Question about Video Cameras
Apphangb1 error when I try to run PIXELA videobrowser v1 or v2
I get the above error message when I try to run videobrowser.exe on WIN7 machine. [ apphang B1 ] Trying to use program with my CANON HF g10
3 Suggested Answers
SOURCE: i'm trying to install pixela on my computer and it
It is on the bottom of the Camcorder, just leave off the letters. Put in numbers only.
John
Posted on Nov 24, 2010
caroldon
  • 17130 Answers
SOURCE: The Pixela video browser provided with my Canon HF
As you had rightly confirmed there is a conflict in the software with your OS/graphic card and it needs to be checked if the CD contains any machine error. If you are able to check with the support site for a download try and see if this works out. If not check this CD on another PC to confirm the case of a faulty CD or software in which case you can lodge a complaint to the support customer center.
So please check this out first.
Posted on Oct 18, 2011
Avaya ip office 500 voice mail message fading in and out
Depending on which voice mail:
If you are using embedded mail then check connectivity with the line provider or upgrade system.
If you are using voicemail pro on a PC then check network traffic or connect PC directly to the IPO
Sep 16, 2013 | Avaya Embedded Voicemail for IP406 V2 and...
IF I HAVE A MOTOR WITH STAR DELTA WINDING AND NO LABELING IS DONE HOW WILL I CONNECT THE CABLES TO THE MOTOR
the motor will have 3 pairs that can be checked with a ohm meter for continuity. each pair has a start and a finish. usually it would be labelled U1 V1 & W1 for the start and U2 V2 & W2 for the end or finish.
To connect in star ( Motors that start with direct load ) supply cables to U1 ( Red ) V1 ( White ) W1 ( blue ) and bridge out U2 V2 & W2.
To connect in delta Supply cables as above. Bridge U2 to V1 - Bridge V2 to W1 - Bridge W2 to U1.
If you have a reversed winding the motor will growl and not turn.
To reverse direction of rotation swap any 2 supply cables ( But only when the power is OFF )
Mar 09, 2011 | Kitchen Ranges
Trying to run exe program and getting 0xc000007b error message. All other programs running perfectly. Already re-instal'd program. Recently upgraded from XP 32 > Win7 64 bit. Wondering if that has...
yeah it is possible ...the 7 still has issues...and all the programs that you install now ..has to be compatible with the Operating system and also with the 64 cpu u chosen to install ...
just look for aversion that will run ..thats all
Mar 11, 2010 | Computers & Internet
AppHang81 Error-help!
what version of windows are you using? state the version and servicepack. in the intrim, start your computer in safe mode and run some programs. shut down the computer and restart in normal mode.
Jan 02, 2010 | Compaq Presario CQ60-220US PC Laptop
Where to download Pixela Transfer Utility software?
instead you can use this utility (see download below). If you have a card reader in your PC then this utility makes live even easier....
http://users.telenet.be/truyens/
Jan 01, 2010 | Canon FS200 Flash Media Camcorder
Transformers primary winding broken. What the ratio? 230 VAC to ? VAC (10 VAC ??)
For transformers, the voltage to turns raio is calculated by formula:
V1 / N1 = V2 / N2 where,
V1 >> Voltage at primary
N1 >> number of turns at primary winding
V2 >> Output voltage at secondary
N2 >> No. of turns at secondary winding
So in your case:
V1 = 230 and V2 = 10. If you know the no of turns of winding at one side, you can calculate the turns on the other side.
Aug 12, 2009 | JVC RC-ST3 Cassette/CD Boombox
Sansa E250R doesn't recognize a 8GB card nor does my computer
Is you E280 V1 or V2? The V1 will only recognize up to 2GB. You can find this by going to settings, info. If the firmware number starts with 1 it's a V1. V2's start with 3.
If you have a V2 place the card in a card reader to format. Format card to FAT32. If not recognized by a card reader the card may be defective.
If the player is a V1 the micro SDHC can still be used by loading RockBox firmware. But note when running RockBox the sync port will be disabled. To use port the player can still be started in the Sansa firmware but a SDHC card will not be accessible.
http://www.sansaworld.com/
http://www.sansaworldmp3.com/
Apr 04, 2009 | SanDisk Sansa e250 MP3 Player
Video Cameras Logo
53 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
