Question about Watches
My audel led touchscreen won't turn on - Watches
It died and won't charge or turn on
could be the battery .. try taking the back off,take battery out and leave the battery out for 10 minuets ..then put it back in . this could help restart the charging cycle . if not then you'll need a new battery
Apr 24, 2015 | Garmin Approach S3 Touchscreen Golf Watch
Need to set time on a childrens place led silicone watch
This how I set my son's watch from TCP. Press the screen to turn the watch on, once the time is displayed press and hold the center just below the display area until the hour blinks, then press repeatedly until the hour is correct. Press and hold again to set minutes, etc.
Apr 21, 2014 | The Children's Place Girls Led Silicone...
Getting a lock while scrolling
My S3 constantly triggers the screen lock whenever it is touched. How do I turn this feature off?
Jan 22, 2014 | Garmin Approach S3 Touchscreen Golf Watch
How to set a audel watch time
Google the model number of the watch for "manual" to try to locate the instructions that came with the watch.
Nov 05, 2012 | Watches
How to set audel touch led wrist watch
What you have to do is to press and hold the button for at least 5 seconds. Then when time starts flashing, you can change the time by pressing the button. To edit another value you press the button again and another value will flash.
May 05, 2012 | Watches
What kind of battery does the texas instruments model 101 watch use?
I am pretty certain that this watch uses two #386 silver oxide button cells. Alkaline cells would work, too, but they'd burn out more quickly--not that batteries last all that long in this watch, anyway. I'm basing this on the slightly newer (~1976-78) plastic-bodied TI LED watch that I have in front of me that I believe contains the same time keeping module as the original model 101.
It is also possible that the earlier watch would have taken #357 batteries, which are the same diameter as #386 cells but slightly taller. Both battery types were popular in LED watches of the time. However, I would suggest starting with #386 cells, as I destroyed the case back of a plastic TI LED watch many years ago by trying to use #357 batteries instead of the slightly smaller 386s. Both batteries put out the same voltage, so the watch will light up with either. However, the case back won't close if the battery is too tall--and if you force it, you can bend, distort, or shatter (in my case) the all-but-unobtainable case back.
Have fun with this watch! Mine still lights up and keeps good time.
May 28, 2011 | Watches
How do I set the time and date on my audel digital watch?
If u don't have the instructions for setting it contact the mfg because I'm not fimilar with that Brandi service all WatchESPN she I come across one I don't know that's I do if I can set it or google on how to set that what and some times u will get a video on how to set be sure u ask specifically how to set ur watch so u get the right video
Jun 22, 2010 | Watches
Changeing the time
Click on my profile (escapement), then click on Tips and Tricks. There you will find links to all watch manuals. Rate me, please .
Apr 14, 2010 | Adidas Candy Digital watch
Watches Logo
21 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
