Question about Toshiba satellite c660
My laptop is powering but not running - Toshiba satellite c660
  • 24 Answers
Check out Toshiba's troubleshooter:
http://support.toshiba.com/support/troubleshootSelfService?PRDTYPE=COMPUTERS
It has text and pictures. If that does not work, try plugging in the laptop and removing the battery. Sometimes a bad battery will cause start problems. If you continue to have problems, post what you have done and what has not worked.
Posted on Nov 22, 2013
Laptop sometimes switches off when moved.
Sounds like a loose connection where the laptop opens and closes hinge there are wires that run from the main screen to the main board. If you know how to take the unit apart it maybe a cheap fix if not then a new laptop maybe the way to go the prices have really dropped from 4 years ago
Jan 12, 2013 | HP Hewlett Packard Compaq 6720s Laptop...
Sometimes the Adapter Charges other times Doesnot, and now finally out, cant charge!
Possible cuase:
1 AC adapter failure
2 Power jack failure
First replace it with another working charger, see if the problem gone. If not, there may be strong possibility that the power jack was broken.
Here below are some common symptoms of a bad charger.
-The laptop only runs when you keep the power cord in a certain direction.
- The laptop only runs on battery power.
- The laptop will not charge the battery.
- The laptop switches from AC power to battery power intermittently.
- The unit suddenly shuts off
- Sparks come out of the back of the laptop.
Reference: Dell Latitude D620 Charger
Jan 20, 2011 | Dell Latitude D620...
When the power charger is on my compaq nx6310, it run very slow, but when I use it without the power charger, only battery, it runs well... it works good!!! My S.O. is Windows XP professional sp3 I use...
You need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
Sep 19, 2010 | HP Compaq nx6310 Notebook
HP Laptop will not power on even pluuged into a/c outlet
Does it run hot, to the touch I mean? Google a free program called Speccy. Install and run it; look at the internal temperature and see if it slowly rises until the laptop shuts off.
Jul 26, 2010 | HP Pavilion dv6000z Notebook
My battery charges but the laptop wont run on the battery
If your power adapter appears to be charging your laptop battery, but the laptop will not run on the battery or only runs for a short time this usually indicates that the battery will not hold a charge and needs to be replaced. Although it should run fine with the power adapter connected.
Jan 26, 2010 | Dell Inspiron 1521 Notebook
Bought new power cord for pavillon dv 1000 and
If the laptop runs on batter but cannot run on the AC adapter, you have a broken DC Jack. If you laptop cannot power up with the battery or flash low battery indicator, you laptop is dead.
Oct 30, 2009 | HP Pavilion dv1000 Notebook
Laptop will not operate or charge the battery from the power pack. It runs fine on battery.???? It is an NEC Versa M400
1. Power OFF laptop
2. Remove battery
3. Use power pack and turn ON laptop (without battery)
4. The laptop will work.
5. After Windows has settled down, insert battery (with laptop on and Windows running).
6. Allow the power pack to catch up a couple of hours.
7. It will work now...
Sep 25, 2009 | NEC Versa VX Notebook
no the laptop cant be run without empty battery
Feb 14, 2009 | Toshiba Satellite A135-S4527 Notebook
Acer Aspire 5000 Laptop
Have you tried changing the power settings,in control panel go to power options and change the time settings for when the laptop is plugged in and running on batteries.
Also change the power scheme to Portable/Laptop.
I hope this helps,please let me know WF
Aug 20, 2008 | Acer Aspire 3000 Notebook
Laptop crashes shortly after boot, power light rapidly blinks red.
Its late, so just to make sure I'm not brain-dead basically your laptop runs fine as long as its powered by the AC adaptor but dies fairly quickly while running via battery. This is very typical of a battery that will no longer hold a charge, not normally a user repairable item. It could also be that the charging electronics (in the laptop) isn't charging the battery, again not a typical user repair job. About your only option short of taking it to the repair shop is buying or borrowing a battery as a test.
Dec 12, 2006 | Medion (40010998)
Toshiba satellite c660 Logo
46 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
