Question about ECS Computers & Internet
Motherboard confuchion i got the cooler master 430 elite tower case for a Narra6-GL6 motherboard but i cant find the pin configuration for the power,re-set and led's on the board on the f panel. is there a manual some ware?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • ECS Master
  • 2,226 Answers
Http://www.asus.com/Motherboards/M2N68/HelpDesk_Manual/
Posted on May 11, 2014
map9966
  • 2351 Answers
SOURCE: Front panel connections
Hi sjcrofts,
The most common problem for most people is knowing what wire color is positive & which wire color is negative. The colors blue, red, green, light blue, light red & light green are normally positive. The color white & black are negative. Your board uses only 2-pin connectors. The 3-pin power connector can be turned into a 2-pin connector to work with the M848ALU pins.
(Page 13, PANEL1). How to? Take the three pin connector, on the back side of the connector you'll see a small tab that holds the wire into the connector. Use a needle & pull tab up while pulling the wire out at the same time. The wire should slide out. Insert the wire back into the connector next to the other wire. You do not need to hook up the SUS led which stands for suspend.
Pin 1 is positive & the manual shows this by adding the _P = positive.
Pin 3 which is to the right of pin 1, is negative for the hard drive led. Pins 9 & 10 are not used.
Good luck sjcrofts!
Mike
Posted on Nov 30, 2008
compdoctor20
  • 172 Answers
SOURCE: Connecting the case to my motherboard
Pin arrangment is Industry Standard Architecture.....
pwr led pwr sw N/C
X X X X O
X X X X O
hdd rst N/C
translated this is top row left to right ...... power led, power switch no connection
Bottom row is left to right........ hard drive, reset, no connection
Note: not all computer cases have a reset button, also the connectors for power led and hard drive produce a light, if the light does not show, power off the pc swithc the cable rooun 180deg on the connector pins and reconnect.
Posted on Dec 05, 2008
SOURCE: Gigabyte GA-8INXP Motherboard Problem- front connector pins
If the wires from the reset switch is white/blue the blue wire is positive, Hdd red/white red is positive power Green/white Green is positive etc. The wires on the speaker connector will be red/black/black/white - red is positive. The colored wire is always positive. On all GA mb's the positive connection is always towards the back of the MB and are marked with a + on the base of the pin as you can see on the photo. Hope this help.
ericram
  • 101 Answers
You can download the complete user manual in English from the manufacturer's website at this link:)
http://support.asus.com/download/download_item_4.aspx?product=1&model=P4B533&SLanguage=en-us&os=17
The front panel connector pinout is on page 2-33, or page 59 in the PDF file. You should have mor ethan enough information to make all the connections you need.
Posted on Jan 02, 2009
  • 165 Answers
SOURCE: Intel Desktop Board D845GERG2 Motherboard front panel plugins
Here is the pinout
http://support.intel.com/support/motherboards/desktop/sb/CS-009016.htm
Posted on Jan 27, 2009
What battery is used for CMOS?
CR2032 this is the commonly used battery in the motherboards
May 05, 2014 | HP Pegatron M2n68-la Motherboard...
How do i restore a diablotek elite atx mid tower to factory settings
Cases don't have "factory settings." This sounds like a problem with the motherboard configuration. Make sure to re-check all your pin connectors leading to USB, Audio, and HD. Also, you may need to remove the MB to check if there's any damage, and to be sure that you don't have a short somewhere.
Jan 14, 2013 | Diablotek Elite 450W PSU ATX Mid Tower...
Where do i plug in the components from the computer case on my motherboard?
There are a few things you will need to plug: HDD LED, POWER LED, POWER SWITCH, RESET SWITCH. There are others such as USB and Audio. All of the pins locations and settings should be available on the motherboard manual. The pins should usually be located near the battery on your motherboard. ALL of the pin's settings will be labeled underneath the pins, but often hard to see, that's why I recommend reading the manual. The USB, if you have ones that are all separate connectors, goes like this: [+5V/VCC/Power] [D+] [D-] [GND].
Feb 21, 2010 | Aspire X-DISCOVERY-AL ATX Mid-Tower Case
Im trying to install dell i530 into Xion II case but cant figure out how the power switch led hooks up?
All of the pins locations and settings should be available on the motherboard manual. The pins should usually be located at the very bottom. ALL of the pin's settings will be labeled underneath the pins, but often hard to see, that's why I recommend reading the manual. All of the switches and LED pins will be different on different motherboards. The USB, if you have ones that are all separate connectors, goes like this: [+5V/VCC/Power] [D+] [D-] [GND]. USB and audio will always be the same.
Feb 17, 2010 | XION II Black Pearl ATX Mid-Tower Case
Cooler makes noise,when it rotates.please help.
Stop beating up the tower before you damage the harddisk! If the case/PSU is out of warranty, take the PSU out and get the fan replaced. You can do it yourself, just observe the arrow direction on the fan (usually the round label should point out) and wire colors (the fan should blow out). Observe also all the precautions since the capacitors inside can hold a significant charge.
Nov 10, 2009 | Cooler Master Extreme 430 RS-430-PMSR...
Power supply compatible with cooler master cac-t05-uw
Power supplies are not matched to a case. Any one you buy will fit in the case. You need to make sure it has the correct power capacity and plugs for your motherboard, video card, and anything else you will have plugged into it.
Mar 27, 2009 | Cooler Master CAC-T05-UW ATX Mid-Tower...
Computers & Internet Logo
200 people viewed this question
Top ECS Computers & Internet Experts
David
David
WTF Chuck.....
WTF Chuck.....
Coss
Are you an ECS Computer and Internet Expert? Answer questions, earn points and help others
