Question about Panasonic Office Equipment & Supplies
Polygon motor error. panasonic kxmb772 Polygon motor call service 1
3 Suggested Answers
  • 110 Answers
SOURCE: laser unit polygon motor failure
This error usually means that the laser unit on the machine has failed. Just replace the laser unit part number 116-1110-00
Posted on Oct 22, 2009
cobra4silver
  • 51 Answers
SOURCE: Call Service 2 Panasonic Error Kx Mb772
Well here I give you the manual with the full list of errors.
Panasonic KB-MBxxx Manual
Posted on Jul 07, 2012
SHARP AR-M236 CALL SERVICE CODE L6-10
Hello I found this for your error code.
Code
L6-10
Description
Polygon motor lock trouble
The polygon motor does not rotate. The motor lock signal is detected for 6sec or more after the polygon motor rotates. The motor lock signal is detected for 1sec during rotation of the polygon motor.
Causes
Polygon motor unit failure Polygon motor connection, harness trouble or disconnection MCU PWB failure
I would unplug the unit for a minute and let it cool, then restart it and see if it was a temporary glitch or if the polygon motor has ceased to funtion. You might try to see if the wiring harness has come loose, otherwise you are looking for a new polygon motor.
Here is a copy of the service manual.It also suggests running a SIM 61-1.
https://www.manualslib.com/manual/1065394/Sharp-Ar-M236.html?page=100
I found a replacement motor for the machine, to give you an idea what it will cost to replace, keep in mind if you don't have the ability to replace this yourself you will have to call a repair tech to come in and do it and you may expect the cost for that to be at least the same as the motor.
http://www.precisionroller.com/motors-for-sharp-arm205/products.html
Hopefully it isn't a motor failure. Good luck.
Oct 18, 2017 | Sharp Office Equipment & Supplies
ERROR CODE L6
Polygon motor lock detection
Detail : The polygon motor does not rotate.
The motor lock signal is detected for 6sec after
rotation of the polygon motor. The motor lock
polygon motor.
Cause : Polygon motor unit abnormality
Improper connection or disconnection of the
polygon motor and the harness.
MCU PWB abnormality
Check and remedy : Use SIM 61-1 to check the polygon motor
operations.
Check connection of the polygon motor
harness/connector.
Replace the polygon motor..
Replace the MCU PWB.
Apr 30, 2014 | Sharp AR-M160 Laser Printer
Jul 06, 2012 | Panasonic Office Equipment & Supplies
SHARP-235, lp 6-10 CALL FOR SERVICE CODE...Sep 2010 ... What does error code L6-10 mean on a Sharp AR-235 ... my machine sharp a 235 say call for service lp 6-10 what dos it mean
L6 10 Content Polygon motor lock trouble
Details The polygon motor does not rotate.
Cause Polygon motor unit failure
Polygon motor connection harness trouble
or disconnection
MCU PWB failure
Check
and
remedy
Check the polygon motor operation with
SIM 61-1.
Check connector/harness of polygon
motor
If the polygon motor isn't working then you will neeto buy a new Laser Unit. They can be expensive if you can get one. To replace it will tak alot of disassembly as well. Might be better and more cost effective to get a new machine.
Oct 22, 2011 | Sharp AR-235 Copier
I have a toshiba photocopiar and this copiar problem disply of error L 6 10 code pl resolved/ solution problem
The polygon motor does not rotate. The motor lock signal is detected for 6sec after
rotation of the polygon motor. The motor lock signal is detected for 1sec during rotation of the
polygon motor.
Cause:
Improper connection or disconnection of the polygon motor and the harness.
MCU PWB abnormality
Check and remedy:
operations.
harness/connector.
Jun 02, 2011 | Toshiba e-Studio 161 Copier Copier
Error code E01-22
The error E01-22 means polygon motor synchronization error.
The possible causes for the error is problem with ;
- engine pcb
- laser unit
- lvps
- sc pcb
You can try to reseat the connectors, else you may need to replace the board.
Nov 04, 2010 | Panasonic Office Equipment & Supplies
Panasonic photo copier what does E01-22 error message mean
the polygon motor is at fault, this requires a service technician.
May 10, 2010 | Panasonic FP-D250F Copier
What does e0122 error code on panasonic workio dp 150 copier mean?
Hello :
polygon motor synchronization error. possible causes are :
1: engine pcb
2:laser unit
3: lvps
4: sc pcb
reseat all the connectors before starting to replace boards
please rate !
Apr 13, 2010 | Panasonic Workio DP-150PA Copier
I have a KX-FL612 FAX. It shows the error "Call Service 1"
its polygon motor is defective try to reset the m/c press menu#9000*550 set maybe it's work
Feb 11, 2010 | Panasonic KX-FL611 Plain Paper Laser Fax
Sharp AR-M205 - Error Code L6
L6 10 Content Polygon motor lock detected Detail It was judged that there is no output of polygon motor lock signal of LSU. The lock signal was checked at about 10-second intervals after the polygon motor started rotating. As result, it was judged that the polygon motor failed to operate normally. Cause Disconnected connecter to LSU or detached harness inside LSU or broken wire. Polygon motor defective Check and remedy Check polygon motor operation with SIM61-1. Check harness and connector for connection. Replace LSU if needed
Dec 14, 2009 | Sharp AR-M205 Copier
29 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
