Question about Konica Minolta bizhub Office Equipment & Supplies
Bizhub c451 print out is smudged with black in half page
Imaging unit shows toner
  • Konica Minolta Master
  • 6,680 Answers
How do you know the image unit shows toner???? Replace the black image unit
Posted on Mar 10, 2018
Inkworks
  • 87 Answers
SOURCE: HP Laserjet smudges across entire page
More than likely you have a bad toner cartridge.
Inkworks
866-381-0541
Posted on Nov 21, 2008
  • 43 Answers
SOURCE: Printing black smudges across the page at 10 cm intervals
Most likely cause by the drum unit. Replace drum or upgrade printer.
Posted on Jan 24, 2009
tigertail
  • 163 Answers
SOURCE: too much toner on paper which then smudges
Try reducing the print resolution using the menu buttons. Does it smudge with coloured prints? If so then the fuser unit is faulty. If it is only black that smudges it is likely to be the K Developer unit. Ensure that you are using genuine toners, not refills or third party as the quality of toner can cause similar results.
Posted on Feb 16, 2009
waqar697
  • 67 Answers
SOURCE: Konica Minolta BizHub C451 printing red lines down documents
your imaging unit is damaged. call minolta guys to have a look it at and change it if neccessary
Posted on Mar 30, 2009
SOURCE: hp laserjet 2420 printer printing completely black pages
remanufactured / compatible toner? sounds like defects to me. try OEM, or another supplier
Posted on Apr 05, 2009
My Konica bizhub c451 is showing p6p7p9p8 and it keeps sterbilizing without showing ready to copy pleas what do I do
Check the Transfer Belt assy,
Remove and Clean properly
Remove all Imaging Unit and shake properly and put it again.
P6/7/8/9 indicating all Imaging units are not in good condition.
So at warmup, color patch not getting properly generated
Dec 22, 2016 | Konica Minolta Bizhub C451 Copy-print-scan
My bizhub c451 is still printing only cyan and black after we change toner catridge, what could be the problem please
The problem could be the laser that scans the image or the detectors that see the colors. It could also be a problem with the power supply or the main board. This is not going to be cheap. If you want to continue, you should download the service manual.
http://www.printcopy.info/?mod=docs&brand=Konica-Minolta&gID=15037
Jul 20, 2015 | Konica Minolta Bizhub C451...
What's your question? my konica minolta c451e printing machine showed me an error code p21, what could that mean and it is not printing any image but black-green shade
P-21 - Color regist test pattern failure
• The number of points detected in the main scan direction is more or less than the specified value during main scan direction registration correction.
• The number of points detected in the sub scan direction is more or less than the specified value during sub scan direction registration correction.
P-21: Color regist test pattern failure
Relevant parts:
• Transfer belt unit
• PH unit
• Printer control board (PRCB)
Step/Action:
1/ Wipe clean the surface of the transfer belt with a soft cloth, if it is dirty.
2/ Change the image transfer belt unit if the transfer belt is damaged.
3/ Change the PH unit.
4/ Change PRCB.
(See Service Manual, pages 599, 603):
http://www.imcopexamerica.com/service-books/Bizhub/Color/bizhubC451_C550_C650FieldSvc.pdf
See also here:
Konica Minolta Bizhub c451 Reparacin de Fotocopiadoras YoReparo
Thread Problemas na C451 7 21
May 31, 2015 | Konica Minolta Office Equipment & Supplies
How do i reset the trouble code c 2259
Black image unit motor failure. First open the front door remove the black image unit not the black toner!!!. Take the image unit and shake it so as to spread out all of the developer & toner inside the image unit along the whole length of the unit. The reason for this is as not have all of the developer/toner all at one end and the motor trying to turn with all that at one end or the other. Never store image units or toner vertically!!!!!
Now reinstall the image unit. and close the door. Opening and closing the front door will reset the machine . If it comes back good chance bad image unit.
May 13, 2014 | Konica Minolta KONICA BR BIZHUB C451...
Replaced the K imaging unit. The new unit does not reflect it being replaced on the copier. Consumables screen shows the K unit at empty still.
"K" is refereeing to the black toner not being full.... I would replace the Black toner bottle. The toners do have a chip on them, you may have got a defective one..... Good Luck
Jan 08, 2013 | Konica Minolta KONICA BR BIZHUB C451...
Bizhub c451 error code c2259?
Black developer motor failure to turn. You mite try pulling out the Black image unit and shake it to spread the toner and developer along the whole unit. The image unit mite have been stored standing up image units should always be laid flat. All the developer may be sitting at one end of the image unit an so the motor is having a difficult time turning.
Nov 27, 2012 | Konica Minolta KONICA BR BIZHUB C451...
Mar 30, 2009 | Konica Minolta bizhub C450P Laser Printer
83 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
