Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
Actually I m looking for cleaning company, which provides their services near around the Vancouver region?
I think you'd better check it on the Google there you'll get best options.http://www.thoroughclean.ca
Posted on Nov 22, 2013
Where could I get my 1960's Preway gas wall oven restored in the Vancouver BC area?
There is a brochure here for 1963. They made the first and only gas powered dishwasher! Your problem will be spares if it needs them. But hopefully it just needs servicing. It looks in good condition externally.
http://www.automatice.org/cgi-bin/index.cgi?showdoc~467~~
alt="Y Franks Parts & Service Ltd - Ranges, Cooktops & Stoves Sales & Services - 604-879-9407">
1490 Kingsway, Vancouver, BC V5N 2R5 1 YP review
Feb 11, 2016 | Ovens
I have the KEBK101SSSO4 that has stopped working. According to a tech, due to a defect, the mother board (I think) and lever burned due to self-cleaning. Should this be fixed by Kitchenaid?
There is a limited warranty on certain parts. It could depend on how long ago you bought it. The "tech" who told you this should be familiar with the procedure for this repair under warranty if his company works with this manufacturer. I suggest you call the manufacturer and ask them which service providers are certified to provide warrantied repairs in your area and contact one of them instead of who you did. I am a technician at a company that handles warranty work on these. good luck,
Aug 27, 2012 | KitchenAid "KEBK101sss Electric Single...
After I cleaned my ovens the top one doesn't heat anymore. I was told that the circuit fuse button has to be reset. We can't locate it. Can you please help? The model umber is: Thermador SCD302TP
Welcome to FixYa.
To address your post, looking for an over-temp cut-out tripped. Here`s what and where to look for for this,
Fortunately if it is tripped, they are the manual reset type and are accessible behind the black grill/vent just above the lower door ( just below upper door) next to the lock latch assembly.
**Turn off the 40amp breaker at your service panel or sub-panel in the home before attempting any service...safety first**
With the power off, you should be able to remove the grill and push the red button in the center of the thermostat and that should fix your problem...as shown here,
If indeed the hi-limit is tripped you`ll know immediately because you`ll feel it click as you push it down. It will look like the image below...
Other than that if you call in a pro, I'd suggest you be sure they are an authorized B/S/H/ service provider ( B/S/H/ is the parent company for Bosch, Thermador, Gaggenau, Siemens products ).
Hope that answers your question and gets you back up and operating. Good luck.
Regards,
Macmarkus :)
May 29, 2011 | Thermador SC302T Electric Double Oven
Describe your Thermador CT 130 C problem. Not heating up properly after we used self-cleaning feature. We have noticed that it is only heating up to half the temperature that it was set to.
Welcome to FixYa.
You have not mentioned if the oven has displayed any error code so I will take that for what it is...there was none shown.
With that, the post heading has conflicting info about your model so I'll go with the most common based on the SEC302 ovens.
I`d start by looking for an over-temp cut-out tripped. Since this problem started following a self clean cycle, it leads me to believe it is just that.
Fortunately if it is tripped, they are the manual reset type and are accessible behind the black grill/vent just above the door and just below the control panel next to the lock latch assembly.
macmarkus_108.jpg If indeed the hi-limit is tripped you`ll know immediately because you`ll feel it click as you push it down. It will look like the image below...
Ultimately it could be a faulty relay board or related to the timer, but I`d start with the hi-limit cut-out tripped first.
If the images I attached are not clear or you just want more info, I can send you a complete service manual in a "pdf" attachment, however you`d need to provide an email address to where I could send it to you.
Other than that if you call in a pro just be sure they are an authorized B/S/H/ service provider ( B/S/H/ is the parent company for Bosch, Thermador, Gaggenau, Siemens products ).
Let me know and I`ll watch for your reply and respond as soon as I can. Good luck.
Regards,
Macmarkus :)
Dec 20, 2010 | Thermador SEC302 Electric Double Oven
Self cleaned sc301 electric oven now when you press bake it shows 100 but never gets hot. reset circuit breaker still nothing any clues
Welcome to FixYa.
With that, I`d start by looking for an over-temp cut-out tripped. Since this problem started following a self clean cycle, it leads me to believe it is just that.
Regards,
Macmarkus :)
Dec 09, 2010 | Thermador C301U Electric Single Oven
When cleaning oven after 30 min. beeping and E 2 appeared
Welcome to FixYa.
I just would like to clarify what you posted. Are you certain it is "E2" and perhaps not "F2" ?
The "F2" on the SC302 wall ovens indicates an overtemp was detected by the onboard watchdog in the control board.
( The lock indicator being on is simply a byproduct of the unit being in self-clean at the time the error occured ).
What this means can actually come down to a couple of things, either an intermittent temp sensor or ultimately a bad main relay board.
In the SC302 service manual I have instructs simply to replace the temp sensor. If the F2 reappears replace the main relay board...but not so fast.
* The one exception which is not mentioned in the manual but I have experienced first hand in the field is this...A tripped overtemp safrety cut-out.
Here`s what to look for for this,
With the power off, you should be able to remove the grill and push the red button in the center of the thermostat and that should fix your problem...if indeed the hi-limit is tripped you`ll know immediately because you`ll feel it click as you push it down. It will look like the image below...
If you feel capable of repairing this yourself I can send you a complete service manual in a "pdf" attachment, however you`d need to provide an email address to where I could send it to you.
macmarkus :)
Jul 31, 2010 | Thermador SC302T Electric Double Oven
Oven keeps switching off
Hello
First double-check the gas supply. Look over the gas valves on the back of the oven to make sure gas is able to flow into the oven. If those look OK, call the gas company to see if there has been an interruption in service to the area or to the house.
If the oven grows too warm, the thermostat might malfunction and the thermostat is probably to blame for what you are experiencing.
The thermostat is the part of the oven that tells it when it has reached the desired temperature, shutting off the heating process. If one of the thermostat's components is broken or dirty, this can render the thermostat useless.
Cleaning and replacing the thermostat components is a process best left to professionals because untrained hands can easily break a thermostat that simply needed cleaning. If you suspect this is the issue, contact your local gas company. Sometimes, gas companies offer oven thermostat repair services.
Apr 16, 2010 | Thermador SC302T Electric Double Oven
We do not have a manual for the jenn air wall oven JJW8530BAB. we just hant to run the clean cycle but can't figure it out. anyone know how to set it to clean? sigmawolf
Actually I did not solve the problem as I'm just looking for a manual for the wall oven so I can set the clean cycle. I just can't see joining a service for just one manual.
Thanks,
Sigmawolf
Dec 16, 2009 | Jenn-Air JJW8530C Expressions Collection...
Oven not working
15
problem
8. door will not open.
9. oven will not heat after Self cleaning.
possible Cause
oven is in Self-clean mode.
time of day is not set due to power failure.
oven settings are not correct.
remedy
if oven is hot, door latch will release
automatically when oven temperature
falls below 390˚F at end of cycle.
if Self-clean was just selected
and the oven is still cool, press
“caNceL•SecuRe” to turn off Selfclean.
the door will open in about 30
seconds.
Press “cLock” touch pad, then press
“tiMe•teMP” pad to set correct time of
day.
follow mode selection and clock settings
as specified in the oveN oPeRatioN
section.
oven will turn on automatically
at preset time. if desired, press
“caNceL•SecuRe” touch pad to cancel
out of delay timed mode.
Troubleshooting Guide (Continued)
Important:
If a Failure Code is displayed, the oven will beep continuously until the user presses the “CanCel•seCure” button. the oven will not heat
after a failure. Call a qualified appliance technician to repair the oven.
Oven Failure Codes
Clock Display Cause
f0. touch pad is stuck in depressed position.
f1. Relay circuit failure.
f . oven temperature exceeded the clean runaway temperature (Self-clean mode
only) or the cooking runaway temperature (cooking modes only).
f3. Short circuit in the oven temperature sensor.
f4. open circuit in the oven temperature sensor.
f6. failure in the eePRoM check comparison. (only time of day and timer will
operate.)
f7 failure of the Self-clean automatic door latch circuit.
f8. failure of the door latch motor. occurs when the motor runs for two minutes
without the door locking in Self-clean mode.
befOre yOU Call fOr servICe
No maintenance, other than the Care anD CleanInG
InstruCtIons identified in this use & Care manual, should
be attempted by the owner/operator. all other maintenance and
service must be performed by a qualified appliance technician.
first, review the recommended checks listed in the preceding
troubleshooting Guide. then, be certain that the appliance has
been installed properly and is being operated correctly. familiarize
yourself with the warranty terms and conditions listed in the
proDuCt WarrantY section.
if the above checks have been completed and the problem has
not yet been remedied, call your local authorized dacoR®
service representative. your dealer can normally provide the name
and telephone number of the nearest service company.
prOdUCT maInTenanCe
If yOU need servICe...
dacoR® works diligently to ensure your satisfaction when
service is necessary. However, if you are not completely satisfied
with the service provided, contact the company that performed the
service and express why you are not pleased. Normally, they will
be willing and able to resolve the problem.
if the service agency is not able to respond effectively, call or
write the dacoR® customer Service department. the phone
number and address of this department are listed on the inside
front cover of this manual. Please include your telephone number
if you choose to write. we will then do our utmost to assure your
happiness and satisfaction.
Here is a snipet from www.dacor.com
You can view the manual there by enter ing your oven model number.
Feb 22, 2008 | Dacor ECD230 Epicure Electric Double Oven
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
215 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
