Mitsubishi tv cs-2611r tv antenna mode
Mitsubishi tv cs-2611r i need it in tv mode vs cable mode. no remote
SOURCE: Need help changing from antenna to cable without a remote
have cable attached to the TV. But, I lost my remote so I cannot change the TV setting from "antenna" to "cable." There is no menu selection on the TV itself. Is there any way to do this?
Posted on Aug 08, 2008
  • 121 Answers
SOURCE: I have a Mitsubishi tv
codes come with remote.
Posted on Dec 06, 2008
SOURCE: Universal Code for Mitsubishi CS-26201TV
After searching the web for hours this is the one that worked for me , if you have the same remote i have it should work for you too.
Code # 10150
Posted on Dec 21, 2008
  • 12 Answers
SOURCE: I somehow deleted channels off
call your tv network and ask them to help you
Posted on Dec 26, 2008
SOURCE: How to change from video mode to cable/Antenna Input without a Remote
Use the menu option on the tvs front control panel. This should allow access to your video sources.
Posted on Jan 26, 2009
Mitsubishi CS-31205 TV Never had a remote for this great TV, but, accidentally pushed a button on my Comcast Cable remote and the TV is now in "Mute" mode. Not the Comcast box 'Mute' . Have...
You are supposed to be able to switch the Comcast Remote to TV mode and switch Mute on that remote to change back to standard volume. If that doesn't work try volume up on the TV. Otherwise if neither of those work then check Remotes.com for a replacement TV Remote.
Mar 09, 2011 | Televison & Video
Tip
Mitsubishi parental lock removal/v-lock redo
Models:
Color Televisions
CS-20EX1, CS-20301, CS-26EX1, CS-26201, CS-26301, CS-2725R, CS-27EX1,
CS-27MX1, CS-27TX1, CS-27200, CS-27201, CS-27301, CK-27304, CK-27306,
CS-27401, CS-27403, CS-3135R, CK-3136R, CS-31AX1, CS-31FX1, CS-31MX1,
CK-31MX2, CS-31301, CK-31302, CS-3525R, CK-3526R, CK-3527R, CS-3535R,
CK-3536R, CS-35X7, CS-35AX1, CS-35FX1, CK-35FX2, CS-35MX1, CK-35MX2,
CK-35MX3, CS-35201, CS-35201A, CS-35203, CS-35205A, CS-35301, CS-35401,
CK-35402, CS-40FX1
Projection Televisions
VS-40VA2, VS-4517S, VS-45VA1, VS-45VA2, VS-4561, VS-4562, VS-5016R,
VS-5017S, VS-50VA1, VS-50VA2, VS-50VF1, VS-50VF2, VS-50VX2, VS-50VX3,
VS-5061, VS-5062, VS-6017R, VS-6026R, VS-60VA2, VS-60VF1, VS-60VF2,
VS-60VX2, VS-60VX3, VS-6061, VS-7017R
This system locks only the entire TV. The TV will display a screen that
will indicate "Parental Lock ... Now the lock is on" and request the
personal four digit code when the TV is powered on.
IMPORTANT> You must use the original remote control that came with the
TV to release the Parental Lock, you cannot use a remote
that came with a VCR, Audio System or from any other
manufacturer.
1. Depending on which remote came with your TV, press the button at
the top labeled TV,OR set the TV/VCR switch in the upper left
corner of the remote to the TV position. .
2. Press the button on the remote labeled POWER.
The TV will turn on and display an information
screen that indicates "Parental Lock ... Now the
lock is on" and ask for the four digit personal code.
3. Press the #9 and the QV buttons at the same time.
The TV will turn on.
4. Press the button labeled MENU.
The "TV Main Menu" will be displayed.
5. Press the ADJUST UP or DOWN button to move the arrow next to the
"Advanced Features" selection and then press ENTER.
The "Advanced Features" menu will appear and
indicate that the lock is ON.
6. Press the ADJUST button to move the arrow next to the "Parental
Lock" option, and then press ENTER.
The screen will change to indicate "Parental Lock
... Now the lock is on" and ask for the four digit
personal code.
7. Press the #9 and QV buttons at the same time.
The screen will return to the "Advanced Features"
menu and indicate that the lock is off.
8. Press the MENU button twice to return to normal viewing.
The original lock code has now been erased and the lock canceled.
on May 16, 2010 | Audio Players & Recorders
Just bought a mitsubishi 40503 dont have manual cant get my cable hooked up
check if the plug if your cable is fit for the antenna in of your tv.if ok then hook it up and do the manual/auto search of channels.
Mar 28, 2009 | Mitsubishi CS-40503 TV
Mitsubisi tv CS- 40307 digital capable ?
If you are subscribing to cable or satellite TV, then the answer is no; they will continue to send an analog signal to your TV. However if you are using an antenna to receive your broadcast, then you will need a converter. Broadcast TV (over the air) has switched to a digital signal for most of the channels as of June 12th.
Feb 22, 2009 | Mitsubishi CS-40307 40" TV
Mitsubishi vs5003r troubleshoot
I found this in another website... i hope this can help you. I'll try too...
Found this on the web, hope it helps.
Thank you for contacting Mitsubishi Digital Electronics America, Inc. We
are pleased to be able to assist our customers via our website. Here is the
information that you have requested:
TV Lock #8
Models:
Color Televisions
CK-35402, CS-40FX1
manufacturer.
personal code.
Oct 26, 2008 | Televison & Video
Black box in middle of screen
If you have a menu button on the front of your tv go into the closed caption portion and turn off the text mode . This will get your picture back . If you don't have a menu button on the front of your tv you will need a remote that can access the menu . Good luck
Feb 29, 2008 | Mitsubishi CS-35405 TV
MITSUBISHI vs-7083
What is your source? Antenna, cable, or satellite?
accordianman
Feb 22, 2008 | Mitsubishi VS-7083 70" Rear Projection...
Mitsubishi vs-45609
You should have two antenna inputs A & B. Most commonly the RF or TV output on the back of the cable box is connected to antenna A and the TV has to be set for channel 3 or 4 depending on which station is not available in your area. If you don't get a picture on 3 or 4 then switch the cable box to antenna B or find the switch on the remote that allows you to remotly switch antenna inputs. If your TV has a connection that says "cable out" don't use that one as that is for a more complex setup. I hope this helps you.
May 02, 2007 | Mitsubishi VS-45609 TV
Televison & Video Logo
18 people viewed this question
Top Televison & Video Experts
Electro Med Services...
