Question about Whirlpool Duet WED9150WW 6.7 Cu. Ft. Electric Dryer - White
Whirlpool duet dryer doesn't work after power surge
So we had a power surge about a month ago and when I went to check my dryer it doesn't function. The only thing that works on it is the light on the inside of the dryer when you open the door. I push the buttons on the control pannel and I get nothing at all. So would it be my control pannel that has to be fixed or does it sound like more than that? And if its just the control pannel would it be worth it to get a appliance repair man to come fix it or can I fix it myself?
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 36 Answers
Hello, well that sounds a fuse problem, you can try check inside, be shore you unplug the power socket before you do it, if the inside fuse is ok ,so the control board is damage and needs to be replaced, and don't think it worth .
Thanks
Posted on Nov 22, 2013
SOURCE: Whirlpool duet electric dryer, not getting any power
Mine shows a faint light behind the control locked indicator and the timer is dimly lit on the two middle horizontal bars (middle of the eights). They go off by pushing various button combos. If I unplug it for a week I can get the control to work for a few minutes.
I replaced the control board, it worked for 5 minutes, then back to nothing. I want to replace the interface but would rather not waste any more money.
I dont want to check every wire for continuity. If someone has fixed this problem, please let me know.
Posted on Aug 15, 2008
  • 249 Answers
SOURCE: whirlpool duet dryer wont start
sounds like the door switch
Posted on Nov 30, 2008
SOURCE: Whirlpool dryer model LEQ8800JQ won't start when push start butto
I posted today (Jan 2, 2009) that I had same problem. Handyman tested for blown thermal fuse, etc and everything was fine. He said I have to replace the timer switch .. well guess what - I fidgeted with the start button (on/off) hard a few times while simultaneously pressing & releasing door switch and it did the trick. In my case the problem was most likely with the start button. Dryer is working fine now!
Posted on Jan 03, 2009
jumptrout51
  • 3361 Answers
SOURCE: Control Panel in my whirlpool duet dryer model
First check for 220 volts incoming power to the dryer at the terminal block on the rear of the dryer.
If you have 220 volts,check continuity on part number 59(thermal fuse) in the attached diagram. No continuity is a bad part.
cut and paste this link to your dryer diagram.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5139909&diagram_id=951915#d951915
Posted on Jul 24, 2010
blueextc3221
  • 15935 Answers
SOURCE: Whirlpool duet dryer does not run. The control
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 30, 2010
-Check your power source. make sure is not over load.
-Or disconnect main power and open back panel to visual check
all wire and connector. Possibly shock some where.
Good luck
Mai
Dec 20, 2013 | Dryers
Whirlpool duet electric dryer turns on but doesn't
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 01, 2011 | Whirlpool Dryers
I press the start button on my whirlpool duet dryer and it beeps, but doesn't start
This is a common issue caused by a blown thermal fuse located on the blower housing and wired in series with the motor. Power to the motor is then cut and therefore cannot run. No dryer function works when the motor cannot run. Click on the link below for the complete details of the troubleshooting and repair procedure.
Whirlpool Duet and Kenmore Elite Electric Dryers Not Starting
Aug 13, 2011 | Whirlpool GEW9250 Electric Dryer
Dryer will not start when pushing start button it just clicks once
This sounds like a problem with the thermal fuse blown which is wired in series with the motor. Power to the motor is terminated when the thermal fuse blows and the motor cannot run. No dryer function works when the motor cannot run. Click on the link below for the detailed instructions in troubleshooting this kind of Whirlpool Duet or Kenmore Elite dryer problem.
Troubleshooting Whirlpool Duet and Kenmore Elite Electric Dryers Not Starting
Mar 23, 2011 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
The dryer won't start, when I push the start button is just beeps. I checked the door and it's shut and nothing is in the way. It was working a few hours ago. We had a bump in the power earlier today...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Feb 22, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Brand New Whirlpool Duet 9450 Error Code PF
This is a problem I've seen before, or something similar. I think you've got a bad connection on the neutral wire. Either in the plug or at the panel. Have electrician check the neutral wire back to the panel from the plug.
Jul 25, 2009 | Dryers
Whirlpool Duet HT Front Load Washer- won't start
remove the plug of the machine from the power outlet and plug it after 10minutes and then check .
if the frontpannel screen shows any error codes or any lights flashing check out this link
http://www.applianceaid.com/frigidaire_frontload_washer5.html
also check out this link for more help
http://www.applianceaid.com/frigidaire_frontload_washer.html
thanks.
Oct 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Imperial Electric Dryer won't start
I have a problem with my Whirlpool IMperial electric dryer, not a Duet gas dryer.
Jul 12, 2008 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool Duet Sportwon't respond after power outage
IF YOUR MACHINE IS A WHIRLPOOL DUET TRY THIS ;
To unlock the controls
Select and hold END OF CYCLE SIGNAL for 3 seconds until the
CONTROL LOCKED status light turns off.
Good luck
Jun 05, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet dryer does not run after power surge/overvoltage
Swb, unplug the dryer, remove the top by removing the 3 screws in back. Slide it off toward the back. On the left will be the main board. Remove the metal cover on the board. On the board you will see P1-5 black wire (L1 line in voltage. You will also see P1-2 white wire (nuetral). With a voltage meter see if you have 120V from that black to white. If you do, you have power going in, nothing coming out, replace the board. Now Im going on that fact that you have no display lights, the dryer is completely non responsive. Catriver
Dec 20, 2007 | Whirlpool GEW9250 Electric Dryer
Whirlpool Duet WED9150WW 6.7 Cu. Ft. Electric Dryer - White Logo
116 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
