Question about Bose QuietComfort 3 Acoustic Noise Cancelling Consumer Headphones
Crackling right hear intermittent - Bose QuietComfort 3 Acoustic Noise Cancelling Consumer Headphones
Random intermittant crackling sound from Hotpoint electric oven
This could be insulation on the wiring or more importantly the connecting spot might be frying. In any event, disassemble it and check into it.
Feb 24, 2013 | Hotpoint Ovens
1997 ford ranger right turn signal doesn't work
Find and replace the flasher. Turn the other blinker on and follow the clicking noise. It will be a small square cox making noise
Sep 01, 2012 | 1997 Ford Ranger SuperCab
Just recieved a pair of qc15's after the first use the right ear cup will crackle intermittantly, building up then dropping out, it does it randomly
It's the EQ of your ipod or itunes that is tripping them up. Apparently there is a 'perfect' EQ to run them on but I'm not familiar with it. Running them with the EQ 'flat' should fix the problem. Hope this helps...
Aug 07, 2012 | Bose QC15 Headphones
Intermittent crackling sounds DPR 1005
This is an obvious thermal problem. Use circuit cooler to isolate the bad part. It could also be a crack in a circuit board.
Alternate warming with hair dryer and cooling one component at a time while listening for the noise.
Feb 16, 2010 | Harman Kardon DPR 1005 Receiver
Screeching/crackling coming from amp
Could be just a bad solder joint somewhere!
Jan 22, 2010 | Audio Players & Recorders
My ipod crackles and my hearing seems to be getting damaged
Id say you should go see a doctor. But for now id say that you should do your best to not listen to it for a while as it can affect hearing. try to use full on speakers if you can. On you tube there are a few Sub-Woofer sound tests you can do. Try playing one (low volume) and repeat. (not a song one)
http://www.teenbuzz.org/ also to hear which frequencies are out of range to you click here. ( click the second icon on the list further down the page)
But yeah go see a doctor. Perhaps some ear drops.
Sep 01, 2009 | Apple iPod touch
Creativr Gigworks S750 Subwoffer intermittent sound
The S750 system is a great sounding one but unfortunatly like many similar systems all the amplifiers and power supplies are housed inside the sub box. This means they suffer badly from heat and vibration problems (they cook themselves or shake themselves apart). I have fixed a few S750 systems in the past but due to their complexity it's not for the faint hearted.
May 26, 2009 | Creative Labs Gigaworks S750 Computer...
Intermittent Crackling noise in the right headphone
Hello Rachel, I use my QC3 for 2.5 years Mon-Fri for 3 hours a day. I have the same problem when battery is weak and/or it is cold outside. The cracking nose stops for me if battery fully charged. This is known problem andBose put it in the manual.
Vlad
Aug 28, 2008 | Bose QuietComfort 3 Acoustic Noise...
Bose QuietComfort  3 Acoustic Noise Cancelling  Consumer Headphones Logo
23 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Ben Armstrong
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
