SOURCE: How do I disable the seatbelt chime on an '89 VW?
look at the buckle and see if there are two wires going into it. if there is cut those and wire them together. or you can try and follow those wires back until you hit a fuze or something. alot of times though that fuse is shared with something else silly like a dome light or radio though
SOURCE: Is there a fuse to pull to stop the seatbelt chime?
Pulling the fuse is not an option.Check your owners manual for instructions on how to shut it off..
SOURCE: Drivers side seatbelt connected When truck is
sensor in the seat belt bukle needs to be replaced
SOURCE: seatbelt chime
There is a switch in the buckle that senses when it is fastened. This might be stuck or the sensor that tells if the seat is occupied is bad.
SOURCE: Ssangyong Korando 2.9tdi
If the engine cannot turn by hand with the cam removed then it is a problem on the crankshaft or con rods. It could also be water on top of the pistons that cannot compress. Remove the injectors and see if the engine will turn a full circle. if water comes out remove the head and check the gasket or head for cracks. Please reply if it is a single or dual cam.
Testimonial: "The engine can turn with the cam removed !! but once the cam shaft is on and the align and on OT the enigine turns a bit and then it is stuck but if I remove the cam shaft I can turn it with no problems. And it is a single cam and no water or any thing is coming out"
