Question about Irons
I require a domotec dsc7 super steam cleaner instruction manual
I have a EURO-PRO X Model EP965 Steam Generator seems to working but steam is not coming our, neither for the iron nor for the brush.
I think you have a tank that is calcified and is not getting enough heat to the water assuming there is enough water in it. If it was blocked it would either cause the relief valve to vent or explode.
I would start by cleaning it, my best guess would be to run a few cycles with vinegar in it. This is a mild acid that will dissolve the calcium deposits. Try maybe a 50%-50% with vinegar and water.
Be sure the vinegar will not damage the unit, I do not know.
Hope these links help.
http://www.sharkclean.com/manual/EP965-instruction_book_0701A.pdf
Euro Pro EP965 Use And Care Instructions Manual
Euro Pro EP965 Carpet Cleaner User Manual
Questions Answers for euro pro steam cleaner iron
May 29, 2016 | Euro-Pro Irons
The green light does not come on and it does not steam
follow this adjustment and fix it. God bless you
Clean an iron:
  1. Unplug the iron and make sure it is cool before cleaning.
  2. Use a toothpick or pipe cleaner to remove buildup in the steam vents, making sure the debris doesn't fall into the vents.
  3. Use a fine sewing needle to carefully clean the spray nozzle of mineral deposits.
  4. To flush sediment from a steam iron, pour 1/2 cup water and 1/2 cup vinegar into the water tank. Place the iron on a rack over a broiling pan and set the iron to steam until the tank runs dry. Repeat if necessary. Or follow the instructions for using a commercial iron cleaner.
Service the steam and spray mechanism:
  1. Unplug the iron.
  2. Use a fine sewing needle to unclog the steam valve assembly. Also, check the valve spring and replace it if it is broken or has lost tension.
  3. If the spray pump is accessible, remove it and check for leaks by placing the spray tube in wa
Nov 04, 2013 | Oreck Steam-It Steam Wand
GC7320 : my appliance has been well rinsed out, but is unable to produce steam when it starts to 'pump'. What should I do, please?
see the instruction and fix it. God bless you
Clean an iron:
Jul 29, 2013 | Irons
Domotec digital steam press not heating up
This could be several things. There are thermal fuses, a thermostat, the coils, the safety switch or the controls.. You need to take it apart to check these things with a voltage/ohm meter.
Dear sir or madam, I am writing to you on behalf of a customer, i am based in a domestic appliance shop called 'Vac Attack'. Although we mainly focus on vacumm cleaners, we had a customer bring in a...
It sounds like the problem is related to the impeller. Vaporizing water, even if it has been distilled, will eventually leave behind it's minerals and deposit it where ever the vapor is allowed to dry. I think if you disassemble the unit and clean it, then lubricate the rotating parts with a silicone based gel then it should likely operate.
Mar 19, 2011 | Rowenta Commercial Garment Steamer - White
Can I get instructions on how to use Steam Press SF680 please?
You can download the complete instruction manual in PDF format by clicking this link.
  • You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa.
Apr 08, 2010 | Hamilton Beach Steam Excel 14770 Iron
Where can I get a new filter for my Domotec steam iron. I bought it from John Lewis but they no longer sell them and werent interested. Thank you
I've got one as well and I'm resigned to keep using it until it just clogs up. I use Britax filtered water in it. I had a Simac Stirella that just jammed open and the repair cost was more than the Domotec! Next time I'll buy a well-known make, but definitely not from John Lewis! Their after sales care on these products is appalling
Jan 03, 2010 | Irons
Just a few months old and stopped steaming, steams frowater entry
I have taken one of these completely apart and found it is glued together except for the platinum plate on the bottom. It is held on by circular lock clips and will break w/o proper tool. I see no way to repair these and the cost of sending in will probably be as expensive as a new one. I have seen them at Lowes and TuesdayMorning for about $100.00. Have tried to get a repair manual from Rowenta-good luck!
Nov 15, 2008 | Rowenta DZ9080 Iron with Auto Shut-off
Europro steam cleaner with iron
Hello Margoi,
Unfortunatly I can not help you with instruction, but from user reviews I know that it has exactly 1 liter capacity.
regards,
Konstantin
Aug 06, 2008 | Euro-Pro Steam Generator EP8001 Iron
Irons Logo
140 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
