Question about Ovens
I need a manual for a Creda Cordialle SO11G oven that appears to be. Gas oven but an electric grill - thee is nothing obvious as to how to control temperature etc. can you help?
My mum has just moved house and there is a creda Cordialle SO11G oven which seems to be gas but with an electric grill; there is a dial for the grill and some buttons on the front for a timer and cook time but no clear way of turning the oven on and setting a temperature - can you help please?
4 Suggested Answers
Junoon007
  • 1011 Answers
SOURCE: Creda Double Gas Oven. Model Europa Gas.48132.Serial No: 83 1 00087
Dear Sir/madam,
This is what should happen:
1. You have a call for heat at the thermostat and the purge fan turns on.
2. 30 to 60 seconds later, you will hear a clicking sound or a glow plug ignitor get bright.
3. The pilot should light and withing a few seconds, the main burner should ignite.
4. The main burner will stay lit without the fan turning on. The fan should turn on automatically about 45 seconds to 2 minutes, depending on the temperature sensor in the heat exchanger.
sorry i cannot found maintenance manual in internet.
Thanks
Good luck
"Don't forget to rate the solution"
Posted on Jul 18, 2008
  • 40 Answers
SOURCE: creda cf50g cooker oven not getting hot
sounds like the ffd is at fault, this is a safety device that alows the main flow of gas through. when the cooker is cleaned the sensor can be moved by accident from its position over the flame, another reason could be a build up of grease etc, stopping the flame reaching the sensor. if none of these then the ffd unit needs to be replaced. they are about £20.00 for the part
Posted on Apr 07, 2010
  • 2501 Answers
SOURCE: Just moved into a rented bungalow - the Creda
Try pressing the "select" button. This should activate the settings menu and use the other two buttons to adjust the time or temperature or anything else tha tappears on the display.
Experiment a little and have patience!
Posted on Sep 26, 2010
Creda Solarplus (48906) top oven and grill not working
Electric stoves do not have pilot lights or igniters it could be the power control board has failed .
Mar 12, 2016 | Creda Ovens
I have a double electric creda oven and i have just had the house re wired. becasue the power has been off the oven is flashing on the display at 0:00 auto and i cannot switch my main oven on as when i...
While holding minute minder and cook period buttons press + or - to set the time after time is set release buttons this should allow for normal operation
May 27, 2014 | Creda Ovens
Creda oven manual
The heat control knob needs to be replaced. This controls the amount of electricity that foes to the burner. Sometimes the burner itself has too much resistance and will only work when full current is applied. Hope this helps, please post a comment that this is solved on fixya.com. So I get credit for a solved problem if it does. If not, check back and give me more info.
May 10, 2014 | Ovens
I've got an Hoover HDC884X Built in Electric Double Oven. Can you tell me what I need to do grill toast. Don't understand the knob controls and the manual doesn't help as it is too generic
Hi, I understand your frustration, the manual supplied is next to useless! The 'obvious' settings appear NOT to work (as the grill remains on full heat setting all the time). The only way we've managed is to lower the food away from the grill..... not ideal I know - but also we don't use it for toast.
I suppose Hoover would be the next best port of call for assistance, oh for a proper manual, not a horrible generic one that attmpts to cover every model they produce - AND FAILS.
This is purchasers main complaint about buying Hoover ovens it seems.
I'll come back to see if anyone can supply a solution to our problem.... and hope it's not a fault in manufacture.
May 05, 2011 | Ovens
Creda fan oven not heating grill is working and light is on in oven
If the fan is working o/k, then the oven elemment has probably failed.
This is located at the rear of the oven compartment behind a removeable cover.
If the fan is not working, then it it could be the timer is on auto, and not on the manual setting. Check your user instructions.
Feb 02, 2011 | Creda Ovens
Creda Europa Oven an Grill Big oven has Stopped working what would be possible causes
do you mean there isnt any power going to it or it dosent heat up or it just gets warm more detail please
Dec 05, 2010 | Creda Europa E010E Electric Single Oven
Creda Cordialle fan assisted oven is so noisy what can I do?
If it is the fan that is noisy, check for loose fan or the fan blades catching the cover, if all o/k, then it will probably be a worn fan bearing, only solution would be to replace the fan motor.
Nov 07, 2010 | Hotpoint Ovens
Just moved into a rented bungalow - the Creda Cordialle electric fan oven will not turn on - the clocks are all over the place and I do not understand how to set them and to get the oven to work at all -...
Sep 26, 2010 | Ovens
Because I haven't got a manual, and the oven is slightly worn, I would like to know what the symbol at the eleven o'clock position on the top oven control knob means. There are 2 symbols that appear to be...
There are two controls for the top oven and grill.
The far left one is purely for the oven and oven lights. The middle control of the three on the panel is for the grill. The grill will only work when the front is down, there is a micro switch that controls this.
The grill control is a dual action control. Turn it one way and it is the full grill, turn it the other and it is only the inner element. Left is the small grill, right is the larger, full grill. Oven lights do not come on with the grill control, you have to turn the lights on with the oven control.
The oven has a small element so takes a long time to heat up.
If you need a copy of the handbook, supply an email address and you can have access to my BT digital vault where a copy is stored.
Dec 10, 2009 | Stoves 720EF Electric Double Oven
Grill faulty on my double oven
Creda reflection double oven had the same issue, both ovens work but the grill was either hot or cold, no temp control. I changed the thermostat first, due to being a novice and not fully understanding how things worked. it didn't help so I have changed the grill regulator,( bit that the knob fits onto) and it has solved the issue. I expect this to be the same with most top oven and grill combinations with the oven working but the grill only being hot or off.
Apr 07, 2008 | Ovens
Ovens Logo
32 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
