Polygon motor inside the LSU does not rotate.panasonic kxmb772
3 Suggested Answers
  • 110 Answers
SOURCE: laser unit polygon motor failure
This error usually means that the laser unit on the machine has failed. Just replace the laser unit part number 116-1110-00
Posted on Oct 22, 2009
  • 22 Answers
SOURCE: the polygon motor can't rotate
Polygon motors are not serviceable items.
If the motor won't turn unless forced then you really need to get it replaced.
The bearings inside the motor can wear out causing excessive noise or seizure.
hope this helps
Posted on Feb 10, 2011
How to solve error c4000 for Kyocera KM-2035 copier? it has stopped
c4000
The Problem:
inside the laser unit Polygon motor synchronization problem
The polygon motor does not reach the
stable speed within 15 s of the START
signal turning on
Causes:
1-Poor contact in the
polygon motor connector
terminals.
Reinsert the connector. Also check for continuity
within the connector cable. If none,
remedy or replace the cable
2-Defective polygon
motor.
Replace the polygon moter or LSU.
May 29, 2014 | Kyocera KM-1505 Copier
What is err0r code E 7 02 IN ARM 450 COPIER
The E7-02 means the beam detect sensor never received a beam from the laser. As the previous poster stated you'll need a new laser unit. Meaning that you need to change the whole laser unit but not the polygon motor.
E7 02 Content Laser trouble
Detail BD signal from LSU is kept OFF, or ON.
Cause The connector of LSU or the harness in LSU
is disconnected or broken.
The polygon motor does not rotate normally.
The laser home position sensor in LSU is
shifted.
The proper voltage is not supplied to the
power line for laser.
Laser emitting diode trouble
PCU PWB trouble
Controller PWB trouble
Check and
remedy
Check for disconnection of the LSU
connector.
Use DIAG (SIM 61-1) to check LSU
operation.
Check that the polygon motor rotates
normally or not.
Check light emission of laser emitting diode.
Replace the LSU unit.
Replace the PCU PWB.
Replace the Controller PWB.
Mar 15, 2010 | Toshiba E-STUDIO 650 Copier
What does error code L6-10 mean on a Sharp AR-235 copier? Would it be worth fixing? Thanks
L6-10 Content Polygon motor lock detection
Detail
It is judged that the polygon motor lock signal
is not outputted.
Lock signal is checked in the interval of
10sec after starting the polygon motor, and it
is judged that the polygon motor does not
rotate normally.
Cause
The LSU connector or harness in the LSU is
Polygon motor trouble
Check and
remedy
Use DIAG (SIM61-1) to check the polygon
motor operation.
Check connector and harness connection.
Replace LSU.
Jan 24, 2010 | Sharp AR-235 Copier
Not able to print. printer pop up says Lsu error
The LSU error stands for Laser Scanner Unit error. The probable cause/s:
The Polygon motor in the LSU does not rotate.
The LSU’s laser beam is functioning properly.
What you can do:
Try to unplug the machine for a couple of minutes or maybe a little longer and then plug everything back in. Power on and then test.
Jan 14, 2010 | Samsung SCX-4216F All-In-One Laser Printer
LSU error
What you can do:
Jan 13, 2010 | Samsung SCX 4200 All-In-One Laser Printer
Hi we have a Sharp AR-M208 displaying error code L6-10. Need to know what that relates to and some basic trouble shooting to resolve. Thanks in advance!
L6-10 Content Polygon motor lock detection.
Detail It is judged that the polygon motor lock signal
is not outputted.
rotate normally.
Cause The LSU connector or harness in the LSU is
Check and
remedy Use DIAG (SIM61-1) to check the polygon
motor operation.
Replace LSU.
Jan 10, 2010 | Sharp AR-M208N Copier
Sharp AR-M205 - Error Code L6
L6 10 Content Polygon motor lock detected Detail It was judged that there is no output of polygon motor lock signal of LSU. The lock signal was checked at about 10-second intervals after the polygon motor started rotating. As result, it was judged that the polygon motor failed to operate normally. Cause Disconnected connecter to LSU or detached harness inside LSU or broken wire. Polygon motor defective Check and remedy Check polygon motor operation with SIM61-1. Check harness and connector for connection. Replace LSU if needed
Dec 14, 2009 | Sharp AR-M205 Copier
LSU ERROR MESSAGE ON little screen when photocopying
What you can do:
Mar 11, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Error LSU
What you can do:
Jul 03, 2008 | Samsung SCX-4100 All-In-One Laser Printer
Photocopier Sharp ar201 not working
L6 - Polygon Motor Lock: The lock signal (the specified rotation speed signal) is not supplies within the specified time (about 6 seconds) after starting the polygon motor rotation. LSU connector disconnection of harness disconnection in the LSU. Replace LSU.
Aug 01, 2007 | Sharp AR 201 Copier
87 people viewed this question
jasbo
jasbo
