Question about Philips Desktop 720-T Desktop Cassette Transcriber / Recorder
Only fast forward functions, auto rewind doesn't work
Model mp820 mp3 player. how do I fast forward?
Cheapo MP3 play with rewind and fast forward - Tablets and e ...
forums.digitalspy.co.uk/showthread.php?t=1687936
Digital Spy Jul 5, 2012 - 13 posts - ‎2 authors
Cheapo MP3 play with rewind and fast forward Tablets and e-Readers. ... can anyone recommend a cheap MP3 player that will allow you to fast forward, ... the yepp yp55 t had a wonderful "scroll through" function that took ...
Oct 20, 2015 | Coby Audio Players & Recorders
How do I get fast forward & rewinds to work on my Teac W450-R dual cassette deck..?
Check the belts, inside the unit you should see a rubber belt which is what pulls the tape fast forward or rewind. Some belts with time get loose and slip, they can also break and fall off which will not let you fast forward or rewind.
Open your cassette player and look where the plastic pulleys are located and check for the belts, they might not be broken at all but very loose and slip on the plastic pulley.
Jun 07, 2015 | Teac Audio Players & Recorders
My tape player doesn't play anymore,
There are end sensors in the unit that are fed by a lamp and they burn out - I am guessing the lamp is out in the center of the tape.
There could be other reasons but without seeing the unit I can not determine remotely. I have repaired thousands of VCR in my 40 years in service.
Aug 09, 2012 | Televison & Video
Rewind and fast forward dont work
either a bad belt if used or the drive idler with this function is worn or slipping. It is called a transport problem.
Jun 12, 2012 | Samsung DVD-VR357
Hi, I am seeking the region free code for a Samsung DVD-D530? Thanks!
I tried the above steps, but each time when restarting the DVD player, it said 'reset' and asked for the language to be selected again. Pressing the "Fast Forward Fast Rewind Fast Forward Up Down" sequence caused the player to lock up and require powering off at the wall.
I found on another web site that there are different initial sequences. Once I use the one for Region 2, it worked fine.
I found the instructions below on another web site, but it worked for me...
  • Make sure there is no disc in the player.
  • Turn on the player (you can use remote control or front panel, it doesn't matter)
  • Wait for "No Disc" message to appear on the TV screen.
  • Press the Repeat button on remote (plain, not A-B).
  • Press the correct sequence of buttons of remote according to the original region code of your player (it's on the sticker on the back panel of the player). FF = fast forward, FR = fast rewind.
    • Region 2 players: FF, FR, FF, UP, DOWN
    • Region 3 players: FF, PLAY, FR, UP, LEFT
    • Region 4 players: FR, PLAY, DOWN, DOWN, RIGHT
    • Region 5 players: FF, UP, DOWN, STOP, RIGHT
    • Region 6 players: LEFT, RIGHT, RIGHT, PLAY, LEFT
  • If you pressed the correct sequence, a small white number 0 will appear somewhere on the top right of the screen. The white number 0 of the same font and size as the "No Disc" message, so don't confuse with the red "not allowed" sign that would appear when you press a function that's not available.
  • Turn the player off and on again, then you can pop in a DVD of any region and watch immediately.
Apr 30, 2011 | Samsung Televison & Video
The dictaphone wont rewind or fast forward and makes a bleeping noise
Does the tape move when you press rewind or fast forward.
If the tape moves for a few seconds then bleeps it sound like a sensor problem.
If it only bleeps when the rewind and fast forward are pressed and the play is ok it sounds like the actuator motor is faulty,this motor enables the rewind and fast forward.
Hope this helps.
Dec 07, 2010 | Dictaphone 1740 Desktop Cassette...
Numark CDX Search (for fast forward and rewind) not working.
Possible switch fault or servo problem,if you havent had it repaired you can send it to us.
Regards.
http://www.audiovisualservices.info/
Nov 15, 2008 | Nu Mark Numark Cdx Table Top CD Player CD...
VHS tape won't play or rewind
I work at the History Channel and have  a VHS that had the same troubles. I need it desperately for the show I am working on. I tapped it on a table fast forwarded it and presto! Tape fixed, crisis averted. Thank you, Thank you, thank you.
Feb 28, 2008 | Televison & Video
No playback on DCR-TRV103
In playback mode the lCD displays the battery time, hi8 symbol and the tape counter. all the functions work the tape will play, rewind, fast forward. The screen stays blank on playback and the tape counter stays at 0:00:00 eventhough I can see the tape turning. I also hooke the camera to my tv and I got no picture.
Dec 23, 2007 | Sony Handycam DCR-TRV103 Digital Camcorder
Philips Desktop 720-T Desktop Cassette Transcriber / Recorder Logo
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
