. Most all evaporative coolers unless connected with a centralized heat / cool system only have an on / off & cool function. "On" is fan only (air circulation while using outside air being drawn into the home) and "cool" turns on the pump to pump water over the pads for evaporative cooling. Hopefully I did not confuse you with my answer.
Happy New Year and thanks for choosing FixYa,
Kelly
Jan 01, 2011 | Heating & Cooling
I am looking for a fuse box layout for a 1998 jaguar xj6 as i need to find the fuse for the cigarette lighter
The fuse for cigarette lighters is number 9 = F9 (20A).
The fuse box / relay plate (fascia 1) is located inside the car under rear left seat 1 for Right Hand Drive (RHD) cars.
The fuse box (fascia 1) layout is:
1. F1 (10A) = Rear fog lamps
2. F2 (10A) = Heated mirrors, panel lamps rheostat
3. F3 (20A) = RH seat motors
4. F4 (20A) = LH seat motors
5. F5 (10A) = Instruments
6. F6 (5A) = Seat control modules, low power door switches, mirror motors
7. F7 (30A) = ABS pump
8. F8 (10A) = LH indicators / repeater lamps
9. F9 (20A) = Cigarette lighters
10. F10 (5A) = Cruise control
11. F11 (20A) = LH A/C blower motor
12. F12 (5A) = Instruments
13. F13 (15A) = Steering column adjustment
14. F14 (10A) = Automatic Transmission (AT) ignition supply
15. F15 (30A) = LH electric windows
16. F16 (5A) = ABS ignition supply
17. F17 (10A) = Electrochromic mirror, reverse lamps
18. F18 (10A) = A/C supply
Please rate my response. Thanks!
May 22, 2010 | 1998 Jaguar Xj Series
Feb 07, 2010 | Mastercool 67471 Evaporative Cooler Air...
Vulcan-Bonaire : summer breeze
This unit is a cooling unit only. I don't know what switch you are looking at but I don't think it's for the evap. cooler(swamp cooler). I am in the Phoenix, Arizona area and it's very common to have a evap. cooler and a seperate heat/cool system as on the hottest days the evap. cooler doesn't cool enough. I hope this helps. Please give me a positive rating. Thank you.
Jan 27, 2009 | Mastercool 67471 Evaporative Cooler Air...
Heating & Cooling Logo
64 people viewed this question
Top Mastercool Heating & Cooling Experts
Bill Long
Dan Webster
Dan Webster
acrman404a
Level 1 Expert
Are you a Mastercool Heating and Cooling Expert? Answer questions, earn points and help others
