Question about Dishwashers
Brandt interaxio Due to a power surge, my Brandt interaxio dishwasher has stopped working at all. Does it have a power protection fuse that I can replace, or is it totally damaged? Is there a way to know?
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 125 Answers
Yes and yes
go to the companys website and click on the contact tab , get the number
then call them
Posted on Nov 22, 2013
SOURCE: brandt dishwasher
The lights on my dishwasher are working but It doesn't do anything when I hit start.
Posted on Jul 11, 2009
SOURCE: NEED USER GUIDE FOR BRANDT DISHWASHER DWF681WU
http://www.brandtuk.com/pdf/DWF681.pdf
Posted on Sep 05, 2009
Testimonial: "thanks just what i wanted"
SOURCE: how to replace a kleenmaid brandt dishwasher door handle
Go to www.espares.co.uk
Look for "Dishwasher Door Handle Opening Pedal" - Genuine spare part for select Blomberg and Hygena dishwashers.
This is the part you need for a Kleenmaid/Brandt DW3 dishwasher.
Posted on Feb 04, 2010
  • 128 Answers
SOURCE: Dishwasher will not start cycle.
OK so you have power, your door interlock switch is working, the intake solenoid is operating.
The issue is that the cycle does not start. This would indicate that your timer is not advancing. The timer tells the machine what to do, when, and for how long. It is not advancing and is stuck at the start of the wash cycle (fill with water). This is not a big issue as a timer is usually easy to replace.
I don't know what type of machine you have so I don't know if is a mechanical or a digital timer.
If mechanical dial type you can simply tun the dial and see if the cycles change. If so for sure you timer is the issue. You simply remove and replace.
Digital is harder to check but from what you say it is most likely your timer.
Shut the breaker off.
Remove the screws from the door frame and from inside the door. Gently remove the control panel. The timer is a simple unit to remove. Unscrew it and disconnect the power supply. Go get a new one from your local parts supplier. Installation is the reverse of removal.
Hope this helps, if so please rate this answer.
Posted on Mar 20, 2010
SOURCE: How can I fit a bottom door seal on a Brandt
If the bottom seal is definitely worn then it is quite a simple job.The seal is just pushed into a groove at the bottom of the door,as you pull the old one out be very careful as the edge of the groove is like a knife edge,the new seal will push in gently starting from one end and keep pushing into the groove try not to stretch the seal in length.Another thing to check first is check the bottom spray arm for splits on the edges as this could be directing the water onto the door,if there are splits then the arm will need replacing.
Hope this helps.
Posted on May 27, 2010
Testimonial: "Thanks for the prompt response. Have checked the spray arm, it is intact and the door seal appears to be aswell. Reluctantly i will have to call an engineer."
Can anyone direct me to an operating manual for the Brandt Wine Chiller?
Search Results
    Download brandt wine chiller manual - Google Docs
    https://docs.google.com/document/d/.../edit Google Docs, Sheets, and SlidesLooking for brandt wine chiller manual? Download brandt wine chiller manual.brandt wine chiller manual. User Manuals, Instructions and Guides.We have that ...
    brandt manual Refrigerators Questions & Answers - Fixya
    www.fixya.com > Forum > Tags > brandt manual
    On my Brandt wine cooler at the top is an adjustment control for temperature. ... is amanual for this refrigerator LG top mount ice box service manual Maytag ...
    Free Refrigerator User Manuals ' ManualsOnline.com
Dec 14, 2015 | Refrigerators
I have a Brandt 1200 series coin counter that won't turn on. The display works, just won't start. Does anyone have a service manual or solution to the problem?
I work for the former Brandt company, now called Glory.
Let me be clear on this. The Brandt/Glory company makes the best counters on the planet. That being said the model 1200 is the worst design ever. I never liked it and it's been last made 25 years ago.
Lets start simple. In the back of the machine there are 2 fuses. F1 protects the motor and is a 3 amp fuse. F2 is a 1/2 amp fuse to protect the display. Make sure they are good.
Next you'll have to take the back off to see if the belt is broke or the pulley fell off. Or, the motor plug has come loose?
Do a machine reset by unpluging the power cord. Then while pressing and holding the "C" key, plug the machine back in and wait 5 seconds. If the above does not help at all, you have more serious problems like bad motor, bad motor controller.
You can try calling me at nine8five 8ninethree 5two4one
Good luck
Jun 10, 2015 | Retail Supplies
Where can I get a manual for a Glory Brandt 8672 currency counter?
Let me set the record straight. Brandt invented the 8672, one of the best machines of all time. Unfortunately it was way over priced. Brandt was in business for over 110 years and then sold out to the employees of the company who then sold out to the DeLaRue company in England. DeLaRue then sold out to Talaris. And, finally, Talaris sold out to Glory two years ago. However, the 8672 stopped production before Glory became the owner. All the above took place over 15 year period. Got all that!!
Now back to your question. What kind of manual do you need? I would need to know the full model and serial number for the correct manual.
If your counter say Brandt on it, that is very old. The newest version has the name Talaris on it. Spare parts can be had, but are very rare and somewhat expensive since the machine is no longer made. Here is a picture of a 8672. Good luck.....
Mar 11, 2015 | Brandt 8672 Note Counter
How to save setting on brandt 8672
The 8672 is a terrific machine. Once you change any setting it will automatically save it as the new default setting when powered up.
Oct 12, 2014 | Brandt 8672 Note Counter
I have a Brandt dishwasher and need a users manuel in English I only have a French one how can Idownload one in English No EN50242 Modle no DFM 1020
You could always scan it in as a pdf then convert that to a word then select all text and use a translator program to give you the english version. Or you can contact Brandt and see if they have a English file they could email you.
May 02, 2011 | Dishwashers
How to replace a kleenmaid brandt dishwasher door handle
Jan 22, 2010 | Dishwashers
Dishwashers Logo
79 people viewed this question
Top Dishwashers Experts
