Question about Saeco Odea Go
Steamer Leaks Hi, I have a problem with my steamer in Odea Go 2, the problem is that the small rubber oring, seal gets old, i cant find part number just for that rubber, maybe someone of you knows where can i get that http://sv057.sendspace.pl/pic/cac4ed0d29159912869d08d/1100x1100 Thanks
    Problem Solver:
  • 15 Answers
Maybe you can try your local car parts shop. You should find one that fits just right.
Most probably that it uses an oring from a car.
Posted on Nov 22, 2013
JohnnyBeans
  • 223 Answers
SOURCE: Steamer does not work
Your steam wand is probably clogged with milk. Remove the panarello outside and stick a paper clip up the tube. Then try to run water out of the steam wand.
Hope this helps!
johnny
Posted on Oct 12, 2007
mirran
  • 515 Answers
SOURCE: Water hissing at back of brew unit after coffee made
I think you have to replace the steam valve.
Have you descale your machine regulary?
How old is your machine?
Maybe your boiler have to be replaced:-(
Posted on Jul 26, 2008
  • 3 Answers
SOURCE: saeco odea steamer is leaking
This is a known issue with the Odea GO. You need to take it in for servicing to get the rubber seals changed. This happened with our maching after about 6 months.
Posted on Mar 09, 2009
  • 80 Answers
SOURCE: My Saeco Odea Go always seemed very noisy?
maybe pump make noise,check holder of pump,or replace pump
Posted on Aug 29, 2009
  • 3 Answers
SOURCE: Saeco Aroma Problems
Whenever we had this problem we needed to prime the pump. Turn the machine on and wait for the coffee light to come on. Then push the coffee button and turn the steamer on wide open until water comes through the coffee outlet. I hope that helps. The user manual can be downloaded from the saeco site.
Posted on Jan 02, 2010
Hot water steamer does not work properly
Any coffee maker, espresso machine related sales-support issues you can always get in touch with www.De-Brewerz.com
Dec 15, 2013 | Saeco Odea Giro Plus Coffee Maker
Water leaks around the steamer
May be. If you get the machine upside down (switched off) you will find a hole near the steam knob which allows access to a screw. Turn this screw with a flat bladed screwdriver and the knob will come off. There is a gasket (washer) near the end of this know which is the seal. I don't know where you get the seal, but try finding a rubber seal in a gasket kit. This may be the problem.
Nov 25, 2013 | FrancisFrancis! X1 - Stainless Steel...
After using steamer for milk frothing the red light comes on and cannot get esspresso to brew and no more steam or hot water comes out of the frothing nozzle, the water level is fine in reservior, beans in...
The tap valve is leaking inside the machine needs new seals.If moisture is escaped and hit the printed circuit card on the tap, the machine will stop you from doing other functions.
Feb 05, 2010 | Saeco Odea-Giro Espresso Machine
Aug 29, 2009 | Saeco Odea Go
Conair steamer leaks water and wets my clothes.
When I use mine I hang the hand held part from my closet door, while I am waiting for it to heat up. When the hose gets too much condensation, from the steam, it leaks out... This will also happen if you try to use in the motion of an iron. The hand held part needs to be at a vertical position at all time to prevent leaking.
Jan 24, 2009 | Conair Compact Garment Steamer Iron
Jul 25, 2008 | Saeco Incanto Classic Espresso Machine
Saeco odea steamer is leaking
May 10, 2008 | Saeco Odea Go
Krups FND1 water escape
What position do you have the knob in? According to your manul it should be in position 9 not in position 8 for steaming.Good Luck.
Apr 11, 2008 | Coffee Makers & Espresso Machines
Heats up and produces steam but the release button does not open the flow of steam.
To remedy this, I did the following:
1) Removed screws from: a) Lower area of handle (1 screw), b) Top of steamer, under round rubber flap around fill hole (2 screws), c) Front of steamer where nozzles attach (2 screws)
2) Removed back of handle, top of steamer, front of steamer where nozzles attach
3) Once all parts are removed, you can see a brass button that is pushed by the trigger
4) Using a needle-nose pliers, grasp and rotate the button several times in both directions (you may hear it cranking against the interior spring). Do this until it turns fairly easily with the pliers.
5) Once this is done, you fill find that the brass button can be very slightly depressed with a bit of force. You may also need/want to unfold a large paper clip to push into the nozzle hole to help unsticking the brass button (not sure if that helped in my case, but it was something I tried along the way). When the brass button moves in and out (again, it won't move much), the steam release mechanism is unstuck!
6) Reassemble all parts (everything snaps back neatly into place).
This worked for my unit!
Nov 11, 2007 | Scunci 52067 Handheld Steam Vacuum
Saeco Odea Go Logo
49 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
