Question about ASUS A8R32-MVP Deluxe Motherboard
Mother board boot master - ASUS A8R32-MVP Deluxe Motherboard
My computer will not boot up,mother board problem?
could be a mother board problem but before you replace it try a few things first
remove the memory and try to boot
unplug all hard drives apart from master and try to boot
go into the bios and load default settings rty to boot
when you mean doesnt boot do you get the welcome screen ? says windows xp etc
if so then its a windows issue and you need to reinstall windows
if after trying all of this the yes maybe its a mother board issue
hope this helps
John
Jul 07, 2011 | Intel Computers & Internet
In nova net pc with intel D945GCLF Mother board , it does not boot the system with windows, and want to flash the bios , its not supporting with usb boot, cd,dvd booting ? , then how we install windows in...
while booting up it must be giving you an option to enter the cmos setup with hitting either f8 key or del key or f10 key. Just hit the key at the appropriate time and enter the advance setup in the cmos setup and go to boot devices and select the priority you wish. In some cases the hard drive and cd rom have jumper settings for putting them in master and slave mode. just read on the drive label and set your cd rom to master and your hdd to slave and you will be able to boot through cd and instal windows.
Dec 26, 2010 | Intel Computers & Internet
Installed a sata hard drive but will not boot now tryed the ram not a problem with the ram could my mother board be dead
You would not have given your hard disc as the master device. You will have a jumper at the backside of your HDD which will decide whether that device is to be detected as Master or slave. So change it as Master if its slave and try booting your system.
Else the HDD must have got corrupted. Try reinstalling XP in ur HDD if the above solution doesnt work.
Aug 01, 2010 | Foxconn (755A01-6ELRS) (K8S755A6ELRS)...
Mother board P4S800MXSE - message:
Your primary is your boot drive c) If you do a disk check it might be able to fix bad sectors unless there is physical damage.
Jan 29, 2010 | Computers & Internet
Disk boot failure
Your boot sector is corrupted you need to install windows again from a bootable windows cd...
Feb 28, 2009 | Intel D845GVSR Motherboard
Primary master hard disk error
i also need help
my motherboard cannot detect also my SATA harddisk
my Mother board is K8V-X but in boot options i see my harddisk
but in main menu no SATA..
so thats why i cannot reboot or reformat my pc
May 29, 2008 | ASUS K8V-MX Motherboard
I replaced mother board now I can't access files on old HD
Try going into the BIOS settings and setting the slave drive as the 1st boot drive.
May 04, 2008 | Intel Motherboard
Installing a 2 port ATA-133 IDE adapter card to a desktop w/a hard drive & DVD
I don't think you can boot off of the ATA-133 so you will have to boot off of the IDE on the mobo and have the DVD drive jumpered cable select on the 2nd IDE. Boot that way to make sure the system boots. Shut down. Then instll the ATA-133 adapter with NO DRIVES on it and boot. The system should ask you for drivers for the new hardware. Intall the drivers. Shut down. Attach the new drives to the ATA-133. Reboot. You still might have to go into admin in windows and assign drive letters to the new drives. Anyway, if you are trying to boot off of a drive on the ATA-133 adapter, I don't think you can do it. I have mostly used Asus boards with Award Bios and there was no way to point the boot process to an add-on ATA Controller.
Jan 12, 2008 | Promise Ultra133 TX2 ATA Controller
Hdd master password
PLEASE REPLACE UR MOTHER BOARD BATTERY. I GUESS UR BATTERY MODEL WILL BE CR3212... PLEASE CHAGE IT AND TRY IT AGAIN. NOT YOUR LAPTOPS BATTERY... THIS IS A BATTERY ON THE MOTHER BOARD. PLEASE TAKE IT TO UR NEAREST DEALER AND GET IT DONE.. PLEASE DO NOT OPEN IT WITH ANY KNOWLEDGE.
CHEERS
AVI
Nov 05, 2007 | HP OmniBook XE3 Notebook
Cannot boot in Slave mode
i have never heared of any hardrive being able to boot when it is set as slave, as the master is always the 'C' drive from which windows looks for the master boot record. why, if you have only one hard drive is it set as slave?, it doesnt make sense. No hard drive will boot up if there is no jumper cap on it, as the motherboard needs to know which hd is master and has the o.s on it.
Jul 28, 2007 | Asrock P4I45GV R5 Motherboard
ASUS A8R32-MVP Deluxe Motherboard Logo
13 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
