Question about Samsung WIS12ABGNX Wireless USB 2.0 LAN Adapter [WIS12ABGNX/XAA]
WIS12ABGNX Wireless LAN Adaptor
NEED DEVICE DRIVER
Wll an wis09abgn wireless adaptor fit myJMB tv
TV WIRELESS DONGLE - TV - Wireless Networking - Tom's Hardware
www.tomshardware.com/.../32368-43-wireless-do...
Tom's Hardware Guide
Mar 6, 2011 - 6 posts - ‎2 authors
do u know what dongle or wireless device can use to put on TV ?? like u all know samsung already have that dongle (Samsung WIS09ABGN ...
Amazon.com: Customer Reviews: Samsung WIS12ABGNX ...
www.amazon.com/...Wireless-Adapter/.../B0079KZZ...
Amazon.com, Inc.Samsung WIS12ABGNX LinkStick Wireless LAN Adapter. bySamsung .... The manual for my Samsung HT D4500 specifically states that you must use the WIS09ABGN. ... If you have a Samsung LED smart tv you can make it wireless.
How to Use Samsung Wireless LinkStick with Samsung LED ...
? 1:41
https://www.youtube.com/watch?v=rfotB5sdswk
Mar 26, 2010 - Uploaded by SPSN
The LinkStick is a wireless USB adapter that provides instant access to Samsung's ... Can any linkstick work with any Samsung 32 Inch TV?.
Jan 05, 2016 | Computers & Internet
Driver for wis12abgnx/xec
Assuming you can get the driver (which comes as a file, i.e. software, not hardware) how would you install it on your TV ?
According to the 'Technical Information' link on the Web page that you can access via the link I attached with my answer, your adapter is compatible with WiFi-ready Samsung TVs and AV equipment produced between 2010 and 2012. If your TV is not a WiFi-ready Samsung TV or is one produced before 2010, well....If it is a Samsung TV produced after 2012, it probably has WiFI built-in, in which case you don't need any wireless LAN adapter, Samsung or otherwise and the TV did not recognize the adapter because the USB port on the TV that you plugged the adapter in is meant to be used for other devices, e.g. flash drives or portable hard drives.
SAMSUNG WIS12ABGNX XEC Wireless LAN Adapter 3D Accessories pc
Aug 30, 2014 | Samsung WIRELESS LAN ADAPTER...
Wis12abgnx has stopped working
I am having the same problem. I have my internet provider and Samsung. My internet is working fine and Samsung hasn't been much help. I have gone through all of the troubleshooting steps with no success. Have you figured anything out yet?
Mar 20, 2014 | Samsung WIS12ABGNX Wireless USB 2.0 LAN...
Engenius wireless lan usb2.0 adapter driver
A lan adaptor driver is fixable by downloading from the network site of the USB 2.0.
important notes
1. Lan adaptors are outdated versions incompartible with recent operating systems. Acquiring a new USB device or even wireless modems are the latest alternatives to lan computer connections of the past. Modern wireless modem connection have built in installation kits,also present is the computers capability to recognise to integrate to a network.
Dec 21, 2010 | Computers & Internet
Sony UWA-NA1 - no available driver for Windows? what specs does it have? It seems that with a Giga Juke Hifi-stereo, it will only communicate with WEP encryption, but the Wireless Giga Juke player station...
I found it! Sony UWA-NA1 USB Wireless Adaptor is a OEM products of Quanta Microsystems Inc, it's using the same USB adaptor as Ralink RT73 USB Wireless LAN card with RT2571WF chipset. I did it work ok in window 7 64-bit. But in the link below, its support XP, Vista as well.
1. Download Drivers for XP/Vista/Win7 here: http://www.station-drivers.com/page/ralink.htmChoose Ralink RT257x/RT2671/RT520x (RT73 series USB Wireless LAN)
2. After download it, run it to install the Ralink Wireless App, check for the driver only. When it done, find the folder it has installed. 3. Open device manager in window managerment, choose the Wireless USB (have no driver with yellow !), right-click, update driver software..
3.a Click "Let me pick from a list of device drivers on my computer". Find the "Network adaptor" in the category devices list, click on it, OK.
3.b In a new window name "Select Network Adapter", choose "Have Disk..." then browse the path of folder Ralink has installed. Your will see a file "netr7364.inf" (may be in XP-32bit or Win7 32bit you will a difference *.inf file). Click on it, click open, then OK.
3.c In the left box, find Ralink Technology Corp. click on it, the find RT73 USB Wireless LAN card, then click NEXT, a "Update Driver Warning" pop-up will appears, just click yes. Then windows will install the driver for Sony UWA-NA1 as "RT73 USB Wireless Card". Good luck! (You may try another devices in the list at your own at risk)P/s: Sorry for my bad english! English is not my primary language.
Jul 08, 2009 | Sony Computers & Internet
Does my HP s7750 have wireless internet connection. if so how do i turn it on or if not do i need to buy a wireless usb adaptor
check the box that the machine was packed. if you find a antenna, then, your machine have wireless LAN.
to set up the Wireless
1 Click the Windows Start Button on the taskbar.
2 Type Device Manager into the Search box, and then click Device Manager to open
the Device Manager window.
3 Click Network adapters. Your WLAN device should be listed here. The WLAN
device may include the term wireless, wireless LAN, or 802.11.
4 Click the Windows Start Button on the taskbar.
5 Type Network and Sharing Center into the Search box, and then click Network
and Sharing Center
to open the Network and Sharing Center window.
6 Click Add a device to the network and follow any onscreen instructions.
For more information about setting up a wireless network:
 Click the Windows Start Button on the taskbar, click Help and Support, and
then type Setting up a wireless network into the Search Help box.
NOTE: If no WLAN device is listed, either your computer does not have an integrated
WLAN device, or the driver for the device is not properly installed.
Feb 26, 2009 | HP Computers & Internet
Lan network card not working
yellow mark signifies
Driver Problems
or
Hardware Resource /IRQ problems
Choose properties of the device on device manager for details
regards
-Mayank
Nov 29, 2008 | Acer 91.AB370.001 Network Adapter
LAN CARD ADAPTOR IS MISSING AFTER FORMATING TO XP PRO
Not sure I understand you what you mean. Let me recap:
1) Your LAN adaptor was working before you reloaded Windows XP Pro.
2) Now it’s not showing up in “Device Manager”.
If this is the case, there must be some software driver missing. Make sure there are no other devices that have an error. Double check Dell’s website at www.support.dell.com and select "I'm looking for drivers and downloads". If you don't have the proper version of Adobe you will be prompted to install it. Once installed return to "drivers and downloads" and enter the "service tag", (serial number) of the laptop. Dell keeps a listing of drivers for every customer's computer they sell.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 03, 2008 | Dell Inspiron 1100 Notebook
Wireless never worked in Acer Aspire 3000 notebook ..help!
you have to install the wireless drivers, check it on cd
Oct 15, 2008 | Acer Aspire 3000 Notebook
Samsung WIS12ABGNX Wireless USB 2.0 LAN Adapter [WIS12ABGNX/XAA] Logo
59 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
