Question about Konica Minolta DiALTA Di183F Copier
C03FF Minolta bizhub 163 - Konica Minolta DiALTA Di183F Copier
xeerie
  • 347 Answers
SOURCE: C03FF Minolta bizhub 210
C03FF, is the improper or unmatched model setting code. go to "service mode" In service mode please select "ADJUST"
in "ADJUST" please select "Model Setting" in "Model Setting" select the cpm, (Copy speed) of your machine, for example if you have bizhub 210, then select "21" from the list. if you have bizhub 163 then select "16" from the list and press "yes" button. code will remove.
Posted on Jun 17, 2010
xeerie
  • 347 Answers
SOURCE: desbloqueo del codigo m2 en konica minolta bizhub 163
Este código significa que la vida las partes de su desarrollo + unidad de imagen se ha caducado. Ahora es el momento de reemplazar las partes.
Posted on Jun 19, 2010
  • 19 Answers
SOURCE: for konca minolta bizhub 163 model haw to resat
turn off the machine and hold in the stop button and turn on. If error returns you might have a dirty or faulty thermistor.
Posted on Jul 28, 2010
copyalbania
  • 44 Answers
SOURCE: err c 0500
This error code is a fuser problem and maybe in my experience a morning problem.
Try to clear the error the error with this procedure:
Hold down utility counter for 3 seconds and in the screen will appear a trouble reset, then touch it and turn off and on the main, it will clear the error code.
If it does not see if you have fuser problems with the termisotrs and also check the power.
Posted on Aug 13, 2010
SOURCE: error c03ff bizhub 211 konica minolta no se
model setting error :)
never change this setting.
if it changed,the Technical Rep.call (C03FF) will appear.
,default setting depend on the marketing area setting.
ex: 20ppm,18ppm,16ppm....
Posted on Jul 22, 2011
Konica minolta bizhub 163 error 0045, what I do to work
from what I've read here:
Error Codes Konica Minolta bizhub 163
, this is a Fusing Cooling Fan Motor malfunction, which suggests, I'm afraid, that you have to have it serviced.
Kind regards,
Jon Erik
Nov 14, 2014 | Konica Minolta bizhub Office Equipment &...
Minolta 163 count reset
Which counter, is this for a Minolta EP4000/5000 or the Minolta Bizhub 163?
Jan 08, 2014 | Minolta EP4000/5000 CS/PRO Copier
Konica Minolta bizhub 215 Printer error C3451& C03FF
For the C3451 Code replace the Fuser
For the C03FF there machine thinks it one model type the circuit board are set to a different model Change setting in Service mode under adjust to proper model.
Apr 01, 2013 | Konica Minolta bizhub Office Equipment &...
What is code c03ff for konica minolts bizhub 215
Model Setting - go to service mode press ( utility stop 00 stop 01 and go to adjust select model press off and on
Jan 24, 2013 | Konica Minolta Office Equipment & Supplies
Error c03ff bizhub 211 konica minolta no se resetea no guarda los cambios
Jul 22, 2011 | Konica Minolta Office Equipment & Supplies
Konica Minolta Bizhub 163 part manuals and error codes.
Process of auto adjustment of ATDC after refilling developer at Konica Minolta Bizhub 163
Dec 15, 2010 | Office Equipment & Supplies
Desbloqueo del codigo m2 en konica minolta bizhub 163
May 18, 2010 | Konica Minolta bizhub 161f All-In-One...
Addressbook problem on Bizhub 163
solution pour l'erreur COF32 pour konica minolta 163
Oct 09, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Jan 29, 2009 | Konica Minolta DiALTA Di183F Copier
Konica Minolta DiALTA Di183F Copier Logo
35 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
