Question about Misc - MFG LTR-48247S Lite-On Cd-Rw Drive Black Bezel P/N 5187-2655 P/N: Ltr-4824
Need driver download for lite-on cd-rw model ltr-48247S-ppb1 and dvd-rom model xj-hd166s-dps7
Can i burn a cd using this model
No. It appears your drive is read only and incapable of burning discs.
Feb 12, 2015 | Lite On XJ-HD166S Internal DVD Drive
JLMS DVD-ROM XJ-HD166 DVD/CD ROM Drive does not acknowledge disc in drive after having the computer set back to factory
Does it not acknowledge dvd disc only or cd or dvd both. If it doesn't read the dvd disc, or able to play dvd disc, but able to exlpore regular cd's, then you have a codec error, and you need to download a dvd codec like powerdvd for it for your system to play dvd disc. Check to see if your dvd-rom drive appears in the "my computer" window, if it is there, but wouldn't be able to play anything, then it could be a driver issue. so make sure in the hardware , the drivers is installed and working properly. If it is working properly and driver is installed, then you got a bad drive, the optical laser lenses isnt reading or the spindle ain't working anymore if you don't hear disc being loaded when inserting the disc.
Jan 30, 2011 | Lite On XJ-HD166S Internal DVD Drive
Need driver SOFTWARE for XJ-HD166S
Here is the download link for the firmware for your DVD drive.
http://drivers.softpedia.com/progDownload/Lite-On-JLMS-XJ-HD166S-Firmware-D9C4-Download-38971.html
Jun 21, 2010 | Lite On XJ-HD166S Internal DVD Drive
CD ROM MODEL LTR-48327S IS MY CD BURNER WHEN I added a new cd/dvd player burner my cd burner quit working what is the problem?
each one has jumpers on the back. tiny plastic thing that slides over two pins. there are six pins. three sets of two. one device must be set to master one to slave or they wont work.
they are usually labeled with a picture or M S CS
master, slave, cable select.
Aug 22, 2009 | Lite On LTR-48327S CD-RW Burner
This drive stopped allowing CD burns. Is it just
Have had this issue in the past with Lite-On in particular. Stop gap measure was to uninstall and reinstall to get it working temporarily. It seems the life span of Lite-On isn't all that great. Best of luck.
Greg
Jun 11, 2009 | Lite On XJ-HD166S Internal DVD Drive
DVD Drive = JLMS DVD-ROM XJ-HD166
Hello I am looking for a driver for a JLMS DVD-ROM XJ-HD166S.
The system thinks it is a HD166.
I keep getting sent to DriverDetective. What a pain!
Jul 15, 2008 | Lite On XJ-HD166S Internal DVD Drive
Trying to find the driver to install for the cd-rw
Please download the driver file from this location its an exe file so when you will finish downloading click on open folder where you can find the correct driver file, and rest i think you know how to install it.
http://drivers.softpedia.com/get/FIRMWARE/Lite-On/LiteOn-LTR-52327S.shtml
Regards
Moses
Jan 13, 2008 | Lite On LTR 52327S CD-RW Burner
Lite-on LTR-52246s
As a first step try running this and then reboot the computer. Sometimes windows loses track of CD drivers. I see one or two computers a week at work with this problem. If they doesn't work it could be a few other things, let me know if it works.
Good Luck,
Matt
Nov 10, 2007 | Lite On LTR 52246S CD-RW Burner
Misc - MFG LTR-48247S Lite-On Cd-Rw Drive Black Bezel P/N 5187-2655 P/N: Ltr-4824 Logo
Top Misc - MFG Computers & Internet Experts
David Payne
David Payne
Are you a Misc - MFG Computer and Internet Expert? Answer questions, earn points and help others
