Question about Ford Vehicle Parts & Accessories
1994 f150 4.9 oil pan replacement
I have a 1994 f150 4.9 and would like to know how to replace the oil pan.
    Novelist:
  • 157 Answers
Is this an oil leak??? theres no pressure at the oil pan gasket. you must lift the engine for access and support it higher in the motor mount area. but first obtain some oil dye and a blacklight. having all the likely leaks fixed may dissuede you from pulling the pan...especially if its a rear main. please provide more info or seek diagnostic "hands on" help. clean the engine and let it repeat its leak mess so you can trace it to its source
Posted on Nov 22, 2013
Oil leaks from 1994 Jeep Grand Cherokee. I tightened oil pan bolts, other various bolts behind pan, still leaks large drops after shut off engine. Pressure is ok, oil level pretty good still (1/2 qt. a...
Sounds like the rear main oil seal on your motor is leaking. In order for it to be replaced, the transmission has to be removed. Not an easy task for the backyard mechanic.
Nov 06, 2011 | 1994 Jeep Grand Cherokee
How do you change the oil pan gasket on 1994 trooper?
take the oil pan off ,scrap old gasket off with a plastic putty knife and replace with newone. put a bead of gasket seal on first.
May 20, 2011 | 1994 Isuzu Trooper
How to locate and replace oil pump on a 1994 chevy corsica
locating the oil pump is easy, its in the oil pan under the engine, why does it need replacing???
Jun 30, 2010 | 1994 Chevrolet Corsica
Oil pan leak on 1994 bronco with a 5.0 liter
Oil Pan Removal
  1. Remove the bolts attaching the fan shroud (8146) to the radiator (8005) and position the fan shroud over the fan assembly.
  2. Raise vehicle.
  3. Remove exhaust manifold-to-exhaust pipe.
  4. Disconnect the oil cooler line at the left side of the radiator if equipped with an automatic transmission (7003).
  5. Remove the nuts and lockwashers attaching the engine support insulators to the chassis bracket.
  6. Drain the crankcase.
  7. Loosen transmission mounting nuts.
  8. Raise the engine (6007) and place wood blocks securely under the engine supports.
  9. Remove the oil pan attaching bolts and lower the oil pan (6675) onto the crossmember.
  10. Remove the oil pan from the vehicle.
Apr 07, 2010 | 1994 Ford Bronco
I NEED TO KNOW THE TORQUE SPECS FOR THE OIL PAN ON A 1994 BUICK LESABRE 3.8 L. V6
Exploded view of the oil pan and related components - 1993 vehicle shown
* If removed, install the oil pump pipe and screen. Secure with the retaining bolt(s) and tighten to 89 inch lbs. (10 Nm).
* Place a new formed rubber gasket in the oil pan flange.
* Position the oil pan and secure with the oil pan-to-engine bolts. Tighten the bolts to 124 inch lbs. (14 Nm). Do NOT overtighten the bolts, as this will damage the oil pan, causing a leak.
Hope help with this (remembere rated and comment this help).
Mar 08, 2010 | 1994 Buick LeSabre
My 1994 Honda Accord has been leaking about a quart of oil every two weeks. I had the oil pan replaced and it is still leaking. Last week, I replaced the spark plugs and three of the wire holes on top of...
your need a valve cover gasket set. It comes with 4 rubber seals for the spark plug tower so oil does not leak on the plugs. Common problem, Simple to fix. Takes about an hour
Nov 12, 2009 | 1994 Honda Accord
Oil pump change
take long bolts out that run thru motor mounts ,jack in front of motor all bolts in oil pan out, remove oil pan and then remove oil pump, replace new pump ,torque to specs, replace oil place with new pan gasket , bolts back thru mounts and ready to go, hope to help, thanks robert b.
Jul 06, 2009 | 1994 Buick LeSabre
Gasket needs replacing
then you need to replace the gaskets drain oil from oil pan take all bolts out and drop the pan as far as valve pan covers buy rubber gaskets not cork they are a lot more pliable and less prone to leak
May 22, 2009 | 1994 Ford Aspire
1994 Ford Taurus 3.0 Oil Light and pressure
Yes, the oil pump is accessible when the oil pan is removed and at those miles it would be a good preventive maintenance idea to replace the oil pump.
Secondly, you should shop around for a better price. $332.00 seems a little high.
With an oil pump replacement, the pan gasket and the oil change should be included in the price, seeing as how those items are removed anyway.
As with any auto repair, its buyer beware. the crooks count on the fact that you don't know what is involved with the repair, or else you would have done it yourself.
Good luck
Aduz
Mar 25, 2009 | 1994 Ford Taurus
Vehicle Parts & Accessories Logo
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
