Home | Panasonic | DMR-E85H DVD Recorder | DVD Recorder frozen - p...
Panasonic DMR-E85H DVD Recorder
Problem for Panasonic DMR-E85H DVD Recorder
DVD Recorder frozen - please wait on display
By MrBrokeit on Oct 09, 2007
I was watching when screen went blank - it seems to have an interferance that comes about once a second - unit will not obey any commands - power button was pressed and held nothing happened - unit was unplugged and left deenergized for 24 hrs - plugged back in, and again please wait - I have accessed the power supply board, fuse good, no obvious visible signs of any capaciter failure -
Clarification Request
Posted by paul913 on Jun 20, 2009
I replaced the c1270 & c1271 capacitors and the c1271 cap blew when turning the power back on. Any idea what went wrong?
thanks,
Paul
Same Problem
May 17, 2009
-   First, I'll pile on with the hat tips to hiker_DC and RandyChev for help in repairing my DMR-E85H. Last year I replaced C1270 and C1271 when I saw that both capacitors had clearly failed, and the DVR worked fine after that.
Until last week. The unit froze up again with "Please Wait" on the display. I opened the case and inspected the power supply board, but I saw no visible problems with any of the components. However, I read the posting by hpwhite, who reported oozing from additional capacitors C1260, C1261, and C1272 on his unit. Those capacitors on my board appeared fine, but knowing nothing else to try, I took a chance and replaced them using hpwhite's product suggestions. To my relief, the DVR now works fine.
So it seems that several capacitors across this board tend to fail -- some more quickly than others -- and unhelpfully, not all of them show visible signs of failure. But hpwhite's experience was a real lifesaver for me. For anyone still haunted by "Please Wait" after replacing 1270 & 1271, replacing capacitors C1260, C1261, and C1272, even if they appear to be in good shape, is a good $5 gamble.
Thanks,
Clint
-   ctm999
May 12, 2009
-   My Panasonic DMR-E85H also had the frozen "Please Wait" problem. The local Panasonic authorized repair shop quoted me $160 plus parts. I found this site and followed the instructions regarding replacement of the C1270 and C1271 capacitors with Radio Shack 1000uF 35V radial-lead capacitors (model 272-1032) @ $1.59 each. Took about 30 minutes plus the time to get the parts. Works great now. Many thanks to everyone who posted these solutions and especially RandyChev for the great pictures. -   Guest
May 01, 2009
-   I have the same problem PLEASE WAIT on display..
I changed 3 faulty capacitors on the power supply but I'm still having the same problem. My DC voltage seems to jump up and down from 7 to 11 V
on the DC plug to the hard drive, i know it should stay at 12 V DC and 5 on the red wire.....any idea what could be causing this problem ??????
-   welbroche
Apr 17, 2009
-   My problem is solved with my DMR-E85H ( bad capacitors ).
Thanks to everyone on here, keep up the good work.
-   walte300
Feb 21, 2009
-   I had the same problem with the "please wait" message. After reading how many of you were able to fix this with no experience in soldering (same here) I got enough confidence to give it a try.
I read the directions from everyone (thanks for the pictures they were a definite help). I borrowed a soldering gun, bought the capicators (1000uhv, 35v) and desoldering braid (to remove the solder) from Radio Shack and watched about half a dozen youtube videos on soldering on a circuit board.
I did follow RandyChev's pictures and procedure. I did not have to remove all the periphals on the board, just the bracket holding the hard drive, the hard drive itself and the underlying bracket for the hard drive. I did remove the screw directly above the power supply on the back panel. I did remove the black connector (RandyChev's picture) from the circuit board below the hard drive. Then I slowly removed the circuit board.
I desoldered and then did a very poor but I assume effective solder job with the two new capicators. I set one straight up and the other on it's side similar to RandyChev's picture. I reconnected everything and then turned the machine on.
I got a message that an "error had occured" and to "change the disc" and then the dvd drive popped open. I reopened the machine and made one change. There are three things that connect to the hard drive, the power source, the black plastic prong connector and a thin strip of plastic with metal coating at the end that I think may actually connect to the black prong connector. Either way, I removed the thin strip and placed it back into where it connects but making sure I pushed it in as far as it could go.
Restarted, it came up "self check" and after a few minutes IT WORKED!!!. Thanks again for all the solutions and responses to this problem.
Can you really buy any hard drive and put it in the machine and have it work (ie is it really possible to replace the 120GB hard drive with one much bigger hard drive 320, 500, 750 GB drive)? -   Fred1776
Best Solution
posted on Sep 28, 2008
Very Helpful)
hpwhite
Rank: Apprentice
Rating: 100%, 5 votes
I actually had 5 bad oozing capacitors on my unit:
C1260 and C1261: Originally 680 microF, 10V - replaced with Radio Shack 1000 microF, 35V
C1270 and C1271: Originally 680 microF, 16V - replaced with Radio Shack 1000 microF, 35V
C1272: Originally 220 microF, 25V - replaced with Radio Shack 220 microF, 35V
Changed them all and now all is well!
Thanks!
Phil
Was this helpful?
Yes
No
4 people thought this was helpful
Solution #2
posted on Feb 05, 2008
Very Helpful)
miwu
Rank: Apprentice
Rating: 100%, 1 votes
I cant find C0270 and C0271 in the service manual and also I cant find 2 680uf capacitors under the hard drive too.
The Problem is that my DMR e85h not start up. No picture on TV screen, the only thing I see is a black screen . No reaction by pushing a button in the front.
The stripes in the display of the DMR e85h
(display look like : IIIIII 0:00 IIIIII )
are going up and down, step by step, nothing else. Pls help what can I do to get my Panasonic working again.
THX
Michael
Ps. Sorry for my bad english, I'am German......8x)
Was this helpful?
Yes
No
Solution #3
posted on Oct 29, 2007
Very Helpful)
hiker_DC
Rank: Apprentice
Rating: 99%, 29 votes
Two 680uF 16V capacitors where clearly leaking under the hard drive in mine.  I'm not sure I memorized it right, but I think they were C0270 and C0271.
I bought replacement capacitors at Radio Shack of better specs 1000uF and 35V for $1.59 each.
Took just under 2 hours to take it apart de-solder the two capacitors put the new ones and and put it all back together again. We worked slow. It wasn't hard, but if you have never done any soldering work and don't know someone to help you, I'm not sure you could do it alone.  Make sure you get the polarization correct too, but the board is clearly marked + and  -.
Was this helpful?
Yes
No
3 people thought this was helpful
Solution #4
posted on Sep 01, 2008
Very Helpful)
RandyChev
Rank: Apprentice
Rating: 98%, 44 votes
Just wanted to supplement DC's solution with photos for those who would like to see the project before attempting. For the record this fix worked perfectly and my unit is back to perfect working order with all my recordings intact.
Start by removing the top cover of the unit.
Working from the back of the unit you'll see the hard drive on the left.
Remove the two screws indicated by the red circles in the picture above. Then slide the cover plate forward and remove.
Two cables are connected to the hard drive. Left side is power and the black ribbon is the data connector. Both come off pretty easily. After removing cables lift out hard drive. Here's what you get.
Better view of cables after removing the drive. Remove plastic drive liner.
Remove the four screws indicated by the red circles in the picture above. Note the one at the top. (I missed this one for a few moments while putting it back together.) Remove drive mount.
Viola! You now see the burned out capacitors. Also circled are the four screw holes you just removed screws from and a cable that must be disconnected. (see next pic)
Gently pry up on the black plastic part of the cable mounted on the power board. You can see in this picture how I've just started to get it off a bit. You may have to pull on the latch in the center of the mounting. I did but I don't know if it was necessary.
On the back of the unit remove one screw just above the power plug. Then rock and twist and hold your tongue just right to get the power supply board out.
You'll see the capacitor numbers labeled on the circuit board on the front and...
on the back. Use a soldering gun to melt the solder on these four spots rocking the capacitors out of the holes as you do so. Just don't get solder over to any adjacent circuits.
You end up with nicely marked pos/neg info on the board.
Get your new capacitors from Radio Shack or other electronics store.
The ones suggested by DC are more heavy duty so they are bigger. I chose to lay them on their side so as to not raise the height of the board components. There is plenty of room to do so making my decision to do so a no brainer.
I leave the leads on the capacitors long until the capacitors are positioned and soldered in good shape.
Then clip the extra lead down to the solder with a wire cutter.
Thats it. reverse the directions to re-assemble the unit.
Hope the pictures helped. They always seem to help me prepare for such an adventure.
Was this helpful?
Yes
No
19 people thought this was helpful
Solution #5
posted on Feb 25, 2008
Very Helpful)
mpitt
Rank: Apprentice
Rating: 94%, 12 votes
I had the same exact problem. However, My failed capacitors were of the 10V variety and smaller than the 16V ones indicated by hiker-DC. The only difference was that my DMR display was also completely dead. Just replaced the bad capacitors this weekend and it is now working great.
Bad capacitors should be visually evident (leaky tops and swollen canisters).
Was this helpful?
Yes
No
Solution #6
posted on Apr 19, 2008
Very Helpful)
stashu
Rank: Apprentice
Rating: 96%, 8 votes
Correction: C1270 and C1271
Was this helpful?
Yes
No
Solution #7
posted on Nov 01, 2008
Helpful)
cc_r
Rank: Apprentice
Rating: 93%, 3 votes
Thanks so much RandyChev for posting the detailed pictures and hiker_DC for the initial fix. I just followed the instructions to fix my long dead unit (gathering dust for months while I decided what to do to it). I decided that even though I've never soldered before in my life, it couldn't get any more broken than it was.
I went to Radio Shack and bought the capacitors and soldering equipment. It was a slow night and I think the guys were bored, so I talked them in to soldering it for me. Got it back home and put it back together and it works!!!! Very cool. Thanks again.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #8
posted on Jun 20, 2008
Helpful)
jstelmac
Rank: Apprentice
Rating: 92%, 2 votes
Cool. Mine's stuck in 'Please Wait'. Blew out the dust, removed/reconnected various cables....this and that and no avail. Please Wait. Did some snooping on the internet, found this post re capacitors 1270/1271, took off my drive and yepper, they are bulging. Will try replacing them tomorrow. Very nice, thanks for the suggestion!
Was this helpful?
Yes
No
Solution #9
posted on Jun 07, 2008
Helpful)
bro_silo
Rank: Apprentice
Rating: 90%, 3 votes
One more round of applause for hiker_DC.
Panasonic Tech Support says the "PLEASE WAIT" means the E85H is too sick to get to SELF-CHECK. Per hiker_DC's note, I replaced the bulging/ splitting/leaking C1270 and C1271 capacitors on the circuit board under the hard drive and "Voila!". Everything works.
Thanks!
Was this helpful?
Yes
No
Solution #10
posted on Dec 15, 2007
Helpful)
esmith591
Rank: Apprentice
Just wanted to say I used hiker_DC's solution on my DMR E85H. I'm a newbie, never tried to do anything like this before, never soldered anything, etc. Plugged the thing in, not expecting much, and it worked perfectly!!! Thanks you, hiker_DC.
Was this helpful?
Yes
No
Solution #11
posted on Nov 22, 2008
Helpful)
edna1242
Rank: Apprentice
Rating: 85%, 1 votes
Thanks to all of your suggestions I was able to fix my DVR. I just want to add that the Radio Shack Radial capacitors polarity is shown by the arrows pointing to the minus (-) lead.
Was this helpful?
Yes
No
Solution #12
posted on Oct 29, 2008
Helpful)
cabinjj
Rank: Apprentice
Special thanks to randychev and hiker!! I followed instructions and in less than one hour replaced the capacitors and done. Pictures were a great help. Unit up and running great!! Can't believe Panasonic would soak a person $130 plus to solve a $3.00 problem. I hope I can return the favor some day and help others!!
Was this helpful?
Yes
No
Solution #13
posted on Oct 20, 2008
Helpful)
emrlsu87
Rank: Apprentice
Thanks to DC and RandyChev for the directions, advice, and photos. It took me about 3 hours (including trip to Radio Shack) to fix the "Please Wait" problem........works like new.
Was this helpful?
Yes
No
Solution #14
posted on Oct 15, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Hey Thanks, It works! This Pana Unit had a bunch of old family films in the hard drive when it stop working. Now it is fixed and all is saved. Thanks again
Solution #15
posted on Sep 25, 2008
Helpful)
inlandcpl
Rank: Apprentice
Thank you, thank you, thank you !!! Nervously replaced the two capacitors and I cannot believe it ! It works !!!! First time attempting anything like this. Wow...... I appreciate it.
Was this helpful?
Yes
No
Solution #16
posted on Sep 22, 2008
Helpful)
SD-Mongo
Rank: Apprentice
What a great help this has been! I had the same problem and stumbled upon this sight looking for a replacement hard drive because I thought mine had crashed. This saved me about a hundred bucks and a lot of frustration. The pictures were absolutely the best help - I even got the part numbers for the capacitors off the picture of the packages. Many, many thanks again.
Was this helpful?
Yes
No
Solution #17
posted on Sep 16, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
My E85 suddenly would not power on. It had been acting very sluggish prior to this and I had become frustrated to the point of not using ut. After reading this thread, I removed the circuit board as described and found that capacitors C1260 and C1261 were bulging and leaking. There were rated at 10V, 680 uf. I removed both and replaced with 15V 1000 uf. After reassembly, the unit worked powered up. I then installed the update to the software after downloading from the panasonic website. The unit works perfectly and responds promptly.
Thanks to all.
Solution #18
posted on Aug 17, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Thanks to all here!!! I had the same problem as mpitt (totally dead unit) replaced two obviously failed capacitors and all is working again.
Solution #19
posted on Feb 12, 2009
Very Helpful)
ceconrad
Rank: Apprentice
Thanks very much to hiker_DC and especially to RandyChev for the step-by-step instructions and pictures that gave me the confidence to do it.
I had the same symptom where PLEASE WAIT was stuck on the display forever, and if you listened closely there was some kind of pulse about once per second.
I was skeptical that the problem would be so easy to fix but when I opened up the unit sure enough C1270 and C1271 had failed visibly:
The local "The Source by Circuit City" (what all the Canadian Radio Shacks turned into) didn't have much capacitor selection, but another local electronics shop had 1000 µF 25V caps that worked great:
Note: When I first plugged the unit back in I got PLEASE WAIT again while it tried to reorient itself. But this time I could hear it doing things, plus the screen display was a bit different (had other symbols too), so I just let it go for a while. Eventually it shut itself off (rather, went to standby). Then, with trepidation, I pressed power. It powered up and told me an error had occurred, and that I needed to press ENTER. So I did that. It shut itself down. I pressed Power again and this time it came up in the SELF CHECK mode. When it was finished the self check everything was fine. It had even remembered all my channels and programs!
In summary this cost me:
  • 1 hr to troubleshoot and disassemble (includes finding this web site)
  • 2 hrs to buy parts (first place I went didn't have what I needed)
  • $10 for parts (had to buy 4 caps even though I only needed two, and I was nearly out of solder so I needed more of that to)
  • 1 hr to repair and test
So, if I were able to bill my time out at much, then this may not have been worth doing myself. But since I'm currently a student and my time is worth little (monetarily, anyway), this was great. Plus I had fun doing it.
Thanks again!
Was this helpful?
Yes
No
Solution #20
posted on Nov 24, 2008
Very Helpful)
biller2000
Rank: Apprentice
I had the same problem with the same 2 parts. I saw others were having other caps go bad in that same general area. So I decided to replace those too.
I did one thing better while I had the thing apart. I upgraded the 120gb hard drive to a 320gb drive while IDE drives are still available cheaply. I used my PC to clone the old drive to the new one. Once I dump all my content to DVD-RAM, I'll reformat to get the full capacity.
Was this helpful?
Yes
No
Solution #21
posted on Nov 19, 2009
Not Rated)
creeves850
Rank: Apprentice
Rating: 0%, 0 votes
I followed RandyChev's instructions, and they were perfect (one bracket screw on my machine was in a different place than his). I have never worked on electronics before, so it was very satisfying to fix this problem. The pictures were fantastic! Thanks so much.
Was this helpful?
Yes
No
Solution #22
posted on Nov 13, 2009
Not Rated)
ronostertag
Rank: Apprentice
Rating: 0%, 0 votes
My deck had the same problem with the Please Wait, when I opened it those 1270 and 1271 looked bad and as long as it was open I also replaced the 1260, 1261 and 1272 caps as warned about it other postings but on the other board I had a bad looking cap 3031 so I did that also. As long as you have it open look around.
Was this helpful?
Yes
No
Solution #23
posted on Oct 02, 2009
Not Rated)
tahoejoe167t
Rank: Apprentice
My E85 started showing the please wait the other night and then went completely dead. Opened the unit up and C1270. 1271, 1260, 1261 all looked bad. Used the recommend radio shack 1000 micro F capacitors to replace all 4. Though I had no confidence in my soldering job, to my surprise, the unit started up! Now , I just hope the soldering job holds. Thanks to all of those who posted here.
Was this helpful?
Yes
No
Solution #24
posted on Aug 03, 2009
Not Rated)
ahidontknow
Rank: Apprentice
Rating: 0%, 0 votes
Thanks for the instruction. After replacing 6 damaged capacitors, my DMR-E85H is up and running and I become a hero of my 4 years old daughter as there's lots of films recorded she loves.
The capacitors I replaced are C1270, C1271, C1272, C1260, C1261 and C1413.
Was this helpful?
Yes
No
Solution #25
posted on Jun 26, 2009
Not Rated)
wjhyslop
Rank: Apprentice
Rating: 0%, 0 votes
I have a DMR E85H with exactly these problems and have just dismantled it following all the excellent instructions and pictures posted by you guys. (many thanks).
However my power board is different to those pictured, (made in Slovakia) and seems to have a different layout of components.
Most disappointingly there appear to be no faulty caps, after close inspection they all appear perfect, but due to different board they are also not numbered the same eg.C1270, C1271 so I don't know which are the potentially faulty ones.
Any advice would be most welcome.
Many thanks.
Was this helpful?
Yes
No
Solution #26
posted on May 27, 2009
Not Rated)
jwr1914
Rank: Wiz
Rating: 86%, 7 votes
I want to say that the same problem led me here but I had to replace the other two capacitors that were right next to the ones named to resolve my problem. C1269 & C1270 are the same type of capacitor but for another voltage in the power supply (I am guessing). My caps showed signs of bulging and leaking and I realized that I had a similar problem but diferent. I went to Radio Shack and purchased the same capacitors but replaced these two culprits and voila, no more problem. Started right up after the bootup. I did not lose a setting. Thanks, guys!
Was this helpful?
Yes
No
Solution #27
posted on Apr 16, 2009
Not Rated)
sridoc
Rank: Apprentice
Rating: 0%, 0 votes
Let me add to the chorus. Apparently the C1270 and C1271 capacitors are the weak links in the DMR E85H video recorder. Having the same problems everyone else mentioned, I took my unit apart (following the excellent instructions by RandyChev) and found those two capacitors with swollen tops and a scant amount of leakage. Replaced them with the Radio Shack 35V, 1000uf capacitors and the machine works like new! Thanks very much, RandyChev!
Was this helpful?
Yes
No
Solution #28
posted on Apr 01, 2009
Not Rated)
G_G072
Rank: Apprentice
Rating: 0%, 0 votes
First of all, THANK YOU. My Panasonic DMR-E85H DVD Recorder suffered the same fate when it froze on "Please Wait" and ceased to operate. An internet search led me here and I figured I might as well try the remedy described. Once I opened up the machine the same two capacitors were obviously fried - C1270 and C1271 were split and leaking. The photographs and descriptions listed here were right on the money. I ventured to Radio Shack to purchase the better spec capacitors. One mistake I made - I unintentionally purchased capacitors with AXIAL leads the first time - same specs but these will not work for the repair as they are a bit larger and the leads will make contact with other portions of the board when bent around the capacitor. Make sure you purchase the RADIAL lead capacitors - rookie mistake on my part but it might save someone else the trouble. I have zero experience in soldering but found a friend with some experience and we went to work. We found that we did not need to remove the old solder and did not need to use new solder. Very simply - use your solder iron to heat up the original solder just enough that you can wiggle one lead at a time out of the board on the bad capacitors. This was very easy and only required heating the four original solder spots one at a time and rocking the bad capacitors out. It is definitely a two person job using this method - one to heat the solder and one to rock the leads out. We pre-cut the leads on the new capacitors to about 1-1 1/4", reheated the four solder spots one at a time and inserted the leads of the new capacitors. They were solidly on the board after just a few seconds. We bent them over to reduce their height and I had the machine back together in about five minutes. WORKS LIKE NEW again and I am hoping the better spec capacitors will last. Once again, thanks for the tech info. Take it from me - it was not a difficult repair and will cost less than $10 even if you have to buy a new solder iron - less than $4 if all you need are the capacitors!
Was this helpful?
Yes
No
Popular Solutions for Panasonic DMR-E85H DVD
Questions and Unsolved Problems for Panasonic DMR-E85H DVD
Do you recommend Panasonic DMR-E85H DVD Recorder?
Answer
Answer
Panasonic dvr recorder dmr-e85h suddenly in only playing in black & white... Is there a... (More)
Answer
have no problem,just tell me how to run this unit. Regards, Alex.
Answer
Ever since the time change, my E85H has been acting flaky. I did get the clock re-set, but now it... (More)
Answer
my remote says check remote3 how do i fix it since every time i touch it . it won't allow me to do... (More)
Answer
When placing DVD in it says no read Also wont burn disc And makes a clonking noise when trying to'... (More)
31 Other Users Have The Same Problem - Continued
Comment by islandzac386, posted on Feb 17, 2009
hello, could someone please tell me if i will need to change the cable for the black ribbon, first?
as i have just noticed after removing the cover that about half of the cable has been damaged across the width of it.
i too have an error ... with the display flashing //// 0:00 //// .... just had my strg-6353 replaced and checking for faults! lo and behold, there seems to be another problem ... dah!!!
and help would be most appreciated ... cheers!
Comment by Guest, posted on Feb 17, 2009
hello, could someone tell me ... would i need to replace the cable to the black ribbon ... just noticed that the cable is snapped about half way across!
just checked my recorder, and now all i get is a flashing ///0:00//// .... or should i change my capacitors!!!
Comment by Luxofoz, posted on Feb 02, 2009
I have removed everything down to the circuit board but there doesn't seem to be any bulging or leaking capacitors at all! Should I remove the dvd player and check capacitors under there? Any ideas? Thanks.
Comment by stilettoking, posted on Feb 01, 2009
"please wait" on display problem. Nothing seems to make it work again.
Completely frozen.
Can I at least remove the DVD that's inside?
Comment by heldnova, posted on Jan 25, 2009
I had the same problem and replaced the capacitors. Now everything works fine on HDD except the door on the DVD drive won't open. Display shows "LOCK." Pushing Pause and Channel up as suggested in the manual doesn't help. It still shows "LOCK." Trying to record on the DVD drive shows the disc is full even though it is not. Help!
Comment by cccbowe, posted on Jan 11, 2009
I had the same problem i replaced the capacitors and now the message please wait is gone but the unit does not respond to any other command by remote or on the unit only the power button works and the display reads no disc
Could some one help me on thsi one
cccbowe
Comment by Guest, posted on Jan 08, 2009
I may have the same problem, the PLEASE WAIT is frozen without hash marks, but the video output flashes like a one second alternating Black and White Strobe.
Comment by brudin, posted on Dec 17, 2008
PEASE WAIT ON SCREEN>AND NOTHING HAPPENS>any ideas?
Comment by Guest, posted on Dec 12, 2008
I thought the unit would not support a bigger hard drive, and that it had to remain the same size? Also, how many software updates have there been for it?
Comment by RoyGBiv-inRI, posted on Nov 28, 2008
Had the same problem after recording last weekend and turning the recorder off. I was amazed to see this detail fix offered during a quick web search. It turned out to be a good project to do with my father visiting from Florida for Thanksgiving Day weekend. We just finished. I was more than a little upset when I plugged the unit back after we''d finished and it still said "PLEASE WAIT," but in a minute or so it powered up, and it is working normally.
Thanks for the fix and the detailed pics, they really helped.
SMK
Comment by Guest, posted on Nov 23, 2008
The fix offered worked great!
Comment by kodi06, posted on Nov 23, 2008
My system was recording when I went to bed one night and had a "please wait" message when I got up next day. I tried unplugging it and plugging it back in. Nothing. I tried leaving it unplugged for a day and again nothing. Can you please help me with this? You can't buy these anymore and I really love it.
Comment by kevbofixya, posted on Nov 10, 2008
Same "Please wait" problem, I thought I'd have to sell her for scrap, but then I found this, and wow. Worked perfectly! Thanks for the advice, (I used the radio shack 3 dollar caps). The pictures helped a lot, much appreciated. I owe you guys!
Comment by Guest, posted on Oct 22, 2008
I had the same problem.  I followed your instructions and it was a snap to fix!  Great pictures made it really easy.
Comment by kvenezia, posted on Oct 18, 2008
To repeat those of you before me: Thank you, thank you all!. RandyChev's pictures matched my exact problem, now fixed with capacitors from Radio Shack. All of you gave me the confidence to bring out my soldering pen used previously for much less important surgeries.
Ken
Comment by tympani, posted on Aug 23, 2008
The white band on the capacitor body is NEGATIVE. (Actually you should be able to figure it out from the other ones on the board). If you can't find a 680 ufd, you can use a 1000 ufd capacitor. Hope this helps
John
Comment by elmalem, posted on Aug 23, 2008
I have same "pls wait" problem, read this post and found it to be gr8. Thanks to all the replies. I followed the steps, found my 2 caps to be bulging/different color top, obivously out and what made it worse, was that radio shk had only One (35V, 1000uf). My question is:
how do i figure out the polarity, which is the positive on the cap, and which side is the positive on the board?? Please let me know, asap, because early morning tomorrow, i am heading out to another radioshk to grab another one and replacing them.
THANKS
Many thanks to hiker_DC for your suggested repair. My DMR-E85H just developed this problem: Stalls at "Please Wait". I removed the HDD and circuit board. Caps C1270 and C1271 were bulging. 2-$0.70 caps from my local electronics store (1000ufd) fixed the problem. Fortunately Panasonic idiot proofed the board so it's silk screened on both sides with the cap numbers and polarity. 1/2 hour fix, open to close except for the trip to the store.
However, when I booted the machine it came up with nothing on the HDD but after switching it off and back on again, all stored programs reappeared. Looks like Panasonic underdesigned these units.
BTW, does anyone know if and how to put a bigger HDD in these. Is it even possible? How does the software that runs the machine get transfered or is it stored in firmware like ReplayTV units? Is it possible to back up the unit to a second HDD?
Thanks,
John Gilbert
Comment by cheetah595, posted on Aug 07, 2008
DVD recorder was stuck on "Please Wait". Called Panasonic and they said the minimum charge to repair was $130. I told them explicitly not to repair the machine unless the material I had recorded on the hard drive would be unaffected. The hard drive was practically full with superbowls, bowl games, boxing matches, survivor finales, concerts, olympics, etc. that I had recorded over the last few years that could not be replaced. The only reason I wanted it fixed was to retrieve this material. Otherwise no way I would pay $130 for a 3-yr old machine. When I got it back today, it appears to be working ok, but the hard drive is blank and all my stuff is lost. I am really POd about this and will call them tomorrow to demand my $$ back. My question on this board is this - is there any reason why my hard drive would be erased or bad because of a capacitor problem????
Comment by MitchCurry, posted on Jun 24, 2008
Had same problem; replaced C1270 & C1271 capacitors. Gets further into the bootup process, but stuck in "Please Wait" mode. Before replacing capacitors recorder did not show hash marks in front and behind the "Please Wait" message. This message lasts for about 60 seconds, then "Please Wait" message lasts forever and no hash marks. Does anyone have an idea what to try next? I think it might be the hard drive or DVD-RAM drive. So, I am asking to see if anyone has a service manual, not operations manual, or troubleshooting steps to see if the hard drive or DVD-RAM drive is bad? Thanks!
Comment by CaptBill, posted on May 29, 2008
Just to expand on my comment. I think my 4 year old unit went out Sunday when I was flipping circuit breakers to install a ceiling fan. I think the capacitors were getting weak since the unit now seems to respond a lot faster starting up and navigating through the Direct Navigator screen.
Comment by CaptBill, posted on May 28, 2008
I had exactly the same problem display frozen on PLEASE WAIT and no fan running. I was lucky that it came up at the top of a Google search. Read Hiker_DCs post and took off the hard drive off and there was C1270 and C1271 with bulging tops. A trip to Radio Shack and $3.38 for two 1000uf 35V capacitors (PN 272-1032) was all took to fix it. Guess my soldering iron was old or I was out of practice because I had trouble soldering the new capacitors to the board. But I put a jumper wire from the leads back to another spot on the same foil. Plugged it and it came back with the last channel display and time left on disk.
Many thanks to Hiker_DC. I still like this unit with a hard drive and disk drive I can dub too.
Comment by Pat2830, posted on May 18, 2008
I have the same problem. The DMR-E85H was working fine last night. When I went to set it this morning, the display was blank and it wouldn't turn on.
I unplugged it, plugged it back in, and got "Please Wait" and nothing more but the flash on the screen eveyr few seconds.
Comment by stashu, posted on Apr 19, 2008
Tried Hiker DCadvice and it worked. I have never done anything like this before but gave it a try, I had nothing to lose and saved $130.
Thanks for posting this info., mpitt advise was very helpful too.
Looked under the hard drive and saw 2 leaky capacitors. Found both at Radio Shack for the same price as mentioned. I'm just thrilled.
Thanks everyone again.
Comment by stashu, posted on Apr 18, 2008
I turned the unit off and went to bed. When I woke up I noticed the unit never shut down and " PLEASE WAIT " is displayed. It doesn't respone to anything. I pulled plug for 12 hours and still comes up " PLEASE WAIT ".
Panasonic says, must be returned with $130. and wait for price of total repair. I need help as it's not worth this kind of money with no guarantee.
Comment by please wait, posted on Mar 22, 2008
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Panasonic DMR-E85H DVD...:
Top DVD Player Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more DVD Player Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
