Question about Car Audio & Video
My car is idling very well but the moment i put my foot on the pedal it cuts off this usually happens when it reaches operating temprature
    New Friend:
  • 169 Answers
Try increasing idle speed.
Posted on Nov 22, 2013
My 06 cobalt will not idle. I take my foot off gas pedal it cuts off.
The automatic idle control unit is not operating. Could be as simple as a poor or disconnected wire or the unit is bad.
Nov 20, 2015 | Cars & Trucks
Engine will die after warmed up
depends on what you mean by "warmed up". If you mean engine reaches normal working temprature and works normally then cuts out , but restarts wwithin 5 minutes and then carries on working normally until it cuts out again, and then restarts withing minutes...have the throttle position sensor checked. It may be that you have a warning code on the dash?
It might be the pedal position sensor alternatively.
If your engine works ok until fully warmed up this may be the problem.
If there are any symptoms before the cut out happens can you please add the details and repost thwe query
Oct 26, 2015 | Cars & Trucks
My 2004 ford expedition idles rough like its going to cut off The idling jumps up and down in park or drive only when stopped Service engine light cuts off and on periodically what could be happening
run a teat. Remove the vacuum line from the brake booster and plug off. Start engine and see if it idles normally. . Put your foot on the brake pedal and apply the brakes . If the idle is still normal replace the brake booster as there is an air leak in the diaphram.. The service light is probably recording misfiring and air fuel mixture problems.. run fault codes any way just to check it out .
Dec 23, 2013 | Cars & Trucks
After cranking it idles fine but after about a min. it starts idling really high. I can't find any vacuum leaks. is there any of the controle modules that would cause this ?
Are you sure that this is actually idling high? If you put you foot on the brake, and put into drive, would the vehicle jump?
The reason that I ask, is the cooling fan has a very similar sounding effect, when it kicks in. If this were to be the cause, you would alter it's noise, slightly, by putting into drive, but the vehicle would not jump excessively?
If the vehicle is actually reving high, I suggest paying for a diagnostic, presumeing you have no error codes........ Many things can cause higher idle, many of them NEEDED, they deal with issues like temprature, emissions, some models charging....etc. get an opinion.
Your vehicle, by the way, has drive by wire, meaning there is not actually a pull cable going from the foot pedal to the throttle plate..... So, you need to inquire, programmically, with the computer, typically these tools are too expensive for home use....get an opinion from a good shop, or maybe the dealer.... At least the dealer would also look for recall issues for you...
Mar 11, 2011 | 2005 Chevrolet Express
Idles rough quits when foot off gas pedal
You have a blown head gasket, or intake manifold gasket one of the two.
Feb 10, 2010 | 1996 Nissan Altima
The engine will not idle when cold
possibly the coolant temperature sensor is faulty
Sep 05, 2009 | 1995 Subaru Legacy
Car will not idle must keep foot on gas pedal or it cuts off
Check the EGR operation. If this valve is leaking it will cause your symptoms.
Jun 30, 2009 | 1997 Chevrolet Monte Carlo
1997 Honda Accord stalling at lights when gas is pressed.
It sounds like you need a complete tune up and have the cooling system fushed and filled as well. It sound like it needs some TLC.
Jun 18, 2009 | 1997 Honda Accord
When warmed up, the engine (2.7) may miss erratically
1391 is lose off cranksensor or cam sensor like code 340 i would by a cam sensor for that code.356 sounds like a bad coil on #6 which there are one per cylinder .dont worry about code 432 for now.
Mar 15, 2009 | 1999 Dodge Intrepid
Car Audio & Video Logo
26 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
