Question about Cardo scala-rider Headset
Microphone Hi ..Can you help ,I can hear someone talking to me but they cant hear me ..think its the mic ?? where can i get it repaired or can I do it myself ? not to bad with lectrics..Brian
  • Damiano Migani Jan 18, 2008
    it happened to me too.
    I purchased a Scala Rider and I noticed that the mic wouldn't work. so I had it replaced under warranty and the new unit has the same proble.. Am I doing something wrong? I Installed the bluetooth, I can ear directions from my GPS in the helmet but if I make a phone call I can't hear the other person speaking, while the others can ear me.
    what can I do?
It is the microphone, this happened to me. I was inquisitive and out of warranty so had nothing to lose. Fix using these steps:
1. Remove foam microphone cover
2. Slide ring collar back down the boom
3. Split open the plastic microphone unit
4. Solder any loose wires - black to the rim, white to the middle of the microphone
5. Reverse steps above to put back together
Posted on Dec 06, 2008
    New Friend:
Before you go slicing thing open, check this. Remove the whole headset/mic assembly by undoing the retainer allen screw. You'll find it plugs into the cradle section with a single gold plated 3.5mm aux connector. Just like the socket on an iPod / iPhone. Look at the male connector. Chances are you may see crusty green corrosion deposits on the gold plating. I simply wiped mine vigorously with a microfiber cloth and reassembled. Good as new!
Obviously some rain / moisture had got in there over the winter. As a daily commuter it's hard to keep it out.
Posted on Feb 16, 2015
SOURCE:
Why can't they hear me talk on a call
You phoned microphone needs to be replaced. The speaker and Mic are two different components and works independently as well. IF people on the receiving end cant hear you, then your microphone is not fuctioning. Take it ti yiur dealer if it is still under warrantee or a reputable repair shop to replace the microphone
Aug 11, 2014 | BlackBerry Z30
I have google talk. when i call someone i can hear them but they cant hear me. My internal mic doesnt appear to be working.
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it
hope this helps
don
Feb 16, 2011 | Acer Computers & Internet
Motorola E1000 mic problem
U SHOULD CHANGE THE MIC OK BECAUSE THE MIC IS GONE IT TIME IS OVER IT WILL BE OVER 50 TO 200 RS/-
May 23, 2009 | Motorola Mobility E1000 Cellular Phone
Mirophone is not working on laptop
Hi
Firs of all I like to remind you the model that you have doesn't come with integrated microphone. However It will work any standard PC microphone that you can obtain around few dollars or less from IT stores. All you need to plug the microphone to the right side second socket socket as illustrated below
If issue persist please post further I will provide assistance accordingly
Good Luck
Feb 01, 2008 | Toshiba Portege S100-S1133 Notebook
Nokia N73 speaker fault?
try cleaning the mic first before replacing it..this usually does the trick..theres probably dust on the mic.
Jan 24, 2008 | Nokia N73 Cellular Phone
Microphone problem
If the speaker icon is in your system tray (next to your clock), then you can right click on it, then "Open Volume Control" and make sure your Microphone volume is up and that the mute (under microphone) check box is unchecked. If the icon is not there, you will have to check the box to show it in Control Panel > sounds and audio devices... You may have to go to options, then click on advanced controls to adjust the mic..
If that doesn't do it? You could update your audio driver.
Good luck.
Jan 12, 2008 | Dell Inspiron 2200 Notebook
Samsung x 495
hi blow inside the inlet on the phone check in the menu of the phone if the mic function is enabled check on other device if the mic is working at all good luck
Apr 02, 2006 | Samsung SPH-A500 Microphone
Cant talk
Try going to Control Panel -> Sounds and Audio Devices Click on Voice Tab and make sure the proper device is selected. Click on Volume and make sure levels are appropriate. Lastly, click on Test Hardware and wait until you can speak into the mic to see the voice levels. If you can see the voice levels, then your mic probably works and it is just an issue of configing the COD settings. goodl luck
Mar 15, 2006 | Altec Lansing AHS-502 Headset
Cardo scala-rider Headset Logo
964 people viewed this question
Top Cardo Radio Communications Experts
janvdb
Level 1 Expert
Tom Chichester
David
David
Level 1 Expert
Are you a Cardo Radio Communication Expert? Answer questions, earn points and help others
