Question about Intel DH55TC Motherboard
Bios manual - Intel DH55TC Motherboard
Need the bios setting for a Radisys Endura EM945G Motherboard
http://www.easyhelpguide.com/manual/Radisys-EnduraEM945GMotherboardDDR2400MHz-Manual.html You can go to their web site to get bios updates and the installation program to flash the bios. If all you want to do is reset the bios, just remove the coin cell battery for more than 5 minutes. Put it back in and reboot. This will NOT reset a windows password.
Sep 01, 2016 | Boating
Bios password?
Read the manual from your manufacturer's website on how to reset the bios password.
Get online and got to www.google.com In the google search box type: "Acer Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operating system when requested. Look for manuals and search them for Bios Password or Bios Password Reset.
May 31, 2012 | Computers & Internet
Reset bios motherboard
RTM - Read The Manual.
Get onlineand got to www.google.com In the google search box type: "FujitsuSupport" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Look for Manuals. Search the manual for bios or bios password.
Apr 28, 2012 | Fujitsu AMILO D-7820 Notebook
I want to get in the bios to change the setting to boot from disk platform windows 7
  • Shut down your computer. Check your computer manual for the key stroke to get into your BIOS. Typically it is your "F1" or "F2" key.
  • Restart your computer.
  • Press the BIOS key that was indicated in your computer manual. Continue to press the key until the computer enters your BIOS.
  • Once entered in bios look for boot option and set primary boot device.
    Then restart your system
    Feb 20, 2011 | Acer Computers & Internet
    Cannot open bios set up forgot bios password
    Reset the motherboard BIOS. To do this:
    1. Open your computer casing where the motherboard lies in.
    2. Look for the BIOS jumper settings. It should be near the battery.
    3. And there reset the bios settings. (To do this, refer to your motherboard manual.)
    4. Once already done. Close the casing and power up your computer.
    See how it works.:-)
    Nov 03, 2009 | Intel D850MV Motherboard
    I want manual and bios of Asus motherboard model
    Here's the link to the driver and bios updates. Hope it helps you.
    http://bios-and-system-update.free-driver-download.com/ASUS/12467/ASUS-Mainboard-P4PE-BP-BIOS-1007.html
    Mar 29, 2009 | ASUS P4PE-BP Motherboard
    I want to update my bios, Ausus- P5N73-AM motherboard, plzzz help!!!!!
    Check what bios version is on the board now, then look at the bios updates at Asus. There are mostly
    two reasons too update a bios. Upgrading cpu, a newer cup that was not listed when the board came out will have a bios update for the newer cpu. A specific problem that is listed with the update that you have the same problem. If you do not fall into one of these areas,then you should not update the bios,and if you read your manual it will tell you not too.
    So you figured out you need too, go to Asus and download the bios update,then put it onto a flash drive,
    with the pc off,plug in the flash drive and start the pc, the bios post should show the drive in menu
    with your other drives. Enter the bios,usally it is holding the del key, go to tools and then bios flash.
    When you get your bios update download the manual,then print the page with this info on it, follow the manual as you do this, DO NOT do it without it,if you mess it up there will be problems. It is easy if you walk through it with the manual as the same time you are doing it. This board might have an easy flash
    that can be done while running windows, MANUAL,, read it. The best way is flash while in bios but easy flash also works. Do not just read what I said and try it,please follow the manual as you go along,it will save you a lot of problems in the long run. Asus has a great site,with everything you need and they work hard at updating the drivers for new operating systems. Asus is the best motherboard on the market.
    Mar 21, 2009 | Intel DG31PR Motherboard
    ASRock P4I65G motherboard
    The manual is here:
    http://www.asrock.com/manual/P4I65G.pdf
    See page 20 for the Clear CMOS jumpers..
    a bios virus is a very rare animal.
    Oct 14, 2007 | Computers & Internet
    Bios settings
    ?manual? when you go into your BIOS at the bottom of all generic BOIS consoles, there are F1 - F12 options. one of these will be: restore to failsafe settings" and the other "optimized settings" the rest you can tweak manually. as far as a manual goes you must be referring to the motherboards manual, and it only touches on BIOS and CMOS settings. good luck.
    Sep 25, 2007 | Computers & Internet
    Corrupted BIOS chip
    That depends on your motherboard Manual. It should correspond to your BIOS. Download the Motherboard's BIOS file usually in a Zip then the contents are .bin files. Then use the BIOS manufacturer's EPRON Programming tool. Which usually comes with a user manual. Just follow its examples. Good luck!
    Sep 18, 2007 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
    Intel DH55TC Motherboard Logo
    13 people viewed this question
    Top Intel Computers & Internet Experts
    Tony
    David
    David
    vsri9
    Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
