Question about Cellet EBCEL39 Bluetooth Headset
How do I know Cellet Bluetooth getting charged when I put for charging. Because there is no indication (may be I dont find) of charging or Charged
Lg hbs 510 bluetooth is fully charged (blue light) but when i unplug from charger it wont turn on or vibrate
Your Bluetooth may be falsely indicating it is charged when, in fact, it is not charging at all.
Jul 12, 2017 | LG Radio Communications
My HBS 730 LG Stereo Bluetooth head set doesn't seem to come on. It seems not to charge up according to its indicator light.
the rechargeable battery has died and usually not serviceable by the consumer .check with a phone store .
Dec 08, 2015 | LG HBM 730 Bluetooth Headset Wireless...
How do you know its charged
If, when turned off and plugged in, the indicator light is red, the battery is low. If the light is purple, the charge is medium. If it's blue, the charge is high. Good luck.
Nov 02, 2012 | Motorola Mobility H721 Bluetooth Headset
Bluetooth is plugged into charger but keeps flashing red light, dont know if its charging or not
I had the same issue -- charged it for days and still red light flashing. I was ready to break it open and see if I could replace battery. Then I looked on the opposite end of the charger and seen a little round hole thingy. I put the end of a pen in there and pushed it twice and -- the red light went away . Plugged the charge in and steady red then purple and now blue. Looks like that is a reset ..Try it -- it worked for mine.
Sep 22, 2011 | Motorola Mobility H721 Bluetooth Headset
Not getting Charged
If you mean the Insignia NS-BTHDST or NS-BTHDP, I read elsewhere in this forum that you can reset it and that might work. See the manual. Basically you hold the volume up and volume down together while the charger is plugged in. The instructions were vague and mine did not reset nor show a purple light as indicated in the manual.
However, after trying that a couple of times, I accidently got it to work by pressing the phone/play button twice. Press it normally, not the long press you use to turn it off and on.
So in other words, plug it in to the charger. Press and releas play. Press and release play.
For me, the charge light turns on and it starts charging. I hope this helps.
Mine is new too, sort of. It was an "open box" from an ebay seller. I may return it anyway, since it is clearly NOT behaving correctly. You shouldn't have to press buttons at all to get it to charge. I know because I have another one.
Bon chance, mon ami.
Oct 10, 2008 | Insignia Bluetooth Wireless Headphones...
Charging H550
The indicator light turns red when the battery is
charging. It may take up to 1 minute for the
indicator light to turn on. When the headset's
battery is fully charged (about 2 hours), the
indicator light turns off.
Jan 09, 2008 | Motorola Mobility H550 - Bluetooth Headset...
Motorola H350 bluetooth headset light indications, what do they suggest?
The headset is fully charged when the light goes out. The two buttons on the side are for volume up and down. Press both at the same time and it mutes the headset.
Nov 10, 2007 | Motorola Mobility H350 Wireless Headset
Motorola H500
press and hold the main button for 3 or so seconds an it wil flash 3 times to indicate that it is active.
Mar 24, 2007 | Motorola Mobility H500 Wireless Headset
Cellet EBCEL39 Bluetooth Headset Logo
26 people viewed this question
Top Cellet Radio Communications Experts
eradiostore
eradiostore
Are you a Cellet Radio Communication Expert? Answer questions, earn points and help others
