Question about Edifier M1360
Edifier M1360 wont work
It wont work any more. somethings wrong inside. i barely use it. when i plug it and turn on. there's no sound and the green light doesnt show on the controller.
No sound playing from either speaker on the Edifier Multimedia Speaker M3300 setup.
Go to http://www.edifier.ca/french/speakers/m3300/m3300-EN-FR-manual.pdf and check the troubleshooting guide. I notice it says to check to make sure the mute button on the remote is off. Try it without the remote plugged in, also. Try hooking up another device with a headphone jack like an mp3 player. The only other thingI can think of would be a blown fuse, which sometimes lets a small signal through with some amps, but I don't see any fuse holder.
Dec 09, 2014 | Edifier Audio Players & Recorders
My Edifier M1360 speakers will only work when plugged into the headphone jack and I can't get all three speakers working at the same time. What can I do?
the sub woofer green 1/8 inch plug goes into the audio card either the front or the back of the pc. the jack it plug into is normally the green one. the two speakers normally join together on one card and plug into the subwoofer. also look for a on/off know to the speakers for power. normally on one of the little speakers. make sure it is on.
Nov 09, 2014 | Edifier M1360 2.1 Multimedia Speaker...
No side speakers
Make sure you test your wires and that they are running paralel, un wire and rewire, and make sure no speaker wire is exposed or touching.
Dec 12, 2013 | Edifier M1360
The plug works because the socket switch is turned on and the volume control button is green but when I plug in the auxiliary cable there's no sound? Is there something wrong with the inside of the...
Was the second aux cable you tried new or old? If both aux cables were older, you might possibly want to try (not necessarily buy) plugging in a new one. If you have done that: How old is this receiver? Brand new or older, if older it could be build-up inside the jack causing a break in the connection between jack and aux cable. If this is the case then a simple cleaning with a Q-tip and some alcohol could help immensely. If that's not the case, it sounds like you could have a short in the jack.
Jul 13, 2011 | Audio Players & Recorders
When I bought the dryer 18 months ago it came with a 3 wire plug and the green ground was attached seperately (not part of the plug). We just moved and the house has a 4 plug setup. I bought a 4 wire plug...
Good day,
You wired it correctly. The original setup you had, used a 3 prong, and the white wire could serve as a ground, since all green wires and white wires connect to the same place on the circuit breaker panel.
Adding an additional green wire from the cabinet to a grounding location, such as a bare cold water pipe is just added safety.
There might be something wrong inside the dryer, but to be safe, you should have the outlet checked, to make sure the white(common wire) didn't lift off ground potential, and you have a true 230 volts from red to black, and 115 from both white to red, and white to black at the outlet.
Dec 23, 2009 | Washing Machines
Motherboard sound issues
Hi antlob,
Normally one would think something is wrong but if you look at page 2-23 in you're manual you'll see you're using the wrong plug-in (Lime green) (Rear). Plug you're spreaker jack into the
(Black sound out jack). See if that makes a differance?
To fine tune you're sound you can open Asus/RealTek sound effect manager listed in control manager. This program has connector sensing software & other goodies.
Enjoy!
Mike
Jul 20, 2008 | ASUS M2N-E SLi Motherboard
Black screen
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
aqrtyctr-107
Jun 12, 2008 | Nintendo Wii Console
Psp
it means ur psp is bricked u need a pandora batery and a magic memry card it may sound stupid but it work look it up on you tube
Jan 07, 2008 | Sony PlayStation Portable (PSP) Console
Speakers don't work after getting unplugged once! Light doesn't turn on, etc.
Well it sounds to me like you got them in the wrong plug try a diferent one it wont hurt
Dec 01, 2007 | Dell A215 Computer Speakers
Edifier M1360 Logo
47 people viewed this question
Top Edifier Audio Players & Recorders Experts
David Payne
David Payne
Robert Graf
IT Solution
IT Solution
Are you an Edifier Audio Player and Recorder Expert? Answer questions, earn points and help others
