Question about Dishwashers
Lamona dishwasher lam8601.... Same problem as last person!! Dishwasher won't work on any programme but sounds as though it's working ?? Any suggestions ?
2 Suggested Answers
SOURCE: Lamona dishwasher from Howdens. E1 code
we have a howdens dishwasher model number hja8630, which is full of water which hasnt drained . i have ladled it out checked filters are unblocked but it still fails to start. it does a click click sound and then nothing . only 18 months old and only ever used twice a week
Posted on Mar 22, 2010
Electrolux dishwasher
Hello - The issue may lie with the door latch; a door switch is used to start and stop your dishwasher. It's a safety feature that won't allow water to flow with the door open. With a faulty door switch, there is a chance your dishwasher won't start at all. Dishwasher door switches are about an inch long. They are usually black but can be red. There are metal prongs on the body of the switch called terminals. Some door switches have two terminals and some have three. If your door switch is OK, check the timer assembly. This controls when and how long power is sent to other controls on your dishwasher. If these controls don't receive power, they won't work. The timer assembly contains a motor. Check this motor as well. It is often cheaper just to replace the timer motor rather than the complete assembly. My last suggestion is to check the cycle selector switches. These switches indicate cycles for washing, drying, and setting the temperature of the water. If one of your switches is the problem your dishwasher may not start. Dishwasher cycle selector switches tell the timer which cycle to run by opening and closing electrical circuits. Most selector switches are six to eight inches long. They are usually black and have terminals. By testing each one of these parts with an ohmmeter you should be able to determine why your dishwasher is not working. It is possible for other parts to fail but these are the most common parts to check. If any proves to be ineffective, I strongly suggest contacting a professional to move forward accurately.
Nov 05, 2012 | Electrolux 24 in. ESL4125 Dishwasher
Lamona (Howdens) dishwasher. Start/Cancel/Pause button is not working.
Probably a bit late for the original poster, but I found this page after searching with the same problem. You can actually fix this yourself. I had exactly the same problem - if you take the front off the dishwasher, the switch module is inside a grey plastic moulding. If you remove the two cable plugs and remove the two screws holding the moulding in you can then take it out. Carefully open it by pulling back the clips, and inside is a small circuit board that slides out. On one side are the two microswitches. I got mine working again with some switch cleaner. If that doesn't work, you should be able to get a new switch soldered on by any electrical repairer. Obviously, yours may be slightly different as I don't know what model dishwasher you have, but mine is a Howden's/Lamona too, so it's probably very similar. Good luck.
Oct 07, 2012 | Dishwashers
Steam coming out of dishwasher
Sounds like the drain hose is partially plugged restricting the water to completely pump out.
Mar 28, 2017 | Dishwashers
Dishwasher not working. Start button works ok as
It sounds as though the Anti-flood device has kicked in,could be due to a leak under the dishwasher,it will need to be pulled out and investigated.
I would also check that there is water at the hose to the machine.
Hope this helps.
May 21, 2010 | Neff 24 in. S4456 Built-in Dishwasher
Feb 21, 2010 | Dishwashers
CDA dishwasher (model number CW496) , stops working at the rinse cycle, and does not empty, filter is ok, tried re-setting the programme but unless there is no water being held the programme won`t work
my dishwasher starts off with good intentions then a couple of minutes later it starts beeping non stop.I open the door to find it has turned on to the rinse cycle and will not do its job.I continue to start it again and then it repeats the problem again.Can you help?
Sep 21, 2009 | Dishwashers
HELP WITH NON FUNCTIONING DISHWASHER
similar problems here, repair man says its fine but the salt light was on so i added salt and works ok now. Some dishwashers don't function properly without the salt and rinse aid, even though you're pills may have then included, you still have to add them seperately, dumb but necessary at times.
Feb 27, 2008 | Dishwashers
Bosch dishwasher model no SGS4002GB
check to see if you have water in the sump {base} of machine. if there is a leak,the limit will activate making it look as though its washing but it is really the drain pump.working. sort the leak out
Jan 09, 2008 | Bosch 24 in. SGS43C12 Classixx...
Dishwashers Logo
76 people viewed this question
Top Dishwashers Experts
Owen Barnes
