Question about Dell 922 All-In-One InkJet Printer
Dell 922 aio carrier stall
Its been days now and my aio hasn't worked. I've tried to get to the black in cartridge that I must have installed wrong but the carraige is trapped under the printer housing so I can't get it out.
  • 3 more comments
  • Gary Z. Oct 27, 2007
    I got the carraige out and replaced with the correct ink cartridge but get the message carrier stall error 1200 check for obstructions - there is nothing impeeding the carrier but it won't print!
  • Gary Z. Oct 29, 2007
    I still get the message - print carrier stall -.  I don't want to buy a new printer but its been weeks now!
  • Gary Z. Oct 30, 2007
    The cartridge is free now and it slams to right when I turn it on but I get the same error message.
    I wiped it the best I could but it didn't help.
    I'm still trying!
    Scholar:
  • 121 Answers
Can you cheat the top so that it thinks you have everything closed?  You're going to want to watch the carriage try to come out.  There's usually a tab on the door/lid that tells the printer you have shut it.  If you stick something in where the tab pokes into the machine, you'll cheat it.
Anyway, once you cheat it, turn the machine on and you can see what's stopping it.
Unless it never moves away from the cleaning section at all.  In that case, it might have locked itself into that position.  You might have to look for gears that you can turn to pull the cleaning section away from your printheads.
Erice
Posted on Oct 30, 2007
  • Eric Engel Oct 30, 2007
    Try this -
    Open the printer and see if you can look along where the carriage moves back and forth. There should be what looks like a clear plastic strip or 'mylar' behind it that runs along the length of the printer.
    This mylar has tiny lines in it (too small for us to see.) The carriage contains a sensor that looks through the mylar (the mylar is called an encoder strip) to find out where it is. If you can see the encoder strip, wipe it with a slightly damp rag.  Be careful not to bend or kink it.  If it is warped, it is probably shot.
    Then move the carriage all the way to the other side and wipe what you couldn't get at.
    Thankyou,
    Erice
What is error #2200
The 2200 error message indicates a scanner stall or jam. The steps below will help you to resolve the issue and clear the error message.
Printer Reset
1 Power off the All-In-One (AIO) and remove the power supply from the back of the unit. Wait 30 seconds. Then reinsert the power supply and power the AIO on.
Did the error message return?
Yes: Continue to step 2.
No: Attempt a test scan. If the error message does not reappear, the error is resolved.
2 Power off the AIO and remove the power supply from the back of the unit. Open the scanner cover. Check the scanner glass for cracks and the scanner casing for cracks. Close the scanner lid. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove both cartridges, close the top cover, reinsert the power supply, and power the AIO on.
Yes: contact Dell.
No: Continue to step 3.
3 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Insert the color cartridge, close the top cover, reinsert the power supply, and power on the AIO.
Yes: Repeat step 3 with another color cartridge. If the printer fails again, continue to step 4.
No: Repeat step 3 and install the black/photo cartridge. If both cartridges are installed, attempt a test scan. If the error message does not reappear, the error is resolved.
4 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove the color cartridge and insert the black/photo cartridge. Then close the top cover, reinsert the power supply, and power the AIO on.
Yes: Repeat step 4 with another black/photo cartridge. If the printer fails again, contact Dell.
No: Install the color cartridge. If the printer fails, contact Dell. If the error message does not appear with both cartridges installed, attempt a test scan. If the error message does not reappear, the error is resolved.
Mar 23, 2010 | Dell 962 Photo All-In-One InkJet Printer
Dell 922 print carrier stall error message. Also, error 1200.
Hi
hope it will work
Error code: 1200
This error code is commonly associated with the Dell 922 printer. Usually you might see the cartridge moving front and back and slamming itself against the printer. You need to tighten the strings located on the back of the printer and then it should work fine
Clean the carriage rail. This is the round chrome piece that the carriage assy that holds the cartridges rides on. Use a paper towel that is slightly moist.
Be sure to not force anything. Unplug the printer after you get the carts in the middle. Move them to one side and clean and then move them to the other and repeat.
Lift up the scanner to reveal the cartridge compartment; under the chrome rod on which the cartridges run there are two small gaps about 8cm apart. In the right one should sit the paper sensor which is a small black rod that hooks downwards; the problem I had was my sensor had bent up and out of the gap so all I had to do was bend it gently back into position using a small screwdriver.
Hope you get it to go.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Nov 18, 2009 | Dell 922 All-In-One InkJet Printer
I get the error 2200 message everytime I try to send a fax
Hello there:
this is a scanner stall or jam. The steps below will help you to resolve the issue and clear the error message2.gif.
Printer Reset
NOTE: The embedded links in the table lead to specific troubleshooting documents.
StepAction1
No: Attempt a test scan. If the error message does not reappear, the error is resolved.2
Power off the AIO and remove the power supply from the back of theunit. Open the scanner cover. Check the scanner glass for cracks andthe scanner casing for cracks. Close the scanner lid. Open the topcover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove both cartridges, close the top cover, reinsert the power supply, and power the AIO on.
Yes: Continue to Contacting Lexmark.
No: Continue to step 3.3
Power off the AIO and remove the power supply from the back of theunit. Open the top cover of the AIO. Using the carrier belt, move thecartridge carrier to the middle of the unit. Insert the colorcartridge, close the top cover, reinsert the power supply, and power onthe AIO.
Yes: Repeat step 3 with another color cartridge. If the printer2.gif fails again, continue to step 4.
No: Repeat step 3and install the black/photo cartridge. If both cartridges areinstalled, attempt a test scan. If the error message does not reappear,the error is resolved.4
Power off the AIO and remove the power supply from the back of theunit. Open the top cover of the AIO. Using the carrier belt, move thecartridge carrier to the middle of the unit. Remove the color cartridgeand insert the black/photo cartridge. Then close the top cover,reinsert the power supply, and power the AIO on.
Yes: Repeat step 4 with another black/photo cartridge. If the printer fails again, continue to Contacting Lexmark.
No: Install the color cartridge. If the printer fails, continue to Contacting Lexmark.If the error message does not appear with both cartridges installed,attempt a test scan. If the error message does not reappear, the erroris resolved.
Nov 10, 2009 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Dell AIO 942 Error 2200
I would recommend cleaning off the contacts where the cartridge is loaded as well as the any other spots to see if maybe there is just something on the contacts.
Sep 19, 2009 | Dell 942 All-In-One InkJet Printer
Dell AIO 922 printer not seeing the color cardridge
" Unplug the printer cable from the computer.
" Unistall the printer drivers from Device manager and also unistall the all the printer appications
" restart the computer
" Click here and slecet the operating system and download the drive
" after installing drivers and software it will ask you to connect the printer.
" then you can connect the printer and and try to Print the test page.
Jun 17, 2009 | Dell 922 All-In-One InkJet Printer
How to change ink cartridge in dell 922 all in one printer
Here is a link for the user manual in PDF for your printer:
922 AIO Manual
Replacement of cartridges begins on page 44 of the manual.
Thanks for using Fixya.
Apr 22, 2009 | Dell 922 All-In-One InkJet Printer
Printer Always Indicates Ink is Low or Cartridge is Incorrect
To get rid of the low ink warnings google the specific error message with 'ink refill' and look for 'engineers reset' or similar ..
NB. Dell printers (re-badged Lexmarks) are notorious for ink usage and high costs .. so my best recommendation would be to throw it away and purchase something else ..
Nov 30, 2008 | Dell 922 All-In-One InkJet Printer
Dell 922 All In One Printer cartridge carrier jammed
unplug and plug back in this should reset printer so carrige will move
Dec 05, 2007 | Dell 922 All-In-One InkJet Printer
Dell A940 All In One Printer
mine was a lil bit crooked and it has to be straight
just by where the cartridge area on the back is i straightened it out and wala
"Carrier stall" Error and the Carrier Slams in the Printer I
If the printer carrier is slamming into the side of the printer, please try the following:
  1. Disconnect the power supply from the back of the printer.
  2. Open the front cover of the printer where the cartridges are located.
  3. Look for two black bands that span from left to right (they should have one serrated side and one smooth side). Just above the black bands there is a transparent strip; this strip is called the Encoder strip.
  4. Flick this strip lightly with your finger to make sure that it is running smoothly from left to right. You may need to do this two or three times. CAUTION: Do not pull the strip!
  5. Close the front cover of the printer and reconnect the power supply.
Oct 27, 2007 | Dell A940 All-In-One InkJet Printer
Dell 922 All-In-One InkJet Printer Logo
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
