Question about Hobart Ovens
Cn401 listed as 480volts will it operate on 240
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 30 Answers
No it will not
Posted on May 03, 2016
120v on bake element red wire and element wont heat up
the reason its not heating is because you will always have 120 volts on this red wire due to its being connected directly to one side of the in coming power source,its either that you lost the other 120 volts of power coming into the unit,a tripped breaker/fuse/etc. or the control board relay that supplies the other 120 volts to the element for a combined 240 volts needed to heat the element,if you have 240 volts to the connection to the unit then you either a bad control board or the Neutral incoming power wire could be burned off which you need to get 120 volts to operate the control board which operate the relay to supply the element with the required 240 volts to operate
Oct 27, 2012 | Jenn-Air JMW8530C Electric Double Oven
Oven wont heat, shuts down in few seconds
Sseem issue with the thermostatic.
Aug 30, 2008 | Ovens
What is the standard plug for stoves newhome el916. Is it the general 13A plug
I can't find an online manual for the model of the appliance you are talking about, so I'm unable to figure out the wattage it draws. Nor do I know where you are in the world and the voltage you are running at, so I can't tell you straight off. But I can tell you how to figure it out very easily:
I imagine that know what your main power supply voltage is (either 240 volt or 110 volt).
You can look at the appliance and there will be a data sticker with the wattage rating on it somewhere (or it will be in the install/Owner manual).
Now you have these 2 bits of information we can do a simple sum:
Watts divided by Volts = Amps
Therefore example calculations look like this:
If you have a 500 watt appliance on a 240 volt system 500/240 = 2.083 so use a 3 amp fuse
An appliance with a 750 watt motor on 240 volts: 750/240 = 3.12 so use a 5 amp fuse
A 2KW (2000 watt) appliance like a hot air blower on a 240 volt system: 2000/240 = 8.33 amps so use a 10 amp (or more commonly 13 amp) fuse
A 500 watt motor on a 110 volt supply 500/110 = 4.5 so use a 5 amp fuse
A 1KW (1000 Watt) appliance at 110 volts: 1000/110 = 9.09 amps so use a 10 amp (or more commonly 13 amp) fuse
etc etc etc.....
If the sum comes out below 13 amps, you can use a 13 amp plug. If it doesn't you need to hardwire it into a proper cooker supply.
Jul 29, 2011 | Stoves Ovens
There's no heat from my Westinghouse Oven(pol662s). The grill, fan & light all operate correctly, just the oven. I'm guessing it's either a thermostat or element problem. If it's a...
One quick test would be to turn on the bake and shake the element a little. Sometimes the connection burns loose and by shaking the element you may breefly make connection and there would be a little heat. If that does not work you would have to take the element out and check continuity. (Turn the power off!) Next you need to trace the wiring. If you have an old mechanical thermostat you could have a burnt terminal. I forgot, first make sure you have 240 Volt going to the oven. Fans, clocks, lights will work on 120 V. but elements need 240 V.
May 10, 2011 | Ovens
How do I know if my Hotpoint oven 920 years old0 is on a 220 0r 120 line? The serial plate says 120/220.
An oven uses both 120 & 220 -- actually it would be 120 volts and 240 volts or nominally, 110 volt and 220 volt.
The 120 is used for the lights. The 240 is used for the heating elements.
A 240 volt breaker (nominally 220 volt) -- supplies both 120 and 240 volts depending on how the supply is connected to the appliance.
There will be a 240 volt (nominally 220 volt) breaker in the main panel for the oven. This is two 120 volt breakers side-by-side with their toggle switches connected together with a strap across the top of the toggles.
Charlie
Jan 11, 2011 | Hotpoint Ovens
How do I remove the built in oven to replace the
there are no internal fuses, chk your houses main power panel and stove plug to make sure you have 240 volts for proper unit operation
Nov 03, 2009 | KitchenAid KEBC107 Electric Single Oven
New oven, new installation. power at wall outlet, no power at ove
Open wire...either ground or neutral.
Lights are 110volt...and possibly there is a disabling feature due to open wire, as stated above, not allowing oven to operate.
When ground and/or neutral are provided all should work.
Feb 28, 2009 | Ovens
Is a kenmore wall oven model# 47789 120 or 240 volts
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Nov 16, 2008 | Kenmore 47782 / 47784 / 47789 Electric...
Wattage for oven pleb30s9fc
  • Connected Load (kW Rating) 240/208 Volts: 3.5/2.6
  • Amps @ 240/208 (Approx.): 14.6/12.6
  • Minimum Circuit Required - Amps: 30
  • Bake Element Wattage 240/208 Volts: 3400/2554
  • Broil Element Wattage 240/208 Volts: 2750/2065
  • Armored Electrical Cable
What kind of wires did you buy?
Jul 25, 2008 | Frigidaire PLEB30S9DC Electric Single Oven
Ovens Logo
Top Hobart Ovens Experts
Craig Butler
Craig Butler
Dan Webster
Dan Webster
Gil Shultz
Are you a Hobart Oven Expert? Answer questions, earn points and help others
