Question about Broan-NuTone Allure II QS230SS Kitchen Hood
My broan elite vent hood fan turns on by itself
My kitchen fan turns on by its self
SOURCE: Damper need for Broan Range Hood
I called tech support at Broan and was told they recommend two dampers in cold climates ...one at in the wall cap and one on the unit. They make the damper,
(#BP87-7"), that attaches to the round duct plate that comes with the hood. Strangely the unit does not include a round damper and the seller LOWES did not have it, also checked Home Depot,.
The Tech said they can't get stores to stock it. I checked at a local supplier of all kinds of plumbing, heating, and cooling supplies and they only had basic 7" dampers which, I was told would probably be too heavy, and be manual. I ordered it through Amazon/True Value ($11.56 w/ shipping, shipping more than cost of damper). Tech indicated that the 2nd (unit damper) is optional and may not be needed if in a warm climate. I would suggest that Broan include the $5.00 item in their unit or at least sellers stock it.
Posted on Jun 28, 2008
SOURCE: my broan allure turns on by itself
Isn't it suppose to turn on automatically? The broan has a heat sensor!
Posted on Feb 28, 2009
  • 7 Answers
SOURCE: I am looking for a replacement blower for my broan k3500 hood fan
Call an outstanding customer support department at:
Customer Service: 800-558-1711
Technical Support: 800-637-1453
Posted on Aug 24, 2009
  • 95 Answers
SOURCE: Broan range vent fan not working
The motors will go bad from time to time. I would check Broan's web site
www.broan.com
or fill out this form
http://www.centralvacuumstores.com/fan_help.php
Posted on Sep 19, 2009
dmftrucker
  • 1922 Answers
SOURCE: short in electrical line or switch on cooktop hood
its the variable fan circuitry, the triac semiconductor is shorted
Posted on Nov 04, 2009
Brian range hood model CJD130SS fan light on display flashes with fan off or on.
I believe that's the "change or clean filter" indication. Clean the aluminum filters in the dishwasher, replace the charcoal filters if non-ducted, press the fan light over 3 seconds and it should reset.
Sep 02, 2013 | Broan-NuTone Broan Elite E661...
Broan elite hood vent has blinking light that won't reset with power off/on. What gives?
I turned both the light and fan on then pushed the filter button. After a loud beep the filter light reset went off. This worked for me.
Jan 21, 2011 | Broan-NuTone Broan Elite E661...
I just had a Broan Elite E662 hood installed and it is blowing out instead of pulling air in. I held a tissue up to the filter and it does not pull it up...rather it blows it down. Was something done...
It sounds like the fan blade may be installed upside down, or the entire motor/fan assembly is upside down. Typically, these small motors aren't reversible, so you should check the blade first.
Dec 13, 2009 | Broan-NuTone Broan Elite RM605404 Kitchen...
Fan turns on and off since turning hood light on a few days ago
If it is a Broan, there is a delay button that was also depressed. It will turn the fans off after a few minutes. If not, then you're shorted out either in the control panel or the wiring in the range hood.
Sep 23, 2009 | Broan-NuTone Allure II QS230SS Kitchen...
Broan range vent fan not working; motor humming but will not turn, light works fine, not the fuse.
www.broan.com
Sep 12, 2009 | Broan-NuTone Broan Range Hood Accessory
Range vent damper noise
Check to make sure that the installer completely untaped the damper when he installed it. It needs to be able to move freely.
Apr 04, 2009 | Broan-NuTone Allure III QS330SS Kitchen...
Nutone Allure fan has disco lights.
Its definetly the control board!!!
Part #R111632
Price $110.00
Definetly not cheap...
Dec 22, 2008 | Broan-NuTone Allure III QS330SS Kitchen...
Vibration at high speed
check these causes fan blade brackets,fan blade for cracks, any grease on blades.
Dec 27, 2007 | Broan-NuTone AllureĀ® I WS136BC Kitchen...
Broan allure fan and light
Check that you have not accidentaly switched the wall socket off in the cupboard above the rangehood. The slide switch could also be faulty.
Oct 30, 2007 | Broan-NuTone AllureĀ® I WS136BC Kitchen...
Clicking sound with the unit off.
Its probaly the duct. There is a little hinged door which is in the ducking right where the fan connects to your duct's, somtimes they play in the wind. I have heard this problem before. Is the clicking perfectly sycronized?
Sep 24, 2007 | Broan-NuTone Allure III QS330SS Kitchen...
Broan-NuTone Allure II QS230SS Kitchen Hood Logo
160 people viewed this question
Top Broan-NuTone Kitchen Ranges Experts
Dan Phillips
Level 1 Expert
Phil Lovisek
Phil Lovisek
Are you a Broan-NuTone Kitchen Range Expert? Answer questions, earn points and help others
