Question about Coleman Heating & Cooling
Breaker box is heating up - Coleman Heating & Cooling
  • 69 Answers
You are overloading the circuits. eliminate other loads when using heaters or run dedicated circuits for heaters
Posted on Nov 23, 2013
I HAVE A 2 1/2 TON PACKAGE HEAT PUMP . THE60 AMP BREAKER AT THE DISCONNECT BOX KEPT TRIPPING . I DISCONNECTED THE HEAT STRIPS AND NOW THE 60 AMP BREAKER ISNT TRIPPING . WHAT IS CAUSING MY BREAKER TO T
You need to check the current rating of your heat strips. If it is more than 60 amps then you need a bigger breaker. If 60 amps or less then your heat strips are going bad. Also make sure your fan turns smoothly without any wobble.
Jan 06, 2014 | Electrical Supplies
My oven will not heat
From your description it could be that the heating element(s) shorted and failed. It is likely that one (or both?) will have to be replaced
Mar 27, 2013 | Kitchen Ranges
My dryer wont heat up and i was wondering if it is the lightbulb that heats up the dryer
No it is not the light bulb that heats it. It has an element inside that heats up. Before anything you need to go to your breaker box and find the breaker marked dryer and reset both sides of the breaker. What I mean by this is the breaker box that is for the power coming in to your house. It is in this panel that the breakers are for the power in your house. The dryer breaker is a double 110 volt making it a 220 volt breaker .So both of the 110 volt switches need to be reset.
Also make sure you are on a cycle on the dryer that requires heat. Try the setting that has the numbers for the amount of time you want to run it for set it to 45 minutes and leave it for five minutes and then open the dryer and see if there is any heat. If there is no heat we may have to call the repair man to come over and look at it . If it does work then your in luck so please remember to click on the yes box on you way off the web site. Thanks and Good Luck!
Oct 10, 2010 | Kenmore Dryers
Dryer will not heat up.......... Clearered lint path but still no heat...... Troubleshooting mentions a curcuitbreaker...... Where is it located? Do you have any other ideas? Please respond ASAP...
The circuit breaker that they are talking about is the breaker box in your house. This is where your breakers are for the whole house(the fuse box) The breaker for the dryere should be listed on a list most likely on the inside of the door to the panel.You can check the list to see what number the dryer is on and then find it in the breakers. It is a double switch breaker because the dryer runs on 220 volts not 110 volt. The reason for this is the heating element that is in the dryer requires more power. Resetg both of the switches assigned to the dryer as they will be side by side ,Each one of those is a 110 volt breaker.after reseting them close the panel and go back and check the dryer. If it works be sure to click on the yes box on the site here so we know we helped you out. Thanks for your time and good luck...bye for now
Oct 10, 2010 | GE Profile Harmony DPGT750GC Gas Dryer
Barrel of dryer turns but no heat
Your heating element needs to be replaced, or the 240 breaker in your breaker box has tripped. I was a maytag technician for several years...So, check your breaker box for any tripped breakers or the heating element in the dryer needs to be replaced, or the t.stat for the element has blown.
Apr 26, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Stove top or oven doesn't heats. range type is a accubake system
Have you check the outlet to see if its geting power, if not, check the main breaker in the breaker box, you may have to turn the breaker to the off postion and then back to the on postion, if power is going to the outlet your stove should work.
Feb 12, 2010 | Kitchen Ranges
Dryer will run, but not heat
hi!! your circuit breaker should be located outside your home or inside.if you go outside your home and check where the main wires go into your home you should find a box.Open the box and see the one breaker that says dryer make sure it says on..If it"s on the my friend you have a heating element problem your heating element on the dryer has fail..In electrict dryers 90% percent is the heating element failure..
Jan 03, 2009 | Dryers
Mr slim unit
Let me try to send you to a quick fast electrical course on wiring size vrs amp draw it can carry before it burns into. The breaker box can send out the rated amps the wire comming into the box its sized for. (example. #3 can carry 10 amps) then it is distributed thru breaker thru the wires to the loads amp draw. depends on the maxium rated amp draw of the load, the wire can carry a certain amount of heat or amps. Ceck the max. rated amps or heat draw it can carry to size your wires & breaker,! thank you very much!
Dec 11, 2008 | Heating & Cooling
MYELECTRICDRYERISNOTHEATINUP
Your dryer may not be heating because the electric elements have gone bad on your unit. Replacement is easy enough although purchasing the element box may be costly. First check your breaker box to see if it has tripped the breaker, on occasion only half the breaker will flip so that the dryer will run but not heat up. Flip the breaker all the way off then back on and see if that helps, if not get ready to purchase elements.
Sep 28, 2008 | Dryers
Heater element will not heat drum.
if it's turning and not heating, chances are that it could be a broken heating element or it's not getting the full power. before taking the dryer apart, go to the breaker box that supplies power to it and pull the breakers completely off and then on. if that doesn't work, you could have a bad breaker or a bad heating element. if one of the breakers seems kind of loose or wiggles easily it needs changing anyway.
May 01, 2008 | Dryers
Heating & Cooling Logo
Top Coleman Heating & Cooling Experts
Bill Long
paulcarew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
