Question about RoadPro Road Pro 12 Volt Dc Portable Battery Jump Starter & Air Compressor 12V Dc Portable Battery Jump Starter & 260 Psi Air Compressor
Need the manuall . i lost the . charger and i dont . know the . milliamps . to charge the unit withy
VEC012POB Manual
Vector sold to Black & Decker who then sold to Bacchus. The only manual I find with the same number you show is NOT yellow and has no USB connection. It is charged by a 110 volt wall wart charger that plugs into a receptacle on the unit, or a 12 volt cigar lighter cable that plugs into the 12 volt port on the unit. Here's a brochure for the model number you provoided:
May 31, 2014 | JUMP START SYSTEM
What (low voltage) goes from wall plug into (charger stand)? Thanks, Richard
I don't know what the question is here for sure but the voltage is converted to 12 volt from the wall to the charger. Milliamps is the only variation from charger to charger.
Jan 22, 2013 | Cobra Ga-cs Or Ga-cl Microtalk Charging...
I lost my cobra cxt227 manuals but I need to charge them. Do I charge them with the units on or off? How do I know they are charging?
You're best to charge them powered off. It's healthier for the batteries. Just put them on the charger and give them about 12 hours of uninterupted charging time.
Apr 29, 2012 | Cobra Electronics Microtalk Cxt225 -...
Hi i have a colman hot water on demand but have lost the 240 volt charger.i was wondering what milliamps or amps it needs to puchase another one from a elec store.
Coleman Charger mine is a 240~volt ~50Hz 12V~600mA
my other is a 240v ~5oHz 12V~1mA battery should only be( 6V4.5Ah)
with a 1mA hour change should only be 4 hours to charge as its a fast charger.
Jan 27, 2012 | Coleman Hot Water On Demand
I just dont know :/
That should not be too difficult to find out. Plug the phone in the charger and the charger to the wall socket. The phone should say Charging. Even if your particular phone does not say charging, leave the devices connected to the charger. After a few hours, unplug th phone and turn it on. If it does not stay on there is no charge. If it stays on, use your phone and see how long the charge lasts. If it lasts the same amount of time as it used to, then the charging occurs normally. If the charge does not hold, then there is incomplete charging or no charging at all.
Jan 14, 2012 | Computers & Internet
I lost the ac adapter. where can i buy one for this model 400 amps 260 psi air comp
Hello, I found that a 12 volt, 1500 milliamp charger for a Boston Acoustics set of speakers works to charge this. (halfway charged, today). So, I 'm sure on the 12 volts, and hoping it will be enough power to fully charge. B
Aug 15, 2010 | JUMP START SYSTEM
I just need a power supply cord to charge my jump starter system. Where can I get one?
Just get a generic charger from EBay. They may be available elsewhere. Get a 12 volt 500-600 milliamp one or if you know the exact milliamps for your charger, use that number. Here's a link to one on EBay.
http://cgi.ebay.com/12-VOLT-AC-POWER-SUPPLY-ADAPTER-12V-DC-600MA-CHARGER_W0QQitemZ300404845865QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item45f1862d29
I'm not recommending this particular one, just using it as an example. Good luck!
Mar 09, 2010 | JUMP START SYSTEM
Lost Charger for Toshiba 803T
dont know any., however.,you can still charge ur phone using pc/portable via usb.,u just need to install the phones driver.
Apr 17, 2008 | Toshiba 803T Cellular Phone
Wall charger
Radio shack carries a universal kit with choices of many different voltage and milliamp combination. Bring your DVD player to them, and they can help find the one that best suits you.
Aug 21, 2007 | Initial IDM-1731 Portable DVD Player with...
Battery/Power problem
many toshiba laptops used a 15 volt supply, but look at he label attached to the bottom of the unit. it should spell out what voltage and what current (in amps). if a 15 volt supply is used that can only supply 100 milliamps, while the laptop needs more than 1000 milliamps, the laptop will play dead
May 25, 2007 | Toshiba Tecra 740CDT Notebook
RoadPro Road Pro 12 Volt Dc Portable Battery Jump Starter & Air Compressor 12V Dc Portable Battery Jump Starter & 260 Psi Air Compressor Logo
Top RoadPro Air Tools & Compressors Experts
Lawrence Oravetz
ray gallant
 Bob Oppenheimer
Bob Oppenheimer
Level 1 Expert
Are you a RoadPro Air Tool and Compressor Expert? Answer questions, earn points and help others
